[GeoNode-users] geonode importlayers error when metadata XML is present
Daniel Victoria daniel.victoria at gmail.com
Wed May 4 12:26:39 PDT 2016
Oops, I feel embarrassed now! The metadata XML file that I though was in
ISO format was in fact, Dublin Core. I blame it on the intern that
downloaded the data. But it's my fault for not checking...
Anyway. I downloaded the (correct) ISO XML file from a GeoNode (v2.4),
placed it with the shapefile and imported it in our new geonode server
(v2.4). All the metadata came along. So this is basically what we are going
to do to move data around from one geonode instance to another
1) download the shapefile
2) download the ISO XML
3) Place them together
4) upload in the new server
5) Profit!
Cheers
Daniel
On Wed, May 4, 2016 at 11:12 AM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi Tom,
> Sorry for the late response. I was traveling. Continuing on this issue, I
> edited the geonode/layers/metadata.py according to your commit [1]. I then
> tried to add the shapefile which had the offending metadata xml file and I
> received the error "Cannot use None as a query value"
> My workflow is the following:
> 1) Download the shapefile and the metadata (ISO XML) from an old geonode
> (running v2.4)
> 2) Rename the metadata xml file to be the same as the shapefile
> 3) Upload the shapefile+metadata (xml) in the new geonode server (v2.4).
> I'm attaching the error I get when running geonode updatelayers
> Thanks for the help
> Daniel
> [1]
> https://github.com/GeoNode/geonode/commit/562af5f1b76cd785ecfb9ae996522a701c3f6dd5
> On Mon, Apr 25, 2016 at 10:02 PM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
>> Hi Daniel:
>> On Wed, Apr 13, 2016 at 2:43 PM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>> > Hi Tom et al.,
>> > I saw that you closed the issue. Great. Two questions though
>> > 1) Was the problem related to how the metadata was produced
>> (incomplete)? Or
>> > related to geonode not accepting incomplete data?
>> I would say both. Was the metadata produced in GeoNode?  If you can
>> reproduce
>> a workflow, this will help us validate it's a GeoNode metadata
>> handling issue that
>> we can then fix.
>> Thanks
>> ..Tom
>> > 2) I'm a newbie when it comes to updating GeoNode. I have it installed
>> from
>> > the ppa repositories. How can I apply the patch you just comited?
>> Should I
>> > just convert the GeoNode install folder from my machine into a git
>> > repository and pull from Github? Are there any tutorials on how to do
>> that?
>> > Thanks
>> > Daniel
>> > On Tue, Apr 12, 2016 at 10:40 PM, Daniel Victoria
>> >> Thanks Tom, I just opened an issue[1].
>> >> Now, getting back to my problem of getting the metadata from one
>> GeoNode
>> >> server to another. What would be the best option? I tried downloading
>> the
>> >> XML and putting it along with the shapefile since I'd rather not have
>> to
>> >> fill 100+ metadata records by hand.
>> >> What about the migration scripts from afabiani. Will that move both the
>> >> data (vector data in postgis or imagens in GeoServer) along with the
>> >> metadata?
>> >> Cheers
>> >> Daniel
>> >> [1] https://github.com/GeoNode/geonode/issues/2469
>> >> On Tue, Apr 12, 2016 at 5:27 PM, Tom Kralidis <tomkralidis at gmail.com>
>> >> wrote:
>> >>> On Tue, Apr 12, 2016 at 12:39 PM, Daniel Victoria
>> >>> > Hi all,
>> >>> > I'm trying to populate a new geonode instance (v2.4) with some
>> >>> > shapefiles
>> >>> > from another geonode (v2.4).
>> >>> > I have all the shapefiles in a directory so I'm inclined to use the
>> >>> > importlayers command. And to make things easier, I've downloaded the
>> >>> > metadata (ISO format, XML file) from the former geonode and placed
>> it
>> >>> > with
>> >>> > the shapefiles that will be imported.
>> >>> > The importlayers command fails with the following message
>> >>> > ./par_a01_2013_inventoryplotsubplot.shp
>> >>> > Traceback (most recent call last):
>> >>> >   File
>> >>> > "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py",
>> >>> > line 588, in upload
>> >>> >     title=title
>> >>> >   File
>> >>> > line 429, in file_upload
>> >>> >     vals, regions, keywords = set_metadata(xml_file.read())
>> >>> >   File
>> >>> > "/usr/local/lib/python2.7/dist-packages/geonode/layers/metadata.py",
>> >>> > line 62, in set_metadata
>> >>> >     vals, regions, keywords = dc2dict(exml)
>> >>> >   File
>> >>> > line 198, in dc2dict
>> >>> >     vals['date'] = sniff_date(mdata.modified)
>> >>> >   File
>> >>> > line 222, in sniff_date
>> >>> >     return datetime.datetime.strptime(datestr.strip(), dfmt)
>> >>> > AttributeError: 'NoneType' object has no attribute 'strip'
>> >>> > If I remove the XML file from the shapefile directory, the
>> importlayers
>> >>> > command works OK.
>> >>> > Any idea what is wrong? Attached is the offending metadata file,
>> just
>> >>> > in
>> >>> > case.
>> >>> > Cheers
>> >>> > Daniel
>> >>> Daniel: looks like missing metadata.  Having said this, we should
>> have a
>> >>> more
>> >>> graceful error.  If you can open a GitHub issue [1], I will fix.
>> >>> Thanks
>> >>> ..Tom
>> >>> [1] https://github.com/GeoNode/geonode/issues/new
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160504/a327b116/attachment.html>
More information about the geonode-users mailing list
