[GeoNode-users] Try to create a geonode's app into Windows OS
Jeffrey Johnson
ortelius at gmail.com
Mon May 16 10:16:26 PDT 2016
Awesome. Let us know if you need any more help.
On Mon, May 16, 2016 at 9:49 AM, Carlo Di Michele
<carlo.dimichele at gmail.com> wrote:
> Thanks Jeff.
> It worked.
> Regards
> Carlo
> 2016-05-16 17:09 GMT+01:00 Jeffrey Johnson <ortelius at gmail.com>:
>> Hi Carlo,
>> Running this command inside the python shell wont work. You need to a)
>> pip install Django b) run this command at the normal shell (cmd
>> prompt). If there are no problems with a) then b) should work.
>> Let us know if you run into further problems.
>> Jeff
>> On Mon, May 16, 2016 at 7:34 AM, Carlo Di Michele
>> > Hello,
>> > I'm trying to create a geonode app into Windows OS.
>> > I'm trying to follows the linux procedure
>> > http://docs.geonode.org/en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html#setup-admin
>> > The problem that I face is:
>> > $ Install python-django
>> > I can't find any python-django file anywhere in my installation so I did
>> > in
>> > this way:
>> > 1) I've run python
>> > C:\GeoNode-2.4.x\geonode-2.4.x\geonode\geoworld>python
>> > Python 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit
>> > (AMD64)] on
>> > win32
>> > Type "help", "copyright", "credits" or "license" for more information.
>> > 2) inside python terminal I typed
>> >>>> C:\GeoNode-2.4.x\geonode-2.4.x\Lib\site-packages\django\bin\django-admin
>> >>>> startproject my_geonode
>> >>>> --template=https://github.com/GeoNode/geonode-project/archive/master.zip
>> >>>> -epy,rst
>> > SyntaxError: invalid syntax
>> > Any hints?
>> > Thanks
>> > Carlo
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
