[GeoNode-users] Edit layer no CATALOG
Liyuneh Gebre liyenew at gmail.com
Tue Nov 1 04:26:27 PDT 2016
Dear Alessio
1) PUBLIC_URL configured in setting.py and local_setting.py as well in
web.xml for geoserver integration and it works fine from remote pc's can
access it .*.thank you *in advance
2) I deleted all the layers and maps and to update any files in DB there is
only one table BASE_LINK related with uploaded link and after deletion
nothing left there.
 but still the Error 404 exists
On Mon, Oct 31, 2016 at 6:42 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Ohh, I see ... most probably you changed the URL of GeoServer.
> GeoNode stores the server URL of the maps on DB. Maybe it is trying to
> access a wrong GeoServer or WMS URL.
> Try to get the whole WMS URL or the one related to that 404 error (which
> is a Resource not found by the way).
> In case it refers to a wrong URL you have only two options I guess (at
> least I'm aware of):
> 1. Manually update the maps JSON on DB by updating the wrong GeoServer
> address with the new one
> 2. Delete the maps and rebuild them from scratch
> In any case please make sure the "PUBLIC_URL" of GeoServer is correct on
> your settings.py file.
> Try to ask on mailing list if there exist a management command to do that
> automatically, but I'm afraid it is not.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Oct 31, 2016 at 4:36 PM, Liyuneh Gebre <liyenew at gmail.com> wrote:
>> i tried to truncate the log file
>> /var/log/httpd/error.log  and reboot the machine
>> and invoke the 404 error but no error was logged on error.log even the
>> python related
>> On Mon, Oct 31, 2016 at 5:35 PM, Alessio Fabiani <
>>> Ok, so you should be able to see the detailed error on
>>> /var/log/apache/error.log
>>> P.S.: I kindly suggest you to *not *send the log on the public mailing
>>> list, it could contain information you wouldn't share with people about
>>> your server and system setup. Try to find and cut just the Python exception
>>> if possible.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Mon, Oct 31, 2016 at 3:32 PM, Liyuneh Gebre <liyenew at gmail.com>
>>> wrote:
>>>> Apache 2.4.6
>>>> tomcat 7
>>>> java 7
>>>> On Mon, Oct 31, 2016 at 5:26 PM, Alessio Fabiani <
>>>>> Mmm, is there a chance to take a look at a more detailed log? Are you
>>>>> running GeoNode through an Apache2 Web Server or something?
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Mon, Oct 31, 2016 at 3:24 PM, Liyuneh Gebre <liyenew at gmail.com>
>>>>> wrote:
>>>>>> Dear Alessio
>>>>>> thanks it works after running
>>>>>> "python manage.py loaddata initial_data.json"
>>>>>> but am still can't figure out the *Create New Map Error throwing 404*
>>>>>> since i can access my geoserver and all the uploaded layers exist in
>>>>>> geoserver.
>>>>>> best regards
>>>>>> On Mon, Oct 31, 2016 at 5:04 PM, Alessio Fabiani <
>>>>>>> The problem is caused by the fact that the new versions of GeoNode
>>>>>>> are (at least for the moment) no more initialized.
>>>>>>> You need to import manually the "initial_data.json" fixtures in
>>>>>>> order to let it work correctly.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Mon, Oct 31, 2016 at 2:40 PM, Liyuneh Gebre <liyenew at gmail.com>
>>>>>>> wrote:
>>>>>>>> on Edit layer the catalog is not activated shown in the attached
>>>>>>>> png   and to update the other info
>>>>>>>> it returns "Category is required"
>>>>>>>> centos 7 geoserver 2.8.5 geonode 2.5.4
>>>>>>>> P.S still the creating map returns 404
>>>>>>>> *Liyuneh Gebre*
>>>>>>>> *Geospatial Database Administrator and Researcher *
>>>>>>>> *Ethiopian Institute of Agricultural Research *
>>>>>>>> *Climate and Geospatial Directorate *
>>>>>>>> *Office Phone: +251 -116-460380*
>>>>>>>> *Cell Phone:    +251-911- 858155*
>>>>>>>> *P.O.Box: 2003*
>>>>>>>> *Addis Ababa *
>>>>>>>> *Ethiopia*
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> *Liyuneh Gebre*
>>>>>> *P.O.Box: 2003*
>>>>>> *Addis Ababa *
>>>>>> *Ethiopia*
>>>> *Liyuneh Gebre*
>>>> *P.O.Box: 2003*
>>>> *Addis Ababa *
>>>> *Ethiopia*
>> *Liyuneh Gebre*
>> *P.O.Box: 2003*
>> *Addis Ababa *
>> *Ethiopia*
*Liyuneh Gebre*
*P.O.Box: 2003*
*Addis Ababa *
*Ethiopia*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161101/137dcf46/attachment-0001.html>
More information about the geonode-users mailing list
