[GeoNode-users] Edit layer no CATALOG
Liyuneh Gebre
liyenew at gmail.com
Wed Nov 2 03:56:09 PDT 2016
k after couple of hours if u are available i can install teamviewer
best regards
On Wed, Nov 2, 2016 at 1:53 PM, Liyuneh Gebre <liyenew at gmail.com> wrote:
> on *Creat New Map* it creates this error
> On Wed, Nov 2, 2016 at 1:39 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Sorry Liyuneh,
>> is this one the correct screenshot of the error you are experiencing?
>> [image: Inline image 1]
>> if so I need the URL of the failing window *not *of the main URL.
>> From you screenshot the /maps/new is working correctly (I can see the map
>> tool on the background).
>> I need to know exactly *when* you are getting this error (which are the
>> operation you are actually doing) and the URL of the modal windows throwing
>> the error. You can find this also by enabling the browser debug options on
>> the *net tab*. Please, let me know if you are able to find those
>> information.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, Nov 2, 2016 at 11:22 AM, Liyuneh Gebre <liyenew at gmail.com> wrote:
>>> i don' have any other this is the only one and geonde.conf file is all
>>> the same.
>>> On Wed, Nov 2, 2016 at 1:12 PM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Is your geonode.conf file comliant with the following one?
>>>> http://training.geonode.geo-solutions.it/_downloads/geonode.conf
>>>> Do you have any other apache2 conf file or Proxy configuration on your
>>>> system?
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Wed, Nov 2, 2016 at 11:09 AM, Liyuneh Gebre <liyenew at gmail.com>
>>>> wrote:
>>>>> *Cenots 7 with xfs partion stand alone machine not virtual*
>>>>> tomcat installation followed the document
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>> n/setup_on_centos/install_base_tomcat.html
>>>>> with java 1.7
>>>>> *Appache*
>>>>> http://training.geonode.geo-solutions.it/002_install_and_adm
>>>>> in/003_setup_on_centos/install_base_httpd.html
>>>>> *Geoserver*
>>>>> downloaded 2.7 and moved to /var/lib/tomcats/geoserver/webapps/ for
>>>>> deployment
>>>>> On Wed, Nov 2, 2016 at 12:56 PM, Alessio Fabiani <
>>>>>> Well the troubleshooting is not trivial.
>>>>>> Lets try to identify the issue first.
>>>>>> 1) How did you installed your system?
>>>>>> 2) Are you using Apache2 HTTPD server? (I guess so) If YES how did
>>>>>> you configured your virtualhosts?
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Wed, Nov 2, 2016 at 10:37 AM, Liyuneh Gebre <liyenew at gmail.com>
>>>>>> wrote:
>>>>>>> so is there any fix am waiting? or should i have to configure on
>>>>>>> Debian package
>>>>>>> best regards
>>>>>>> On Wed, Nov 2, 2016 at 12:01 PM, Alessio Fabiani <
>>>>>>>> Mmm,
>>>>>>>> "/maps/new" is a standard GeoNode endpoint, if you see a 404 error
>>>>>>>> thrown by Tomcat that means that there is a mapping/proxying issue on you
>>>>>>>> HTTP Server configuration.
>>>>>>>> Somehow this URL is redirected to the Tomcat instance, but it
>>>>>>>> should not.
>>>>>>>> Best Regards,
>>>>>>>> Alessio Fabiani.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Italy
>>>>>>>> On Wed, Nov 2, 2016 at 9:57 AM, Liyuneh Gebre <liyenew at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Dear Alessio
>>>>>>>>> thanks for your concern
>>>>>>>>> http://172.28.202.28/maps/new
>>>>>>>>> On Wed, Nov 2, 2016 at 11:47 AM, Alessio Fabiani <
>>>>>>>>>> Dear Liyuneh,
>>>>>>>>>> can you please send the link of the window showing the 404 error
>>>>>>>>>> please? Just copy and paste the link of the page.
>>>>>>>>>> Thanks,
>>>>>>>>>> Alessio.
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Italy
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> On Tue, Nov 1, 2016 at 12:26 PM, Liyuneh Gebre <liyenew at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> Dear Alessio
>>>>>>>>>>> 1) PUBLIC_URL configured in setting.py and local_setting.py as
>>>>>>>>>>> well in web.xml for geoserver integration and it works fine from remote
>>>>>>>>>>> pc's can access it .*.thank you *in advance
>>>>>>>>>>> 2) I deleted all the layers and maps and to update any files in
>>>>>>>>>>> DB there is only one table BASE_LINK related with uploaded link and after
>>>>>>>>>>> deletion nothing left there.
>>>>>>>>>>> but still the Error 404 exists
>>>>>>>>>>> On Mon, Oct 31, 2016 at 6:42 PM, Alessio Fabiani <
>>>>>>>>>>>> Ohh, I see ... most probably you changed the URL of GeoServer.
>>>>>>>>>>>> GeoNode stores the server URL of the maps on DB. Maybe it is
>>>>>>>>>>>> trying to access a wrong GeoServer or WMS URL.
>>>>>>>>>>>> Try to get the whole WMS URL or the one related to that 404
>>>>>>>>>>>> error (which is a Resource not found by the way).
>>>>>>>>>>>> In case it refers to a wrong URL you have only two options I
>>>>>>>>>>>> guess (at least I'm aware of):
>>>>>>>>>>>> 1. Manually update the maps JSON on DB by updating the wrong
>>>>>>>>>>>> GeoServer address with the new one
>>>>>>>>>>>> 2. Delete the maps and rebuild them from scratch
>>>>>>>>>>>> In any case please make sure the "PUBLIC_URL" of GeoServer is
>>>>>>>>>>>> correct on your settings.py file.
>>>>>>>>>>>> Try to ask on mailing list if there exist a management command
>>>>>>>>>>>> to do that automatically, but I'm afraid it is not.
>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Italy
>>>>>>>>>>>> On Mon, Oct 31, 2016 at 4:36 PM, Liyuneh Gebre <
>>>>>>>>>>>>> i tried to truncate the log file
>>>>>>>>>>>>> /var/log/httpd/error.log and reboot the machine
>>>>>>>>>>>>> and invoke the 404 error but no error was logged on error.log
>>>>>>>>>>>>> even the python related
>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:35 PM, Alessio Fabiani <
>>>>>>>>>>>>>> Ok, so you should be able to see the detailed error on
>>>>>>>>>>>>>> /var/log/apache/error.log
>>>>>>>>>>>>>> P.S.: I kindly suggest you to *not *send the log on the
>>>>>>>>>>>>>> public mailing list, it could contain information you wouldn't share with
>>>>>>>>>>>>>> people about your server and system setup. Try to find and cut just the
>>>>>>>>>>>>>> Python exception if possible.
>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 3:32 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>> Apache 2.4.6
>>>>>>>>>>>>>>> tomcat 7
>>>>>>>>>>>>>>> java 7
>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:26 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>> Mmm, is there a chance to take a look at a more detailed
>>>>>>>>>>>>>>>> log? Are you running GeoNode through an Apache2 Web Server or something?
>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 3:24 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>> Dear Alessio
>>>>>>>>>>>>>>>>> thanks it works after running
>>>>>>>>>>>>>>>>> "python manage.py loaddata initial_data.json"
>>>>>>>>>>>>>>>>> but am still can't figure out the *Create New Map Error
>>>>>>>>>>>>>>>>> throwing 404*
>>>>>>>>>>>>>>>>> since i can access my geoserver and all the uploaded
>>>>>>>>>>>>>>>>> layers exist in geoserver.
>>>>>>>>>>>>>>>>> best regards
>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 5:04 PM, Alessio Fabiani <
>>>>>>>>>>>>>>>>>> The problem is caused by the fact that the new versions
>>>>>>>>>>>>>>>>>> of GeoNode are (at least for the moment) no more initialized.
>>>>>>>>>>>>>>>>>> You need to import manually the "initial_data.json"
>>>>>>>>>>>>>>>>>> fixtures in order to let it work correctly.
>>>>>>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>>>> Italy
>>>>>>>>>>>>>>>>>> On Mon, Oct 31, 2016 at 2:40 PM, Liyuneh Gebre <
>>>>>>>>>>>>>>>>>>> on Edit layer the catalog is not activated shown in the
>>>>>>>>>>>>>>>>>>> attached png and to update the other info
>>>>>>>>>>>>>>>>>>> it returns "Category is required"
>>>>>>>>>>>>>>>>>>> centos 7 geoserver 2.8.5 geonode 2.5.4
>>>>>>>>>>>>>>>>>>> P.S still the creating map returns 404
>>>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>>>> *Geospatial Database Administrator and Researcher *
>>>>>>>>>>>>>>>>>>> *Ethiopian Institute of Agricultural Research *
>>>>>>>>>>>>>>>>>>> *Climate and Geospatial Directorate *
>>>>>>>>>>>>>>>>>>> *Office Phone: +251 -116-460380*
>>>>>>>>>>>>>>>>>>> *Cell Phone: +251-911- 858155*
>>>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>>>> *Ethiopia*
>>>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>>>> *Addis Ababa *
>>>>>>>>>>> *Ethiopia*
>>>>>>>>> *Liyuneh Gebre*
>>>>>>>>> *P.O.Box: 2003*
>>>>>>>>> *Addis Ababa *
>>>>>>>>> *Ethiopia*
>>>>>>> *Liyuneh Gebre*
>>>>>>> *P.O.Box: 2003*
>>>>>>> *Addis Ababa *
>>>>>>> *Ethiopia*
>>>>> *Liyuneh Gebre*
>>>>> *P.O.Box: 2003*
>>>>> *Addis Ababa *
>>>>> *Ethiopia*
>>> *Liyuneh Gebre*
>>> *P.O.Box: 2003*
>>> *Addis Ababa *
>>> *Ethiopia*
> *Liyuneh Gebre*
> *P.O.Box: 2003*
> *Addis Ababa *
> *Ethiopia*
*Liyuneh Gebre*
*P.O.Box: 2003*
*Addis Ababa *
*Ethiopia*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161102/b4b109cc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161102/b4b109cc/attachment-0001.png>
More information about the geonode-users
