[GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Francesco Bartoli
xbartolone at gmail.com
Wed Nov 2 05:11:26 PDT 2016
Surely, maybe we can handle that during the sprint at the latest
Cheers,
Francesco
Sent from [Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open source mail
client.
On nov 2 2016, at 1:07 pm, Alessio Fabiani <alessio.fabiani at geo-solutions.it>
wrote:
> Hi Francesco,
> good catch. Those commands are not documented on the official GeoNode
documentation (as far as I can see).
> It would be good to have them documented.
> I'll try to find some time to test them and improve the documentation. I
have no much time in these days though, so if someone would like to do that in
the meantime it will be very welcomed.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit [http://goo.gl/it488V](http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0
cy5vc2dlby5vcmc=) for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> [http://www.geo-solutions.it](http://www.geo-
solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
> [http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it&r=Z2
> **AVVERTENZE AI SENSI DEL D.Lgs. 196/2003**
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo
dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
proprietary in nature or covered by the provisions of privacy act (Legislative
Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not
in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly
forbidden except previous formal approval of the named addressee(s). If you
are not the intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message that has
been received in error. The sender does not give any warranty or accept
liability as the content, accuracy or completeness of sent messages and
accepts no responsibility for changes made after they were sent or for other
risks which arise as a result of e-mail transmission, viruses, etc.
> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli
<[xbartolone at gmail.com](mailto:xbartolone at gmail.com)> wrote:
>> Hi Alessio,
>> I think the geonode updatemaplayerip [1] might be of help
>> Ciao,
>> Francesco
>> [1] [https://github.com/GeoNode/geonode/blob/master/geonode/maps/management
/commands/updatemaplayerip.py](https://github.com/GeoNode/geonode/blob/master/
geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN
0cy5vc2dlby5vcmc=)
__Sent from [Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc
=), the extensible, open source mail client.__
On nov 2 2016, at 11:49 am, Alessio Fabiani <[alessio.fabiani at geo-
solutions.it](mailto:alessio.fabiani at geo-solutions.it)> wrote:
>>> Hello Nicolai,
>>> I'm going to maintain the discussion on the mailing list so that it can be
useful for other users too in the future.
>>> The problem should be related only to the maps. I'm currently not aware of
a quick command to do this. At this point you have two options:
>>> 1\. Delete only the old maps and rebuild them from scratch.
>>> 2\. Manually update the GeoServer ip address on the database -> main
geonode database, table "maps_maplayer"
>>> Best Regards,
>>> Alessio Fabiani.
N0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) for more
information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> [http://www.geo-solutions.it](http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2
Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5
vcmc=)
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer
<[nkcryer at gmail.com](mailto:nkcryer at gmail.com)> wrote:
>>>> Dear Alessio,
>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>> I just tested it out, and you were spot on - it's only the old maps that
have this issue. New maps created after changing the URL work perfectly. THANK
YOU!!! This is such a relief.
>>>> Do you know if there's any way to update the configuration in the
database? Or should I re-upload all the data?
>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <[alessio.fabiani at geo-
solutions.it](mailto:alessio.fabiani at geo-solutions.it)>:
>>>>> Dear Nicolai,
>>>>> is the problem related to the new layers also or just the old ones? Can
you please describe exactly your test-case?
>>>>> The thing is... if you are trying to expose your saved maps, consider
that the configuration is stored on the database. Therefore if you created
those maps with the old ip most probably the configuration still has the
latter recored on the DB.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
aXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=) for more
information.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlb
y5vcmc=)
for the attention and use of the named addressee(s) and may be confidential or
>>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer
>>>>>> Hi,
>>>>>> We're trying to open our Geonode installation to the public, and have
done the necessary DNS stuff. As such, our Geonode is able to serve static
files (html etc.) to outside the internal network, but the url for WMS
services etc. still seems to be configured to the localhost.
>>>>>> As such, users can view the Geonode front-end but cannot be served
WMS/WFS content from our geoserver (these show up as bad tiles in
geoexplorer).
>>>>>> I tried to solve this by editing local_settings.py in
C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the "PUBLIC_LOCATION" key
in the OGC dictionary.
>>>>>> The big problem is that no matter what I change in settings.py or
local_settings.py, how many times I restart Apache/Tomcat/the whole server,
delete .pyc files to be regenerated etc., the changes are never reflected in
the actual OGC configuration. I don't understand where the problem lies!
>>>>>> I've even attempted to delete settings.py without incident, so it's
like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>>>> I would be most grateful for any ideas, because I've almost exhausted
the list of buttons to push :/
>>>>>> Best,
>>>>>> Nicolai
>>>>>> _______________________________________________
geonode-users mailing list
[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/geonode-
users](http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2V
users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161102/cb267da6/attachment-0001.html>
More information about the geonode-users
