[GeoNode-users] MAP BASELAYERS
Simone Dalmasso simone.dalmasso at gmail.com
Sat Nov 5 02:16:37 PDT 2016
Hi, here you are overriding all the base layers and setting one that is
actually not visible. If you want to just add a baselayer you have to copy
the entire block from the settings and add this to it.
2016-11-04 22:16 GMT+01:00 Julierme Gonçalves Pinheiro <
juliermecoppe at hotmail.com>:
> Hi All,
> I have added the lines bellow to my localhost local_settings.py file and
> it did work fine. Now, I am trying to do the same thing in a EC2/AWS linux
> ubuntu server. When I add these lines to local_settings.py in my EC2
> server, all my Baselayers disappear from the layers and maps, even the
> default one. Could someone give me a tip on this issue?
> Thank you in advance for your time.
> MAP_BASELAYERS = [{
>     "source": {"ptype": "gxp_googlesource",},
>     "visibility": False,
>     "fixed": True,
>     "name":"SATELLITE",
>     "group":"background"
> *JULIERME GON??ALVES PINHEIRO*
> *_____________________________________________________________________________________________________________*
> * ??" O AMOR ?? PACIENTE, ?? BENIGNO; O AMOR N??O ARDE EM CI??MES, N??O SE
> UFANA, ??N??O SE?? *
> *ENSOBERBECE,??*
> *N??O SE CONDUZ??*
> * INCONVENIENTEMENTE, N??O PROCURA OS SEUS?? *
> *INTERESSES, N??O??*
> * SE EXASPERA, N??O SE RESSENTE DO MAL;?? N??O SE ALEGRA?? *
> * COM A INJUSTI??A,?? **MAS REGOZIJA-SE COM A VERDADE; TUDO SOFRE, TUDO
> CR??, TUDO ESPERA, TUDO SUPORTA.??*
> *O AMOR JAMAIS ACABA "??*
> * I COR??NTIOS 13: 4-8?? *
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161105/5b00d601/attachment.html>
More information about the geonode-users mailing list
