[GeoNode-users] Failed to download layers as anonymous user
Víctor González
victor.gonzalez at geomati.co
Fri Nov 18 06:37:48 PST 2016
I have a GeoNode instance installed from packages in a Ubuntu 14.04 [1].
Authentication between GeoNode and GeoServer seems to be working; if I log
into GeoNode and go to http://mygeonode/geoserver I am successfully logged
in as the GeoNode user.
The problem comes when I try to download a map as an anonymous user:
http://mygeonode/maps/976/download.
After clicking the download button and waiting a bit, I get a Basic HTTP
auth dialog because of a 401 response from
http://mygeonode/geoserver/rest/process/batchDownload/download/3
The map is configured for viewing and downloading by anyone and it works as
expected if I'm logged into GeoNode.
I've seen that the rest filter chain in GeoServer uses the
geonodeCookieFilter chain filter, which I think expects a valid "sessionid"
cookie. That cookie is being sent in my anonymous requests together with
csrftoken, both unexpired with path=/.
I tried to compare the behavior and requests with demo.geonode.org but
http://demo.geonode.org/geoserver is unresponsive right now.
Find here a section of geoserver.log in case it sheds some light:
2016-11-18 15:28:01,628 DEBUG [geoserver.security] - AuthenticationCache
found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to
lowercase, from: '/rest/process/batchdownload/status/3'; to:
'/rest/process/batchdownload/status/3' and httpMethod= GET
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~
antPath= /** methodList= [GET]
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is:
'/rest/process/batchdownload/status/3'; antPath is /**; matchedPath=true;
matchedMethods=true
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning
ROLE_ADMINISTRATOR
2016-11-18 15:28:01,629 DEBUG [ows.OWSHandlerMapping] - No handler mapping
found for [/rest/process/batchDownload/status/3]
2016-11-18 15:28:01,630 DEBUG [geoserver.filters] - Compressing output for
mimetype: application/json;charset=ISO-8859-1
[filter.GeoServerSecurityContextPersistenceFilter$1] -
SecurityContextHolder now cleared, as request processing completed
2016-11-18 15:28:01,775 DEBUG
lowercase, from: '/rest/process/batchdownload/download/3'; to:
'/rest/process/batchdownload/download/3' and httpMethod= GET
'/rest/process/batchdownload/download/3'; antPath is /**; matchedPath=true;
matchedMethods=true
ROLE_ADMINISTRATOR
2016-11-18 15:28:01,776 DEBUG
Is this a bug? Misconfiguration in my instance? The expected behavior?
Thanks in advance.
[1]
http://docs.geonode.org/en/master/tutorials/install_and_admin/quick_install.html#ubuntu
Víctor González
http://geomati.co
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161118/2da13cc4/attachment.html>
More information about the geonode-users
