[GeoNode-users] How to synchronize GWC configuration
Francesco Bartoli xbartolone at gmail.com
Mon Nov 21 15:56:49 PST 2016
Hi Toni,
you might try to clearing out the gwc configuration for that layer and then rebuild the tile caching.
Hope this helps
Francesco
Il giorno 21/nov/2016, alle ore 22:08, Toni Schönbuchner <toni.schoenbuchner at csgis.de> ha scritto:
> Hello,
> a Geonode 2.4 installation is not showing layers in Geoexplorer anymore.
> I´ve recognized that the wms request response with an error saying.
> „Could not locate a layer or layer group with id LayerInfoImpl--484e05d9:1460aec6751:-137f within GeoServer configuration
> the GWC configuration seems to be out of synch“
> Indeed I found a xml file within /usr/share/geoserver/data/gwc-layers/ which refers to a layer which
> cannot be found in geonode, geoserver or postgresql.
> after that I´ve tried
> $ geonode updatelayers --remove-deleted
> in hope it will remove leftovers but it failed with:
> "'Failed to process coral_reef', AttributeError(\"'NoneType' object has no attribute 'default_style'\",)" <Exception:>
> My question is which steps are needed to synchronize GWC configuration again?
> Thanks!
> Toni
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161122/7def84d6/attachment.html>
More information about the geonode-users mailing list
