[GeoNode-users] Error when saving style from gxp
Simone Dalmasso simone.dalmasso at gmail.com
Tue Nov 22 23:52:55 PST 2016
Hi Amedeo,
this is strange, it looks like your geonode layer is missing the title (you
can check that in the admin panel). I'm wondering if updatelayers could
create a resource without a style, this would be a bug indeed.
2016-11-22 9:44 GMT+01:00 Amedeo Fadini <amefad at gmail.com>:
> Hi everybody,
> I'm using Geonode 2.4 insatlled via ppa on Ubuntu server.
> I usually publish my layers in geoserver (most of them are sql views
> from a Postgis Database that aggregate data from other Mysql db using
> foreign tables) and so I prepare also the styles in geoserver and then
> synchronize with  geonode -updatelayers command.
> I need to add the same layer to a map two or more times, with
> different styles: when I try to modify the style from the map editor
> in geoexplorer it raise an error and  the style is not saved.
> Apache error Log attached below
> If I clone the style it raise an error "forbidden" (Cannot delete
> style associated with an other layer) but at the ends the new style is
> saved.
> Any clue?
> thanks
> Amedeo Fadini
>  [Tue Nov 22 09:28:42.948952 2016] [:error] [pid 6020] Internal Server
> Error: /gs/rest/styles/point.xml
> [Tue Nov 22 09:28:42.949015 2016] [:error] [pid 6020] Traceback (most
> recent call last):
> [Tue Nov 22 09:28:42.949022 2016] [:error] [pid 6020]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line
> 112, in get_response
> [Tue Nov 22 09:28:42.949028 2016] [:error] [pid 6020]     response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Tue Nov 22 09:28:42.949032 2016] [:error] [pid 6020]   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/views.py",
> line 339, in geoserver_rest_proxy
> [Tue Nov 22 09:28:42.949037 2016] [:error] [pid 6020]
> style_update(request, url)
> [Tue Nov 22 09:28:42.949043 2016] [:error] [pid 6020]   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py",
> line 1520, in style_update
> [Tue Nov 22 09:28:42.949049 2016] [:error] [pid 6020]     layer.save()
> [Tue Nov 22 09:28:42.949057 2016] [:error] [pid 6020]   File
> "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> line 90, in save
> [Tue Nov 22 09:28:42.949063 2016] [:error] [pid 6020]     return
> super(PolymorphicModel, self).save(*args, **kwargs)
> [Tue Nov 22 09:28:42.949067 2016] [:error] [pid 6020]   File
> "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 545,
> in save
> [Tue Nov 22 09:28:42.949072 2016] [:error] [pid 6020]
> force_update=force_update, update_fields=update_fields)
> [Tue Nov 22 09:28:42.949077 2016] [:error] [pid 6020]   File
> "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line 569,
> in save_base
> [Tue Nov 22 09:28:42.949082 2016] [:error] [pid 6020]
> [Tue Nov 22 09:28:42.949088 2016] [:error] [pid 6020]   File
> "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line
> 185, in send
> [Tue Nov 22 09:28:42.949101 2016] [:error] [pid 6020]     response =
> receiver(signal=self, sender=sender, **named)
> [Tue Nov 22 09:28:42.949107 2016] [:error] [pid 6020]   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py",
> line 88, in geoserver_pre_save
> [Tue Nov 22 09:28:42.949112 2016] [:error] [pid 6020]
> gs_resource.title = instance.title
> [Tue Nov 22 09:28:42.949117 2016] [:error] [pid 6020] AttributeError:
> 'NoneType' object has no attribute 'title'
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161123/67734c2e/attachment.html>
More information about the geonode-users mailing list
