[GeoNode-users] Geonode 2.4: Using Find Layer to add a Layer to Map leads to incorrect result
Simone Dalmasso simone.dalmasso at gmail.com
Thu Nov 24 07:09:05 PST 2016
Ciao Amedeo,
please open a bug, don't think is fixed yet.
2016-11-24 15:30 GMT+01:00 Amedeo Fadini <fame at libero.it>:
> Hi everybody,
> I'm not sure if this bug still persist in master, so I didn't submit an
> issue:
> Using Geonode 2.4.1 installed on Ubuntu via ppa
> I have a lot of layer created in geoserver and published using
> updatelayers.
> When I add a layer to the map using the "find layer" command  the
> "layer properties" view is not complete: it's not possible to select
> the info format in display tab and there's no "available styles" tab.
> If I add the same layer to the Map using Add layer and then selecting
> "Local geoserver" all is fine.
> Can someone confirm how is in master? Should I open a bug request?
> Amefad
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161124/8a72253b/attachment.html>
More information about the geonode-users mailing list
