[GeoNode-users] error when uploading projected layer
Nicolás Gallia
ngallia at cenpat-conicet.gob.ar
Tue Nov 29 10:00:01 PST 2016
Hello!
I have a need for uploading layers with certain projection (see .prj contents below), however Geonode states:
"Geoserver failed to detect the projection for layer [layer_name]. It doesn't look like EPSG:4326, so backing out the layer."
I've checked the format, but maybe there is an issue with units? or someting in geoserver?... (sorry I'm newbie in GIS)
the .prj file has:
PROJCS["Geographic_Coordinate_System_Transverse_Mercator",
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223560493]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["false_easting",2500000.0],
PARAMETER["false_northing",10001965.7],
PARAMETER["central_meridian",-69.0],
PARAMETER["scale_factor",1.0],
PARAMETER["latitude_of_origin",0.0],
UNIT["Meter",1.0]]
Ing. Nicolás A. Gallia
SECECOM
Centro Nacional Patagónico-CONICET
Bvd. Brown 2915
U9120ACD Puerto Madryn
Argentina
Tel +54 (0)280 488-3184 / 488-3185 (int. 1262)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161129/d8c54fd3/attachment.html>
More information about the geonode-users
