[GeoNode-users] Error in running geonode via docker
Francesco Bartoli
xbartolone at gmail.com
Fri Oct 21 02:02:16 PDT 2016
Hi Sindile,
The docker stuff is still a working progress, but this is definitively helpful
and more if you can kindly file an issue reporting the error that you are
facing.
Thanks,
Francesco
Sent from [Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-e10ac810-a27d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open source mail
client.
On ott 21 2016, at 10:57 am, Sindile Bidla <sindile.bidla at geoilocate.co.za>
wrote:
> Dear List
I am trying to run geonode via docker (this is my first attempt on using
docker
have done the following:
1\. cloned the master repo
2\. docker-compose build
3\. docker-compose up
have ran into errors:
**geonode/django "celery worker --app=" 35 minutes ago Exited (1) 35 minutes ago**
ran docker logs "container id"
File "/usr/local/bin/celery", line 11, in <module>
sys.exit(main())
File "/usr/local/lib/python2.7/site-packages/celery/__main__.py", line 30,
in main
main()
File "/usr/local/lib/python2.7/site-packages/celery/bin/celery.py", line 81,
in main
cmd.execute_from_commandline(argv)
769, in execute_from_commandline
super(CeleryCommand, self).execute_from_commandline(argv)))
File "/usr/local/lib/python2.7/site-packages/celery/bin/base.py", line 305,
argv = self.setup_app_from_commandline(argv)
File "/usr/local/lib/python2.7/site-packages/celery/bin/base.py", line 465,
in setup_app_from_commandline
self.app = self.find_app(app)
File "/usr/local/lib/python2.7/site-packages/celery/bin/base.py", line 485,
in find_app
return find_app(app, symbol_by_name=self.symbol_by_name)
File "/usr/local/lib/python2.7/site-packages/celery/app/utils.py", line 229,
in find_app
sym = symbol_by_name(app, imp=imp)
File "/usr/local/lib/python2.7/site-packages/celery/bin/base.py", line 488,
in symbol_by_name
return symbol_by_name(name, imp=imp)
File "/usr/local/lib/python2.7/site-packages/kombu/utils/__init__.py", line
96, in symbol_by_name
module = imp(module_name, package=package, **kwargs)
File "/usr/local/lib/python2.7/site-packages/celery/utils/imports.py", line
101, in import_from_cwd
return imp(module, package=package)
File "/usr/local/lib/python2.7/importlib/__init__.py", line 37, in
import_module
__import__(name)
ImportError: No module named celeryapp
****geonode/geoserver "/usr/local/tomcat/tm" 35 minutes ago Exited (1) 35 minutes ago**
cp: cannot stat
‘/geoserver_data/data/security/auth/geonodeAuthProvider/config.xml’: No such
file or directory
What am I doing wrong
> Sindile Bidla
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20161021/7df10423/attachment.html>
More information about the geonode-users
