[GeoNode-users] Development install and vagrant config.
Erklauer, Dan
derklauer at oceaneering.com
Tue Sep 6 06:31:16 PDT 2016
Thank you, I was able to resolve it with the following modifications to the
standard instructions:
1. Set SITEURL to "http://localhost"
2. Set ALLOWED_HOST = [‘*’]
2. added three port forwarding rules to the vagrant file:
config.vm.network "forwarded_port", guest: 80, host: 1234
config.vm.network "forwarded_port", guest: 8000, host: 1235
config.vm.network "forwarded_port", guest: 8080, host: 1236
3. started the server with python manage.py runserver 0.0.0.0:1234
Now from my host "localhost:1234" returns geonode.
On Tue, Sep 6, 2016 at 8:23 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, take a look at the apache logs. But ALLOWED_HOSTS = ['127.0.0.1',
> 'localhost', '::1'] should also contain the 1234 port ALLOWED_HOSTS = ['
> 127.0.0.1:1234', 'localhost:1234', '::1']
> hope it helps
> 2016-09-06 2:42 GMT+02:00 Erklauer, Dan <derklauer at oceaneering.com>:
>> I'm creating a VM development instance with vagrant and I'm using this
>> document as a reference for vagrant
>> <http://geonode-docs.readthedocs.io/en/latest/tutorials/admin/prep/index.html#setup-a-vagrant-machine-on-mac-osx> and
>> this one
>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>> for the geonode installation process. I'm having some problems. Im going
>> to run the vm over local host port 1234 with vagrant so I have set my
>> vagrant file to config.vm.network :forwarded_port, guest: 80, host: 1234
>> and edited my local_settings.py to:
>> ALLOWED_HOSTS = ['127.0.0.1', 'localhost', '::1']
>> PROXY_ALLOWED_HOSTS = ("127.0.0.1", 'localhost', '::1')
>> POSTGIS_VERSION = (2, 1, 2)
>> SITEURL = "http://localhost:1234"
>> I've left the genode.conf and the web.xml files as
>> localhost wherever referenced in the install docs. But I get a 500 error "*Apache/2.4.7
>> (Ubuntu) Server at localhost:1234"
>> when trying to access http://localhost:1234/ <http://localhost:1234/> after
>> the install. *
>> *As a test I've also set up my vagrant network for an ip and when I hit
>> the IP:8080 I'm able to reach geoserver. I have not had any luck getting
>> the geonode sit when hitting the IP (after modifying local_settings URL to
>> IP)*
>> The two documents have some discrepancies with regards to version
>> numbers, anyone have any suggestions? For an OS I went with ubuntu/trusty32
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160906/cfcedb4d/attachment.html>
More information about the geonode-users
