[GeoNode-users] Edit option for CSV,KML file upload
Naresh N naresh919 at gmail.com
Fri Sep 16 03:44:50 PDT 2016
Dear Simone Dalmasso,
  Thank a lot for quick response. Yes I am using postgres database. If I
load shapefile  ,then Create, Modify options are working fine. But in case
of CSV and KML files the issues which I mentioned in my earlier mail is
coming. Please any idea to resolve.
Thanks&Regards,
Naresh
On Fri, Sep 16, 2016 at 2:22 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, are you using a postgres database to store your data? Make sure they
> are correctly loaded there by geoserver otherwise the feature editing is
> not available.
> 2016-09-16 9:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Geonode Users,
>>  I have installed Geonode in Windows environment. To Upload CSV, KML
>> files the following is included in local_setting.py and able to upload csv,
>> kml files.
>> UPLOADER = {
>>     'BACKEND': 'geonode.rest',
>>     'OPTIONS': {
>>         'TIME_ENABLED': False,
>>         'GEOGIG_ENABLED': False,
>>     'BACKEND': 'geonode.importer',
>>     'OPTIONS': {
>> When we  visualize uploaded  file through the Explore Layers option and
>> if we select Edit Data option the following *issues *are facing
>> 1. In Map window section --> Edit --> *Create option* is in *grey out
>> mode* .i.e not able to select
>> 2. If we click on* Modify option* and click on features option then *feature
>> info option is not visible* and not able to edit the feature geometry
>> and attributes information. I could able to find through the firebug that
>> the  features information is returning to browser but popup is not visible.
>> Please find the attached  screenshot
>> Please suggest me to resolve the issue.
>> Thanks&Regards,
>> Naresh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160916/56213eac/attachment.html>
More information about the geonode-users mailing list
