[GeoNode-users] windows ldap
Dan Erklauer
derklauer at oceaneering.com
Sun Sep 18 19:55:23 PDT 2016
Chris the ldap library is not a prerequisite for geonode. I'm assuming
your following there documentation. That error is telling you don't have
it installed. You will need to install the library use pip or easy install
whichever you have on your windows box.
Dan
On Sep 18, 2016, at 9:48 PM, Franklin, Chris <CFranklin at anglogoldashanti.com>
wrote:
Dan,
I can't run 'import ldap'
<image002.png>
What am I doing wrong?
Regards.
Chris
Today's Topics:
1. windows ldap (Erklauer, Dan)
Message: 1
Date: Thu, 8 Sep 2016 08:40:59 -0500
From: "Erklauer, Dan" <derklauer at oceaneering.com>
To: geonode-users at lists.osgeo.org
Subject: [GeoNode-users] windows ldap
Message-ID:
CAGHmGXNBAnx_KQ1X9AiqbSE663UkK7KxR5Pw139B3kTPCQyzsw at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Chris, I connected yesterday to an LDAP with geonode, it was linux but I
doubt this is an OS issue. There are a couple of things I would
recommend. First check and make sure your dependencies are all there and
available to the user running geonode. On your geonode server enter the
python command line and do 'import ldap' and 'from django_auth_ldap.config
import LDAPSearch'. Make sure that works. Then make sure you can connect
to your ldap server, test this via command line here is an article on how
you do that
http://serverfault.com/questions/452935/how-to-test-a-ldap-connection-from-a-client
make
sure you use the same parameters you are using in the django app, it looks
to me that some of your ldap variables are incorrect (formatting). After
you confirm that you can connect to your directory and your dependencies
are there test using the django installed server (python manage.py
runserver). The code below is how I connected and has some error flags that
will clearly tell, if there is an error and what it is. In my case I had
an ssl issue which I resolved with the ldap.set_option().
DEBUG=True
import ldap
from django_auth_ldap.config import LDAPSearch
ldap.set_option(ldap.OPT_X_TLS_CACERTFILE,'directory/that/has/cert/mycert.crt')
AUTHENTICATION_BACKENDS = (
'django_auth_ldap.backend.LDAPBackend',
'django.contrib.auth.backends.ModelBackend',
'guardian.backends.ObjectPermissionBackend',
AUTH_LDAP_SERVER_URI = 'ldaps://xxxx'
LDAP_SEARCH_DN = 'CN=users,dc=xxx,dc=xxx'
AUTH_LDAP_USER = '(cn=%(user)s)'
AUTH_LDAP_BIND_DN = 'CN=xxx,CN=Users,DC=xxx,DC=xxx'
AUTH_LDAP_BIND_PASSWORD = 'xxxx'
AUTH_LDAP_USER_ATTR_MAP = {
'first_name': 'givenName', 'last_name': 'sn',
AUTH_LDAP_USER_DN_TEMPLATE = "cn=%(user)s,cn=users,dc=xxx,dc=xxx"
AUTH_LDAP_CONNECTION_OPTIONS = {
ldap.OPT_DEBUG_LEVEL: 0,
ldap.OPT_REFERRALS: 0,
LOGGING = {
'version': 1,
'disable_existing_loggers': False,
'handlers': {
'mail_admins': {
'level': 'ERROR',
'class': 'django.utils.log.AdminEmailHandler'
'stream_to_console': {
'level': 'DEBUG',
'class': 'logging.StreamHandler'
'loggers': {
'django.request': {
'handlers': ['mail_admins'],
'level': 'ERROR',
'propagate': True,
'django_auth_ldap': {
'handlers': ['stream_to_console'],
'level': 'DEBUG',
'propagate': True,
On Thu, Sep 8, 2016 at 6:18 AM, <geonode-users-request at lists.osgeo.org>
wrote:
> Send geonode-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
> 1. Re: LDAP on windows (Alessio Fabiani)
> Message: 1
> Date: Thu, 8 Sep 2016 13:18:09 +0200
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> To: "Franklin, Chris" <CFranklin at anglogoldashanti.com>
> Cc: Jeffrey Johnson <ortelius at gmail.com>,
> "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] LDAP on windows
> Message-ID:
> <CAM7ZvLK+LHLnZjwg8x2AJ0onFm60RDhU5FWJoR
> 3nppDErWmLJQ at mail.gmail.com>
> Well the most evident and latest one visible from the logs is the
following
> one:
> URLError: <urlopen error [Errno 10060] A connection attempt failed because
> the connected party did not properly respond after a period of time, or
> established connection failed because connected host has failed to
respond>
> but is quite difficult to understand which is the cause... are you sure
the
> LDAP settings are all correct?
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure,
reproduction,
> copying, distribution, or either dissemination, either whole or partial,
is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Thu, Sep 8, 2016 at 1:11 PM, Franklin, Chris <
> CFranklin at anglogoldashanti.com> wrote:
> > Think that was from trying to get google basemaps working.....nothing
> else
> > in the error file?
> > Chris Franklin
> > GIS & DB Co-ordinator
> > On 8 Sep 2016, at 16:06, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>
> > wrote:
> > It looks like a syntax error on the settings.py
> > File "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\settings.py", line
> 902,
> > referer: http://aupegis03/maps/?limit=100&offset=0
> > [Thu Sep 08 11:07:03.279819 2016] [wsgi:error] [pid 7508:tid 2592]
> [client
> > 172.16.1.176:50471] "name": "SATELLITE",, referer: http://aupegis03/
> [client
> > 172.16.1.176:50471] ^, referer: http://aupegis03/
> [client
> > 172.16.1.176:50471] SyntaxError: invalid syntax, referer:
> > Best Regards,
> > Alessio Fabiani.
> > @alfa7691
> > GeoSolutions S.A.S.
> > Italy
stesso,
> for
> or
> reproduction,
> is
> or
> > On Thu, Sep 8, 2016 at 10:01 AM, Franklin, Chris <
> >> Here’s the error log from today with access log attached- nothing
stands
> >> out to me but I could of easily missed something
> >> [Thu Sep 08 10:30:24.136957 2016] [mpm_winnt:notice] [pid 6492:tid 592]
> >> AH00422: Parent: Received shutdown signal -- Shutting down the server.
> >> [Thu Sep 08 10:30:26.160015 2016] [mpm_winnt:notice] [pid 2732:tid 492]
> >> AH00364: Child: All worker threads have exited.
> >> [Thu Sep 08 10:30:26.363115 2016] [mpm_winnt:notice] [pid 6492:tid 592]
> >> AH00430: Parent: Child process 2732 exited successfully.
> >> [Thu Sep 08 10:30:28.117702 2016] [core:warn] [pid 4512:tid 592]
> AH00117:
> >> Ignoring deprecated use of DefaultType in line 424 of
> >> C:\\GeoNode-2.4.x\\Apache2/conf/httpd.conf.
> >> [Thu Sep 08 10:30:28.133343 2016] [wsgi:warn] [pid 4512:tid 592]
> >> mod_wsgi: Compiled for Python/2.7.10+.
> >> mod_wsgi: Runtime using Python/2.7.10.
> >> [Thu Sep 08 10:30:28.133343 2016] [mpm_winnt:notice] [pid 4512:tid 592]
> >> AH00455: Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10 configured
> >> resuming normal operations
> >> AH00456: Server built: Dec 9 2015 12:21:09
> >> [Thu Sep 08 10:30:28.133343 2016] [core:notice] [pid 4512:tid 592]
> >> AH00094: Command line: 'C:\\GeoNode-2.4.x\\Apache2\\bin\\Apache.exe -d
> >> C:/GeoNode-2.4.x/Apache2 -d C:\\GeoNode-2.4.x\\Apache2'
> >> AH00418: Parent: Created child process 7132
> >> [Thu Sep 08 10:30:28.523970 2016] [core:warn] [pid 7132:tid 492]
> AH00117:
> >> [Thu Sep 08 10:30:28.539596 2016] [core:warn] [pid 7132:tid 492]
> AH00117:
> >> [Thu Sep 08 10:30:28.555222 2016] [wsgi:warn] [pid 7132:tid 492]
> >> [Thu Sep 08 10:30:28.586480 2016] [mpm_winnt:notice] [pid 7132:tid 492]
> >> AH00354: Child: Starting 250 worker threads.
> >> [Thu Sep 08 10:30:36.671636 2016] [wsgi:error] [pid 7132:tid 2592]
> >> [client 172.16.1.176:49975] mod_wsgi (pid=7132): Exception occurred
> >> processing WSGI script 'C:/GeoNode-2.4.x/geonode-2.4.
> x/geonode/wsgi.py'.,
> >> referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] Traceback (most recent call last):,
> referer:
> >> [client 172.16.1.176:49975] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> 4.x\\lib\\site-packages\\django\\core\\handlers\\wsgi.py", line 187, in
> >> __call__, referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] self.load_middleware(), referer:
> >> 4.x\\lib\\site-packages\\django\\core\\handlers\\base.py", line 44, in
> >> load_middleware, referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] for middleware_path in
> >> settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/layers/?limit
> >> =100&offset=0
> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 54, in
> >> __getattr__, referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] self._setup(name), referer:
> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in
> _setup,
> >> [client 172.16.1.176:49975] self._wrapped =
> >> Settings(settings_module), referer: http://aupegis03/layers/?limit
> >> =100&offset=0
> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 128, in
> >> __init__, referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] mod = importlib.import_module(self.
> SETTINGS_MODULE),
> >> 4.x\\lib\\site-packages\\django\\utils\\importlib.py", line 40, in
> >> import_module, referer: http://aupegis03/layers/?limit=100&offset=0
> >> [client 172.16.1.176:49975] __import__(name), referer:
> >> line 874, in <module>, referer: http://aupegis03/layers/?limit
> >> =100&offset=0
> >> [client 172.16.1.176:49975] from local_settings import * # noqa,
> >> 4.x\\geonode\\local_settings.py", line 59, referer:
> >> [client 172.16.1.176:49975] SyntaxError: Non-ASCII character '\\xe2' in
> >> file C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\local_settings.py on
> >> line 59, but no encoding declared; see http://python.org/dev/peps/pep
> >> -0263/ for details, referer: http://aupegis03/layers/?
> limit=100&offset=0
> >> [Thu Sep 08 10:30:43.392043 2016] [wsgi:error] [pid 7132:tid 2592]
> >> [client 172.16.1.176:49976] mod_wsgi (pid=7132): Exception occurred
> x/geonode/wsgi.py'.
> >> [client 172.16.1.176:49976] Traceback (most recent call last):
> >> [client 172.16.1.176:49976] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> __call__
> >> [client 172.16.1.176:49976] self.load_middleware()
> >> load_middleware
> >> [client 172.16.1.176:49976] for middleware_path in
> >> __getattr__
> >> [client 172.16.1.176:49976] self._setup(name)
> >> 4.x\\lib\\site-packages\\django\\conf\\__init__.py", line 49, in _setup
> >> [client 172.16.1.176:49976] self._wrapped =
> >> __init__
> >> [client 172.16.1.176:49976] mod = importlib.import_module(self.S
> >> ETTINGS_MODULE)
> >> import_module
> >> [client 172.16.1.176:49976] __import__(name)
> >> [client 172.16.1.176:49976] from local_settings import * # noqa
> >> [client 172.16.1.176:49976] SyntaxError: Non-ASCII character '\\xe2' in
> >> -0263/ for details
> >> [Thu Sep 08 10:30:45.002868 2016] [wsgi:error] [pid 7132:tid 2588]
> >> [client 172.16.1.176:49977] mod_wsgi (pid=7132): Exception occurred
> x/geonode/wsgi.py'.
> >> [client 172.16.1.176:49977] Traceback (most recent call last):
> >> [client 172.16.1.176:49977] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> __call__
> >> [client 172.16.1.176:49977] self.load_middleware()
> >> load_middleware
> >> [client 172.16.1.176:49977] for middleware_path in
> >> __getattr__
> >> [client 172.16.1.176:49977] self._setup(name)
> >> [client 172.16.1.176:49977] self._wrapped =
> >> __init__
> >> [client 172.16.1.176:49977] mod = importlib.import_module(self.S
> >> ETTINGS_MODULE)
> >> import_module
> >> [client 172.16.1.176:49977] __import__(name)
> >> [client 172.16.1.176:49977] from local_settings import * # noqa
> >> [client 172.16.1.176:49977] SyntaxError: Non-ASCII character '\\xe2' in
> >> -0263/ for details
> >> [Thu Sep 08 10:31:14.498944 2016] [mpm_winnt:notice] [pid 4512:tid 592]
> >> [Thu Sep 08 10:31:19.863632 2016] [mpm_winnt:notice] [pid 7132:tid 492]
> >> [Thu Sep 08 10:31:20.187075 2016] [mpm_winnt:notice] [pid 4512:tid 592]
> >> AH00430: Parent: Child process 7132 exited successfully.
> >> [Thu Sep 08 10:31:21.047950 2016] [core:warn] [pid 7844:tid 592]
> AH00117:
> >> [Thu Sep 08 10:31:21.063577 2016] [wsgi:warn] [pid 7844:tid 592]
> >> [Thu Sep 08 10:31:21.063577 2016] [mpm_winnt:notice] [pid 7844:tid 592]
> >> [Thu Sep 08 10:31:21.063577 2016] [core:notice] [pid 7844:tid 592]
> >> AH00418: Parent: Created child process 2460
> >> [Thu Sep 08 10:31:21.485472 2016] [core:warn] [pid 2460:tid 492]
> AH00117:
> >> [Thu Sep 08 10:31:21.501101 2016] [core:warn] [pid 2460:tid 492]
> AH00117:
> >> [Thu Sep 08 10:31:21.516725 2016] [wsgi:warn] [pid 2460:tid 492]
> >> [Thu Sep 08 10:31:21.547984 2016] [mpm_winnt:notice] [pid 2460:tid 492]
> >> [Thu Sep 08 10:31:29.775250 2016] [wsgi:error] [pid 2460:tid 2592] Not
> >> enabling BingMaps base layer as a BING_API_KEY is not defined in
> >> local_settings.py file.
> >> [Thu Sep 08 10:54:30.903346 2016] [mpm_winnt:notice] [pid 7844:tid 592]
> >> [Thu Sep 08 10:54:32.934649 2016] [mpm_winnt:notice] [pid 2460:tid 492]
> >> [Thu Sep 08 10:54:33.122107 2016] [mpm_winnt:notice] [pid 7844:tid 592]
> >> AH00430: Parent: Child process 2460 exited successfully.
> >> [Thu Sep 08 10:54:34.028352 2016] [core:warn] [pid 512:tid 592]
AH00117:
> >> [Thu Sep 08 10:54:34.043977 2016] [wsgi:warn] [pid 512:tid 592]
> mod_wsgi:
> mod_wsgi:
> >> [Thu Sep 08 10:54:34.043977 2016] [mpm_winnt:notice] [pid 512:tid 592]
> >> [Thu Sep 08 10:54:34.043977 2016] [core:notice] [pid 512:tid 592]
> >> AH00418: Parent: Created child process 3380
> >> [Thu Sep 08 10:54:34.434603 2016] [core:warn] [pid 3380:tid 492]
> AH00117:
> >> [Thu Sep 08 10:54:34.465853 2016] [core:warn] [pid 3380:tid 492]
> AH00117:
> >> [Thu Sep 08 10:54:34.465853 2016] [wsgi:warn] [pid 3380:tid 492]
> >> [Thu Sep 08 10:54:34.497103 2016] [mpm_winnt:notice] [pid 3380:tid 492]
> >> [Thu Sep 08 10:54:42.762744 2016] [wsgi:error] [pid 3380:tid 2592]
> >> [client 172.16.1.176:50268] mod_wsgi (pid=3380): Exception occurred
> >> [client 172.16.1.176:50268] Traceback (most recent call last):,
> referer:
> >> [client 172.16.1.176:50268] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> [client 172.16.1.176:50268] self.load_middleware(), referer:
> >> [client 172.16.1.176:50268] for middleware_path in
> >> =100&offset=0
> >> [client 172.16.1.176:50268] self._setup(name), referer:
> _setup,
> >> [client 172.16.1.176:50268] self._wrapped =
> >> =100&offset=0
> >> [client 172.16.1.176:50268] mod = importlib.import_module(self.
> SETTINGS_MODULE),
> >> [client 172.16.1.176:50268] __import__(name), referer:
> >> =100&offset=0
> >> [client 172.16.1.176:50268] from local_settings import * # noqa,
> >> [client 172.16.1.176:50268] SyntaxError: Non-ASCII character '\\xe2' in
> limit=100&offset=0
> >> [Thu Sep 08 10:55:00.872156 2016] [mpm_winnt:notice] [pid 512:tid 592]
> >> [Thu Sep 08 10:55:03.622159 2016] [mpm_winnt:notice] [pid 3380:tid 492]
> >> [Thu Sep 08 10:55:05.028413 2016] [mpm_winnt:notice] [pid 512:tid 592]
> >> AH00430: Parent: Child process 3380 exited successfully.
> >> [Thu Sep 08 10:55:07.856544 2016] [core:warn] [pid 6624:tid 592]
> AH00117:
> >> [Thu Sep 08 10:55:08.262793 2016] [wsgi:warn] [pid 6624:tid 592]
> >> [Thu Sep 08 10:55:08.262793 2016] [mpm_winnt:notice] [pid 6624:tid 592]
> >> [Thu Sep 08 10:55:08.262793 2016] [core:notice] [pid 6624:tid 592]
> >> [Thu Sep 08 10:55:08.278419 2016] [mpm_winnt:notice] [pid 6624:tid 592]
> >> AH00418: Parent: Created child process 4352
> >> [Thu Sep 08 10:55:08.997173 2016] [core:warn] [pid 4352:tid 492]
> AH00117:
> >> [Thu Sep 08 10:55:09.028421 2016] [core:warn] [pid 4352:tid 492]
> >> AH00117: Ignoring deprecated use of DefaultType in line 424 of
> >> [Thu Sep 08 10:55:09.090921 2016] [wsgi:warn] [pid 4352:tid 492]
> >> [Thu Sep 08 10:55:09.122173 2016] [mpm_winnt:notice] [pid 4352:tid 492]
> >> [Thu Sep 08 10:55:17.325312 2016] [wsgi:error] [pid 4352:tid 2592] Not
> >> [Thu Sep 08 10:56:06.997285 2016] [mpm_winnt:notice] [pid 6624:tid 592]
> >> [Thu Sep 08 10:56:11.731690 2016] [mpm_winnt:notice] [pid 4352:tid 492]
> >> [Thu Sep 08 10:56:11.887926 2016] [mpm_winnt:notice] [pid 6624:tid 592]
> >> AH00430: Parent: Child process 4352 exited successfully.
> >> [Thu Sep 08 10:56:13.294171 2016] [core:warn] [pid 2676:tid 592]
> AH00117:
> >> [Thu Sep 08 10:56:13.669175 2016] [wsgi:warn] [pid 2676:tid 592]
> >> [Thu Sep 08 10:56:13.669175 2016] [mpm_winnt:notice] [pid 2676:tid 592]
> >> [Thu Sep 08 10:56:13.669175 2016] [core:notice] [pid 2676:tid 592]
> >> AH00418: Parent: Created child process 5188
> >> [Thu Sep 08 10:56:14.075424 2016] [core:warn] [pid 5188:tid 492]
> >> [Thu Sep 08 10:56:14.091047 2016] [core:warn] [pid 5188:tid 492]
> >> [Thu Sep 08 10:56:14.137923 2016] [wsgi:warn] [pid 5188:tid 492]
> >> [Thu Sep 08 10:56:14.169173 2016] [mpm_winnt:notice] [pid 5188:tid 492]
> >> [Thu Sep 08 11:06:28.357881 2016] [mpm_winnt:notice] [pid 2676:tid 592]
> >> [Thu Sep 08 11:06:30.420438 2016] [mpm_winnt:notice] [pid 5188:tid 492]
> >> [Thu Sep 08 11:06:30.670385 2016] [mpm_winnt:notice] [pid 2676:tid 592]
> >> AH00430: Parent: Child process 5188 exited successfully.
> >> [Thu Sep 08 11:06:31.764139 2016] [core:warn] [pid 6988:tid 592]
> AH00117:
> >> [Thu Sep 08 11:06:31.795381 2016] [wsgi:warn] [pid 6988:tid 592]
> >> [Thu Sep 08 11:06:31.795381 2016] [mpm_winnt:notice] [pid 6988:tid 592]
> >> [Thu Sep 08 11:06:31.795381 2016] [core:notice] [pid 6988:tid 592]
> >> AH00418: Parent: Created child process 4600
> >> [Thu Sep 08 11:06:32.186008 2016] [core:warn] [pid 4600:tid 492]
> AH00117:
> >> [Thu Sep 08 11:06:32.201632 2016] [core:warn] [pid 4600:tid 492]
> AH00117:
> >> [Thu Sep 08 11:06:32.217258 2016] [wsgi:warn] [pid 4600:tid 492]
> >> [Thu Sep 08 11:06:32.248512 2016] [mpm_winnt:notice] [pid 4600:tid 492]
> >> [Thu Sep 08 11:06:34.264144 2016] [wsgi:error] [pid 4600:tid 2592]
> >> [client 172.16.1.176:50465] mod_wsgi (pid=4600): Exception occurred
> >> [client 172.16.1.176:50465] Traceback (most recent call last):,
> referer:
> >> [client 172.16.1.176:50465] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> __call__, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] self.load_middleware(), referer:
> >> load_middleware, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] for middleware_path in
> >> settings.MIDDLEWARE_CLASSES:, referer: http://aupegis03/maps/?limit=1
> >> 00&offset=0
> >> __getattr__, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] self._setup(name), referer:
> _setup,
> >> [client 172.16.1.176:50465] self._wrapped =
> >> Settings(settings_module), referer: http://aupegis03/maps/?limit=1
> >> 00&offset=0
> >> __init__, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] mod = importlib.import_module(self.
> SETTINGS_MODULE),
> >> import_module, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] __import__(name), referer:
> >> line 902, referer: http://aupegis03/maps/?limit=100&offset=0
> >> [client 172.16.1.176:50465] "name": "SATELLITE",, referer:
> >> [client 172.16.1.176:50465] ^, referer:
> >> [client 172.16.1.176:50465] SyntaxError: invalid syntax, referer:
> >> [Thu Sep 08 11:06:50.670425 2016] [mpm_winnt:notice] [pid 6988:tid 592]
> >> [Thu Sep 08 11:06:55.029802 2016] [mpm_winnt:notice] [pid 4600:tid 492]
> >> [Thu Sep 08 11:06:55.717303 2016] [mpm_winnt:notice] [pid 6988:tid 592]
> >> AH00430: Parent: Child process 4600 exited successfully.
> >> [Thu Sep 08 11:06:57.967308 2016] [core:warn] [pid 6136:tid 592]
> AH00117:
> >> [Thu Sep 08 11:06:58.920435 2016] [wsgi:warn] [pid 6136:tid 592]
> >> [Thu Sep 08 11:06:58.920435 2016] [mpm_winnt:notice] [pid 6136:tid 592]
> >> [Thu Sep 08 11:06:58.920435 2016] [core:notice] [pid 6136:tid 592]
> >> AH00418: Parent: Created child process 7508
> >> [Thu Sep 08 11:06:59.514184 2016] [core:warn] [pid 7508:tid 492]
> AH00117:
> >> [Thu Sep 08 11:06:59.529809 2016] [core:warn] [pid 7508:tid 492]
> AH00117:
> >> [Thu Sep 08 11:06:59.748565 2016] [wsgi:warn] [pid 7508:tid 492]
> >> [Thu Sep 08 11:06:59.764196 2016] [mpm_winnt:notice] [pid 7508:tid 492]
> >> [client 172.16.1.176:50471] mod_wsgi (pid=7508): Exception occurred
> >> [client 172.16.1.176:50471] Traceback (most recent call last):,
> referer:
> >> [client 172.16.1.176:50471] File "C:\\GeoNode-2.4.x\\geonode-2.
> >> [client 172.16.1.176:50471] self.load_middleware(), referer:
> >> [client 172.16.1.176:50471] for middleware_path in
> >> 00&offset=0
> >> [client 172.16.1.176:50471] self._setup(name), referer:
> _setup,
> >> [client 172.16.1.176:50471] self._wrapped =
> >> 00&offset=0
> >> [client 172.16.1.176:50471] mod = importlib.import_module(self.
> SETTINGS_MODULE),
> >> [client 172.16.1.176:50471] __import__(name), referer:
> >> [client 172.16.1.176:50471] "name": "SATELLITE",, referer:
> >> [client 172.16.1.176:50471] ^, referer:
> >> [client 172.16.1.176:50471] SyntaxError: invalid syntax, referer:
> >> [Thu Sep 08 11:07:27.514239 2016] [mpm_winnt:notice] [pid 6136:tid 592]
> >> [Thu Sep 08 11:07:37.123649 2016] [mpm_winnt:notice] [pid 7508:tid 492]
> >> [Thu Sep 08 11:07:37.154933 2016] [mpm_winnt:notice] [pid 6136:tid 592]
> >> AH00430: Parent: Child process 7508 exited successfully.
> >> [Thu Sep 08 11:07:38.951761 2016] [core:warn] [pid 5332:tid 592]
> AH00117:
> >> [Thu Sep 08 11:07:39.373642 2016] [wsgi:warn] [pid 5332:tid 592]
> >> [Thu Sep 08 11:07:39.373642 2016] [mpm_winnt:notice] [pid 5332:tid 592]
> >> [Thu Sep 08 11:07:39.373642 2016] [core:notice] [pid 5332:tid 592]
> >> AH00418: Parent: Created child process 8172
> >> [Thu Sep 08 11:07:40.154890 2016] [core:warn] [pid 8172:tid 492]
> AH00117:
> >> [Thu Sep 08 11:07:40.170516 2016] [core:warn] [pid 8172:tid 492]
> AH00117:
> >> [Thu Sep 08 11:07:40.404889 2016] [wsgi:warn] [pid 8172:tid 492]
> >> [Thu Sep 08 11:07:40.436140 2016] [mpm_winnt:notice] [pid 8172:tid 492]
> >> [Thu Sep 08 12:38:31.649965 2016] [wsgi:error] [pid 8172:tid 2584]
> >> Internal Server Error: /services/register/
> File
> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\
> >> line 112, in get_response
> >> response = wrapped_callback(request, *callback_args, **callback_kwargs)
> File
> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\lib\\site-packages\\djang
> >> o\\contrib\\auth\\decorators.py", line 22, in _wrapped_view
> >> return view_func(request, *args, **kwargs)
> File
> >> "C:\\GeoNode-2.4.x\\geonode-2.4.x\\geonode\\services\\views.py", line
> >> 110, in register_service
> >> type, server = _verify_service_type(url)
> File
> >> 239, in _verify_service_type
> >> service.services
> File
> arcrest\\server.py",
> >> line 480, in services
> in
> >> self._json_struct.get('services', [])]
> File
> >> line 266, in _json_struct
> if
> >> self._contents is not Ellipsis:
> File
> >> line 243, in _contents
> >> handle = compat.urllib2.urlopen(request)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 154, in urlopen
> >> return opener.open(url, data, timeout)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 431, in open
> >> response = self._open(req, data)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 449, in _open
> >> '_open', req)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 409, in
> _call_chain
> >> result = func(*args)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1227, in http_open
> >> return self.do_open(httplib.HTTPConnection, req)
> File
> >> "C:\\GeoNode-2.4.x\\Python27\\Lib\\urllib2.py", line 1197, in do_open
> >> raise URLError(err)
> because
> respond>
> >> [Thu Sep 08 15:15:38.308994 2016] [wsgi:error] [pid 8172:tid 2576]
> >> Internal Server Error: /maps/58/thumbnail
> File
> >> line 105, in get_response
> >> response = middleware_method(request, callback, callback_args,
> >> callback_kwargs)
> File
> django\\middleware\\csrf.py",
> >> line 170, in process_view
> >> request_csrf_token = request.POST.get('csrfmiddlewaretoken', '')
> File
> >> line 146, in _get_post
> >> self._load_post_and_files()
> File
> django\\http\\request.py",
> >> line 227, in _load_post_and_files
> >> self._post, self._files = QueryDict(self.body,
encoding=self._encoding),
> >> MultiValueDict()
> File
> >> line 190, in body
> >> six.reraise(UnreadablePostError, UnreadablePostError(*e.args),
> >> sys.exc_info()[2])
> File
> >> line 188, in body
> >> self._body = self.read()
> File
> >> line 244, in read
> >> sys.exc_info()[2])
> File
> >> line 242, in read
> >> return self._stream.read(*args, **kwargs)
> File
> >> line 45, in read
> >> result = self.buffer + self._read_limited()
> File
> >> line 39, in _read_limited
> >> result = self.stream.read(size)
> >> UnreadablePostError: Apache/mod_wsgi request data read error: Partial
> >> results are valid but processing is incomplete.
> >> *Chris Franklin*
> >> GIS and Database Co-ordinator
> >> Exploration Australia
> >> <image001.jpg>
> >> Tel: +61 08 9425 4719
> >> Fax: +61 08 9425 4650
> >> Email: cfranklin at anglogoldashanti.com
> >> Consider the environment. Think before you print.
> >> *From:* alessio.fabiani at gmail.com [mailto:alessio.fabiani at gmail.com
<alessio.fabiani at gmail.com>]
> *On
> >> Behalf Of *Alessio Fabiani
> >> *Sent:* Thursday, 8 September 2016 3:47 PM
> >> *To:* Franklin, Chris
> >> *Cc:* Jeffrey Johnson; geonode-users at lists.osgeo.org
> >> *Subject:* Re: [GeoNode-users] LDAP on windows
> >> Do you see some specific line on the geonode-2.4.x/apache/logs/
> error.log
> >> or other log files?
> >> Best Regards,
> >> Alessio Fabiani.
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Italy
messaggio,
messaggio
> stesso,
ai
> >> for the attention and use of the named addressee(s) and may be
> confidential
> >> or proprietary in nature or covered by the provisions of privacy act
> reproduction,
> partial, is
> or
changes
> >> On Thu, Sep 8, 2016 at 4:39 AM, Franklin, Chris <
> >> Ok, im getting closer:
> >> I set the virtualenv first – ran
> >> <image006.png>
> >> Then ran :
> >> <image009.png>
> >> Added:
> >> *#LDAP*
> >> *import ldap*
> >> *from django_auth_ldap.config import LDAPSearch*
> >> *AUTHENTICATION_BACKENDS = (*
> >> * 'django_auth_ldap.backend.LDAPBackend',*
> >> * 'django.contrib.auth.backends.ModelBackend',*
> >> * 'guardian.backends.ObjectPermissionBackend',*
> >> *AUTH_LDAP_SERVER_URI = ‘ldap://ag.ad.local' *
> >> *LDAP_SEARCH_DN = 'OU=AUSTRALIA,OU=AUSTRALASIA,DC=ag,DC=ad,DC=local' *
> >> *AUTH_LDAP_USER = '(uid=%(user)s)'*
> >> *AUTH_LDAP_BIND_DN = '{ADD_BIND_DN_IF_REQUIRED}'*
> >> *AUTH_LDAP_BIND_PASSWORD = '{ADD_BIND_PASSWORD_IF_REQUIRED}'*
> >> *AUTH_LDAP_USER_ATTR_MAP = {*
> >> * 'first_name': 'givenName', 'last_name': 'sn', 'email': 'mail',*
> >> *AUTH_LDAP_USER_SEARCH = LDAPSearch(LDAP_SEARCH_DN,*
> >> * ldap.SCOPE_SUBTREE,
AUTH_LDAP_USER)*
> >> to my local_settings.py file like so:
> >> <image010.png>
> >> Restarted Apache but Geonode had a 500 error – what did I do wrong?
> >> Thanks
> >> *Chris Franklin*
> >> <image011.jpg>
> *On
> >> *Sent:* Wednesday, 7 September 2016 4:18 PM
> >> *To:* Jeffrey Johnson
> >> *Cc:* Franklin, Chris; geonode-users at lists.osgeo.org
> >> Jeffrey is right, you need to use pip, but first of all you need to:
> >> 1. go to the windows prompt
> >> 2. go to the geonode installation folder
> >> 3. activate the virtual env with the batch command :
> >> cd C:\GeoNode-2.4.x\geonode-2.4.x
> >> python_env.bat
> >> Scripts\activate.bat
> >> Regards,
> >> -A.
> >> Best Regards,
> >> Alessio Fabiani.
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Italy
messaggio,
messaggio
> stesso,
ai
> confidential
> reproduction,
> partial, is
> or
changes
> >> On Tue, Sep 6, 2016 at 6:42 PM, Jeffrey Johnson <ortelius at gmail.com>
> >> wrote:
> >> Chris, you need to use pip. Im not sure how the virtualenvironment is
> >> setup. Alessio, can you give us some insight here?
> >> https://pip.pypa.io/en/stable/user_guide/#installing-from-wheels (on
> >> windows you need to use the command prompt)
> >> On Mon, Sep 5, 2016 at 9:19 PM, Franklin, Chris <
> >> Thanks dan,
> >> Have been trying to see how I can install the .whl file but can’t find
> >> any info on it, can someone out there help?
> >> Regards
> >> *Chris Franklin*
> >> <image012.jpg>
> >> Mob: +61 04 4818 2351
> >> *From:* Daniel Berry [mailto:dberry at boundlessgeo.com
<dberry at boundlessgeo.com>]
> >> *Sent:* Wednesday, 31 August 2016 8:29 PM
> >> *To:* Franklin, Chris <CFranklin at AngloGoldAshanti.com
<CFranklin at anglogoldashanti.com>>
> >> *Cc:* Jeffrey Johnson <ortelius at gmail.com>;
> >> Chris,
> >> It looks like for windows you could use one of these wheel files to
> >> install python-ldap. Just match the wheel to your OS.
> >> http://www.lfd.uci.edu/~gohlke/pythonlibs/#python-ldap
> >> These have already been pre built and include the `.pyd` file, which is
> a
> >> `.dll` file - https://docs.python.org/3/faq/windows.html#is-a-pyd-file-
> >> the-same-as-a-dll. This should alleviate you having to install devel
> >> libs and compile the source from pypi using pip.
> >> Good luck!
> >> Dan
> >> On Wed, Aug 31, 2016 at 1:57 AM, Franklin, Chris <
> >> Ok I added this to my local setting file :
> >> import ldap
> >> ldap.SCOPE_SUBTREE, AUTH_LDAP_USER)
> >> But was unsure on installing the ldap devel lib – who do I do that on
> >> windows?
> >> http://docs.geonode.org/en/master/tutorials/admin/ldap/
> >> Cheers
> >> *Chris Franklin*
> >> <image013.jpg>
> >> *From:* Jeffrey Johnson [mailto:ortelius at gmail.com <ortelius at gmail.com>
> >> *Sent:* Thursday, 25 August 2016 2:24 PM
> >> *Cc:* geonode-users at lists.osgeo.org
> >> I dont think there should be any difference in how it works on windows.
> >> Let us know how it goes.
> >> On Thu, Aug 25, 2016 at 6:45 AM, Franklin, Chris <
> >> Hi,
> >> Im looking to link my Geonode 2.4 windows into the corp LDAP, is this
> >> possible in windows?
> >> http://docs.geonode.org/en/master/tutorials/admin/ldap/index.html
> >> Regards
> >> *Chris Franklin*
> >> <image012.jpg>
> >> This email, and its attachments, is subject to important warnings and
> >> disclaimers which are legally incorporated into this email in terms of
> >> Section 11(3) of the South African Electronic Communications and
> >> Transactions Act, 25 of 2002. The full text of the warnings and
> >> disclaimers, together with the company details and directors is
> available
> >> by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
> >> _______________________________________________
> available
> >> *Daniel Berry*
> >> Senior Software Engineer | Boundless
> >> 512-468-3946 (cell)
> >> @boundlessgeo
> available
> available
> available
available
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/geonode-users/
> attachments/20160908/c07fa5a7/attachment.html>
> Subject: Digest Footer
> End of geonode-users Digest, Vol 20, Issue 17
URL: <
http://lists.osgeo.org/pipermail/geonode-users/attachments/20160908/135bb64c/attachment.html
End of geonode-users Digest, Vol 20, Issue 18
disclaimers, together with the company details and directors is available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160918/031f3bf3/attachment-0001.html>
More information about the geonode-users
