[GeoNode-users] IntegrityError: duplicate key value violates unique constraint "base_hierarchicalkeyword_name_key"
Simone Dalmasso simone.dalmasso at gmail.com
Mon Sep 26 22:14:52 PDT 2016
Hi, this is likely to be a bug. Could you file it in the issue tracker?
https://github.com/GeoNode/geonode/issues.
thanks
2016-09-26 17:51 GMT+02:00 Gavin Reich <Gavin.Reich at michaelcarder.co.uk>:
> Hi all,
> I’m encountering an error related to Hierarchical Keywords when trying to
> add a layer to geonode using file_upload(). The h_keyword (“human health”)
> has already been added previously when adding another layer. I’m not sure
> if this is a bug in _HierarchicalTagManager.add()?
> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L276
> Any help would be appreciated
> Thanks
> Gavin
> >>> layer = file_upload(filename='/home/ec2-user/test/ospar_encounters_2012_01.shp',
> name='Encounters2012', user=ospar, abstract='encounters 2012 test',
> overwrite=True, metadata_uploaded_preserve=True)
> Traceback (most recent call last):
>   File "<console>", line 1, in <module>
>   File "/opt/python/run/venv/src/geonode/geonode/layers/utils.py", line
> 514, in file_upload
>     layer.keywords.add(*keywords)
>   File "/opt/python/run/venv/src/geonode/geonode/base/models.py", line
> 291, in add
>     tag_objs.add(HierarchicalKeyword.add_root(name=new_tag))
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/treebeard/mp_tree.py",
> line 593, in add_root
>     return MP_AddRootHandler(cls, **kwargs).process()
> line 295, in process
>     return last_root.add_sibling('sorted-sibling', **self.kwargs)
> line 982, in add_sibling
>     return MP_AddSiblingHandler(self, pos, **kwargs).process()
> line 420, in process
>     newobj.save()
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/taggit/models.py",
> line 86, in save
>     return super(TagBase, self).save(*args, **kwargs)
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/django/db/models/base.py",
> line 734, in save
>     force_update=force_update, update_fields=update_fields)
> line 762, in save_base
>     updated = self._save_table(raw, cls, force_insert, force_update,
> using, update_fields)
> line 846, in _save_table
>     result = self._do_insert(cls._base_manager, using, fields, update_pk,
> raw)
> line 885, in _do_insert
>     using=using, raw=raw)
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/django/db/models/manager.py",
> line 127, in manager_method
>     return getattr(self.get_queryset(), name)(*args, **kwargs)
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/django/db/models/query.py",
> line 920, in _insert
>     return query.get_compiler(using=using).execute_sql(return_id)
> django/db/models/sql/compiler.py", line 974, in execute_sql
>     cursor.execute(sql, params)
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/django/db/backends/utils.py",
> line 79, in execute
>     return super(CursorDebugWrapper, self).execute(sql, params)
> line 64, in execute
>     return self.cursor.execute(sql, params)
>   File "/opt/python/run/venv/local/lib/python2.7/site-packages/django/db/utils.py",
> line 98, in __exit__
>     six.reraise(dj_exc_type, dj_exc_value, traceback)
> line 64, in execute
> DETAIL:  Key (name)=(human health) already exists.
> The snippet of the xml metadata containing the keywords:
> <gmd:descriptiveKeywords>
> <gmd:MD_Keywords>
> <gmd:keyword>
> <gco:CharacterString>Human health and safety</gco:CharacterString>
> </gmd:keyword>
> <gmd:thesaurusName>
> <gmd:CI_Citation>
> <gmd:title>
> <gco:CharacterString>GEMET - INSPIRE themes, version
> 1.0</gco:CharacterString>
> </gmd:title>
> <gmd:date>
> <gmd:CI_Date>
> <gmd:date>
> <gco:Date>2010-01-13</gco:Date>
> </gmd:date>
> <gmd:dateType>
> <gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/
> PubliclyAvailableStandards/ISO_19139_Schemas/resources/
> Codelist/ML_gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">
> publication</gmd:CI_DateTypeCode>
> </gmd:dateType>
> </gmd:CI_Date>
> </gmd:date>
> </gmd:CI_Citation>
> </gmd:thesaurusName>
> </gmd:MD_Keywords>
> </gmd:descriptiveKeywords>
> <gmd:MD_Keywords>
> <gmd:keyword>
> <gco:CharacterString>human health</gco:CharacterString>
> </gmd:keyword>
> <gmd:thesaurusName>
> <gmd:CI_Citation>
> <gmd:title>
> <gco:CharacterString>GEMET - Themes, version 2.4</gco:CharacterString>
> </gmd:title>
> <gmd:date>
> <gmd:CI_Date>
> <gmd:date>
> </gmd:date>
> <gmd:dateType>
> </gmd:dateType>
> </gmd:CI_Date>
> </gmd:date>
> </gmd:CI_Citation>
> </gmd:MD_Keywords>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160927/664effce/attachment-0001.html>
More information about the geonode-users mailing list
