[GeoNode-users] Failure to connect to postgres store in geonode 2.5
admire
addloe at gmail.com
Thu Sep 29 02:54:54 PDT 2016
Hi
I have installed docker geonode 2.5 but I am however failing to create a
postgis store in geonode geoserver.
The containers are linked fine but when you exec into the container
looking at the /etc/hosts shows that no entry for the linked containers
is visible.
When I do a docker inspect on the geoserver container I can see the
containers are linked but I cannot publish a postgis store in geonode
geoserver
docker-compose -p gfdrr_oondra exec django django-admin.py migrate
account --noinput
File "/usr/local/bin/django-admin.py", line 5, in <module>
management.execute_from_command_line()
File
"/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
utility.execute()
File
line 346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
"/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
File
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
line 93, in handle
executor = MigrationExecutor(connection,
self.migration_progress_callback)
File
"/usr/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
line 19, in __init__
self.loader = MigrationLoader(self.connection)
File
"/usr/local/lib/python2.7/site-packages/django/db/migrations/loader.py",
line 47, in __init__
self.build_graph()
File
line 191, in build_graph
self.applied_migrations = recorder.applied_migrations()
File
"/usr/local/lib/python2.7/site-packages/django/db/migrations/recorder.py",
line 59, in applied_migrations
self.ensure_schema()
File
line 49, in ensure_schema
if self.Migration._meta.db_table in
self.connection.introspection.table_names(self.connection.cursor()):
File
"/usr/local/lib/python2.7/site-packages/django/db/backends/base/base.py",
line 162, in cursor
cursor = self.make_debug_cursor(self._cursor())
File
line 135, in _cursor
self.ensure_connection()
File
line 130, in ensure_connection
self.connect()
File "/usr/local/lib/python2.7/site-packages/django/db/utils.py",
line 98, in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
File
self.connect()
File
line 119, in connect
self.connection = self.get_new_connection(conn_params)
File
"/usr/local/lib/python2.7/site-packages/django/db/backends/postgresql_psycopg2/base.py",
line 176, in get_new_connection
connection = Database.connect(**conn_params)
File "/usr/local/lib/python2.7/site-packages/psycopg2/__init__.py",
line 164, in connect
conn = _connect(dsn, connection_factory=connection_factory,
async=async)
django.db.utils.OperationalError: FATAL: no pg_hba.conf entry for host
"172.19.0.7", user "postgres", database "postgres", SSL on
FATAL: no pg_hba.conf entry for host "172.19.0.7", user "postgres",
database "postgres", SSL off
Regards
More information about the geonode-users
