[GeoNode-users] Error on running geonode using docker
    Jeffrey Johnson
    ortelius at gmail.com
    Wed Jan  4 07:37:20 PST 2017
You need to execute `make sync` to run the migrations.
On Wed, Jan 4, 2017 at 6:49 AM, Sindile Bidla <
sindile.bidla at geoilocate.co.za> wrote:
> I am trying to run geonode via the docker on Ubuntu 16.04, but have been
> faced with the following error message:
> running docker ps -a
> CONTAINER ID        IMAGE                     COMMAND
> CREATED             STATUS                    PORTS
> NAMES
> 543b85dfd393        geonode/nginx:geoserver   "nginx -g 'daemon off"   22
> hours ago        Up 22 hours               0.0.0.0:80->80/tcp,
> 443/tcp          geonode_nginx_1
> 9a327ceeba10        geonode/django            "django-admin.py runs"   22
> hours ago        Up 22 hours               8000/tcp
> geonode_django_1
> d25966950b90        geonode/django            "celery worker --app="   22
> hours ago        Exited (0) 22 hours ago
> geonode_celery_1
> 1501d708bca9        geonode/geoserver         "/usr/local/tomcat/tm"   22
> hours ago        Up 22 hours               0.0.0.0:32769->8080/tcp
> geonode_geoserver_1
> 1978155ef4f4        rabbitmq                  "docker-entrypoint.sh"   22
> hours ago        Up 22 hours               4369/tcp, 5671-5672/tcp,
> 25672/tcp   geonode_rabbitmq_1
> 95324b25309d        postgres                  "/docker-entrypoint.s"   22
> hours ago        Up 22 hours               5432/tcp
> geonode_postgres_1
> 63b5746192f9        geonode/geoserver_data    "/bin/true"              22
> geoserver_data_dir
> b6567923df39        elasticsearch             "/docker-entrypoint.s"   22
> hours ago        Up 22 hours               9200/tcp,
> 9300/tcp                   geonode_elasticsearch_1
> geonode_celery_1 - Is this an expected behavior, if not what could I be
> doing wrong?
> Also going to http://localhost, I get the following error message:
> ProgrammingError at /
> relation "django_site" does not exist
> LINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
> Request Method: GET
> Request URL: http://localhost/
> Django Version: 1.8.7
> Exception Type: ProgrammingError
> Exception Value:
> Exception Location: /usr/local/lib/python2.7/site-
> packages/django/db/backends/utils.py in execute, line 64
> Python Executable: /usr/local/bin/python2
> Python Version: 2.7.9
> Python Path:
> ['/usr/local/bin',
>  '/usr/src/app',
>  '/usr/local/lib/python27.zip',
>  '/usr/local/lib/python2.7',
>  '/usr/local/lib/python2.7/plat-linux2',
>  '/usr/local/lib/python2.7/lib-tk',
>  '/usr/local/lib/python2.7/lib-old',
>  '/usr/local/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/site-packages',
>  '/usr/src/app']
> Server time: Wed, 4 Jan 2017 08:38:38 -0600
> I am able to access geoserver web interface though.
> Will greatly appreciate any pointers.
> Regards,
> Sindile
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170104/83ce5b6e/attachment.html>
More information about the geonode-users
