[GeoNode-users] Error on running geonode using docker
Sindile Bidla sindile.bidla at geoilocate.co.za
Wed Jan 4 08:29:20 PST 2017
Thanks, Francesco and Jeffrey.
Working now.
Regards,
Sindile
On 04/01/2017 17:59, Francesco Bartoli wrote:
> the command suggested has to be run outside containers in the same
> place where you execute the docker-compose up.
> Sent from Nylas N1
> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-4c316ce7-6d18/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=c2luZGlsZS5iaWRsYUBnZW9pbG9jYXRlLmNvLnph>,
> the extensible, open source mail client.
> On gen 4 2017, at 4:56 pm, Sindile Bidla
> <sindile.bidla at geoilocate.co.za> wrote:
>     Hi Jeffrey,
>     In which container must i execute `make sync`
>     I was using the following workflow as per the notes:
>     If you want to use Docker you can now:
>     # build the docker container
>     docker-compose build
>     # run the docker container
>     docker-compose up
>     # turn it off
>     docker-compose down
>     Regards,
>     Sindile
>     On 04/01/2017 17:37, Jeffrey Johnson wrote:
>>     You need to execute `make sync` to run the migrations.
>>     On Wed, Jan 4, 2017 at 6:49 AM, Sindile Bidla
>>     <mailto:sindile.bidla at geoilocate.co.za>> wrote:
>>         I am trying to run geonode via the docker on Ubuntu 16.04,
>>         but have been faced with the following error message:
>>         running docker ps -a
>>         CONTAINER ID        IMAGE COMMAND                  CREATED
>>         STATUS PORTS        NAMES
>>         543b85dfd393        geonode/nginx:geoserver "nginx -g 'daemon
>>         off"   22 hours ago        Up 22 hours
>>         0.0.0.0:80->80/tcp, 443/tcp          geonode_nginx_1
>>         9a327ceeba10        geonode/django "django-admin.py runs"
>>         22 hours ago        Up 22 hours               8000/tcp
>>         geonode_django_1
>>         d25966950b90        geonode/django "celery worker --app="
>>         22 hours ago Exited (0) 22 hours ago geonode_celery_1
>>         1501d708bca9        geonode/geoserver
>>         "/usr/local/tomcat/tm"   22 hours ago        Up 22 hours
>>         0.0.0.0:32769->8080/tcp geonode_geoserver_1
>>         1978155ef4f4        rabbitmq "docker-entrypoint.sh"   22
>>         hours ago        Up 22 hours               4369/tcp,
>>         5671-5672/tcp, 25672/tcp   geonode_rabbitmq_1
>>         95324b25309d        postgres "/docker-entrypoint.s"   22
>>         hours ago        Up 22 hours               5432/tcp
>>         geonode_postgres_1
>>         63b5746192f9        geonode/geoserver_data
>>         "/bin/true"              22 hours ago Exited (0) 22 hours ago
>>         geoserver_data_dir
>>         b6567923df39        elasticsearch "/docker-entrypoint.s"   22
>>         hours ago        Up 22 hours               9200/tcp,
>>         9300/tcp                   geonode_elasticsearch_1
>>         22 hours ago Exited (0) 22 hours ago geonode_celery_1 - Is
>>         this an expected behavior, if not what could I be doing wrong?
>>         Also going to http://localhost
>>         <http://localhost&r=c2luZGlsZS5iaWRsYUBnZW9pbG9jYXRlLmNvLnph>,
>>         I get the following error message:
>>           ProgrammingError at /
>>         relation "django_site" does not exist
>>         LINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>>         Request Method: 	GET
>>         Request URL: 	http://localhost/
>>         Django Version: 	1.8.7
>>         Exception Type: 	ProgrammingError
>>         Exception Value:
>>         Exception Location:
>>         /usr/local/lib/python2.7/site-packages/django/db/backends/utils.py
>>         in execute, line 64
>>         Python Executable: 	/usr/local/bin/python2
>>         Python Version: 	2.7.9
>>         Python Path:
>>         ['/usr/local/bin',
>>           '/usr/src/app',
>>           '/usr/local/lib/python27.zip',
>>           '/usr/local/lib/python2.7',
>>           '/usr/local/lib/python2.7/plat-linux2',
>>           '/usr/local/lib/python2.7/lib-tk',
>>           '/usr/local/lib/python2.7/lib-old',
>>           '/usr/local/lib/python2.7/lib-dynload',
>>           '/usr/local/lib/python2.7/site-packages',
>>           '/usr/src/app']
>>         Server time: 	Wed, 4 Jan 2017 08:38:38 -0600
>>         I am able to access geoserver web interface though.
>>         Will greatly appreciate any pointers.
>>         Regards,
>>         Sindile
>>         _______________________________________________ geonode-users
>>         mailing list geonode-users at lists.osgeo.org
>>         <mailto:geonode-users at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/geonode-users
>>         <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=c2luZGlsZS5iaWRsYUBnZW9pbG9jYXRlLmNvLnph>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170104/f3842cbb/attachment-0001.html>
More information about the geonode-users mailing list
