[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jan 4 22:41:24 PST 2017
The $ should not be there, is an identifier for pieces of code that would
be changed by the addsite script. It is a normal python path.
And yes, the SERVE_PATH should be in one of the project's settings as it is
used to locate your static and media files "STATIC_ROOT =
os.path.join(SERVE_PATH, 'static')"
2017-01-03 17:13 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> I presume maybe I'm not so far from finalization of the configuration.
> I apologize if I'm not enough smart, but I don't understand which file do
> you mentioned, starting with "$". I suppose you intended the line 19 in the
> wsgi.py located in the geosite folder (i.e. gemex for me), am I correct?
> If yes I changed the line in:
> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "$geosites.%s.settings" %
> curdir)
> since, as you know, I'm using a normal installation of geonode, so I have
> the geosites project forlder within:
> /geonode/geonode/contrib and my project folder name is the original
> geosites.
> Did I understand well?
> Regarding the static_root it is my intention to leave that folder in my
> site folder (/geonode/geonode/contrib/geosites/gemex/). In that case I
> should run your suggested command:
> python manage.py collectstatic --settings=geonode.contrib.
> geosites.gemex.settings
> and in gemex.settings has to be inserted the variable SERVE_PATH, am I
> correct?
> Thanks
> Eugenio
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* martedì 3 gennaio 2017 08.35
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> Eugenio is all more or less right.
> The error you have is because, since you copied the site_template folder
> manually, you also have to correctly adjust the variables in the files that
> start with "$". In this case you have to put the correct project name in
> the wsgi.py-
> For the static files, they can stay anywhere, but is suggested to have
> them in the web server folders /var/www etc,as said. To copy them there,
> once you have set the STATIC_ROOT folder in the geosite settings yu can use
> the normal geonode manage.py file by passing it the geosites settings
> instead:
> 2016-12-29 12:21 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone and all,
>> unfortunately I hadn't solved my problem multi-tenancy configuration.
>> My new questions are:
>> - can I set-up multi-geosites from my running normal installation? (I
>> installed geonode following this guide [1]) or should I install a geonode
>> from scratch?
>> - to run multi-geosites do you suggest me to setup multi-geosite from
>> special version of geonode as for instance [2], if yes How to start?
>> - in my geonode normal installation manage.py and manage_all.py are
>> missing in the /geonode/geonode/contrib/geosites/
>> - the master site has to be within contrib/geosites/master-site,
>> which relationship is there between the normal geonode site and the
>> master-site? in case master-site has to inherit from normal one-site
>> config, how?
>> - just to be sure is this the right order of the setting files read
>> by geonode:
>> - /geonode/geonode/local_setting.py and /geonode/geonode/setting.py
>> (overridden by the first)
>> - /geonode/geonode/contrib/geosites/pre_setting.py
>> - /geonode/geonode/contrib/geosites/local_setting.py
>> and /geonode/geonode/contrib/geositessetting.py (overridden by the
>> first)
>> - /geonode/geonode/contrib/geosites/post_setting.py
>> - in my test performed in the last days I set the: SERVE_PATH=
>> "/dati/geonode/geonode/contrib/geosites/ in
>> /geonode/geonode/local_setting.py is that right? in apache error log
>> I have:
>> [Thu Dec 29 11:46:21.129691 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] self.load_middleware()
>> [Thu Dec 29 11:46:21.129706 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] File "/usr/local/lib/python2.7/dist
>> -packages/django/core/handlers/base.py", line 44, in load_middleware
>> [Thu Dec 29 11:46:21.129728 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] for middleware_path in
>> settings.MIDDLEWARE_CLASSES:
>> [Thu Dec 29 11:46:21.129742 2016] [:error] [pid 14216] [remote
>> -packages/django/conf/__init__.py", line 54, in __getattr__
>> [Thu Dec 29 11:46:21.129763 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] self._setup(name)
>> [Thu Dec 29 11:46:21.129776 2016] [:error] [pid 14216] [remote
>> -packages/django/conf/__init__.py", line 49, in _setup
>> [Thu Dec 29 11:46:21.129797 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] self._wrapped = Settings(settings_module)
>> [Thu Dec 29 11:46:21.129810 2016] [:error] [pid 14216] [remote
>> -packages/django/conf/__init__.py", line 132, in __init__
>> [Thu Dec 29 11:46:21.129831 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] % (self.SETTINGS_MODULE, e)
>> [Thu Dec 29 11:46:21.129851 2016] [:error] [pid 14216] [remote
>> 93.32.72.156:62917] ImportError: Could not import settings
>> '$PROJECT_NAME.gemex.settings' (Is it on sys.path? Is there an import error
>> in the settings file?): No module named $PROJECT_NAME.gemex.settings
>> the error at last line it is seems to be related to something missing....
>> - last but not least I still have doubt on the positioning of
>> static_root folder for each geosites, I would maintain them within each
>> geosite folder but I don't know how to run collectstatic to populate that
>> folder.
>> Thanks for any hint...
>> Eugenio
>> [1] http://docs.geonode.org/en/latest/tutorials/install_and_admi
>> n/geonode_install/index.html
>> [2]
>> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html>
>> https://github.com/terranodo/geosites-project
>> <https://github.com/terranodo/geosites-project>
>> github.com
>> geosites-project - A skeleton project for creating a multi-tenancy
>> GeoNode using the GeoSites contrib app.
>> *Inviato:* mercoledì 21 dicembre 2016 10.37
>> *A:* Eugenio Trumpy
>> ok:
>> - I this that that Alias is a mistake, the way is configured is that any
>> url /gemex will internally point to /dati but I don't think they are
>> actually urls. You can remove it
>> - you can assign a new name to WSGIProcessGroup
>> - it ok to keep the dir in the root base of geonode since your site is
>> inside
>> - the geonode apt package creates the uploaded and static root under
>> var/www as far as I know. It is ok to reuse the same settings. If not I
>> suggest you to put them there as they are meant to be served by apache.
>> - you can use the same config for the Daemon, just use the name you gave
>> to the WSGIProcessGroup instead of geonode
>> This is a brief explanation but you can find more on the static url and
>> roots on the django docs and more on the wsgi config on the apache docs
>> hope this helps.
>> 2016-12-20 9:36 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Simone and all,
>>> thanks again for your inputs.
>>> However, I think I'm at a crucial position to finalize the configuration
>>> of the first new geosite (named gemex).
>>> Just to clarify all the step performed and to focus the stage where I'm
>>> now, I list here below what I did and what I miss:
>>> 1. in setting.py I added under INSTALLED_APPS the line
>>> 'geonode.contrib.geosites'
>>> 2. I run python manage.py syncdb
>>> 3. I copy site-template (i.e. the folder inside contrib/geosites/)
>>> in the same position (i.e. contrib/geosites/) with a new name (e.g. gemex
>>> in my case)
>>> 4. I created a 4 level doman to be linked to the new site (i.e.
>>> gemex.igg.cnr.it in my case)
>>> 5. I added a new site from the admin panel available from a normal
>>> running installation
>>> 6. I create a new virtual host (for apache2) by copy the virtual
>>> host I had for the normal running installation. Here what is clear to me
>>> are the items:
>>> - ServerName = where I put the created 4 level domain
>>> - WSGIScriptAlias where I put the link to the wsgi.py available
>>> within the created newsite (i.e. path to contrib/geosites/gemex/wsgi.py
>>> - ProxyPass and ProxyPassReverse linked to the local geoserver
>>> What is not yet clear:
>>> from your last email I understand that the new site can be where I
>>> prefer. I would say that for now I can leave it inside contrib/geosites, if
>>> I can of course.
>>> Then I have doubts to setup these lines:
>>> - In the normal config I have Alias /geonode /dati/geonode/geonode
>>> but I think I should change to link it to my new site, is it right?
>>> - In WSGIProcessGroup the normal config has geonode, for my new site
>>> do I need to change it?
>>> - Regarding the directive Directory I had <Directory
>>> "/dati/geonode/geonode/"> for the normal config, here should I insert the
>>> path to my new site?
>>> - Regarding /uploaded/ and /static/ Aliases, I understood from your
>>> email I can put those directory where I prefer. Now another trivial
>>> question: /uploaded/ and /static/ folder have to be different from those
>>> created for the normal installation? if no, then it is easy both configure
>>> the virtual host and run collectstatic. If yes, it is not clear how to run
>>> collectstatic for the new site. That's why the command python manage.py
>>> collectstatic works only within geonode folder and fill in the normal
>>> static_root folder. Could you clarify this point?
>>> - Last but not least the line WSGIDaemonProcess is not clear,
>>> because running: service apache reload I had an error: Name
>>> duplicates previous WSGI daemon definition (that's why apache find the
>>> virtualhost I have for the normal installation. The normal installation
>>> has: WSGIDaemonProcess geonode python-path=/dati/geonode/:/da
>>> ti/.venvs/geonode/lib/python2.7/site-packages user=eugenio
>>> threads=15 processes=2 How should sort out this line for the new site?
>>> I offer myself to prepare an how to for dummies to be included as
>>> documentation in git, if I will be able to configure geosites.
>>> Thanks for any clarification
>>> Eugenio
>>> *Inviato:* lunedì 19 dicembre 2016 18.33
>>> *A:* Eugenio Trumpy
>>> I mean the whole gemex folder can be outside. For the static roots they
>>> can be anywhere and is not recommended to have them inside but rather in
>>> /var/www as they need to be served by the web server at some point.
>>> 2016-12-19 16:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Ok, once I run syncdb I 'm able to register new site! first step!!!!
>>>> Coming back to the first issue, I'm not sure to have understood well,
>>>> do you mean the dir thumb, layers, static_root can stay ouside my newsite
>>>> directory?
>>>> That means I cannot run collectstatic if those dirs are inside my site
>>>> dir?
>>>> Actually in the docs I read I saw that the static folder is inside the
>>>> new sites.
>>>> This part is not so clear to me....
>>>> E.
>>>> *Inviato:* lunedì 19 dicembre 2016 16.22
>>>> *A:* Eugenio Trumpy
>>>> It is a good practice to not install the new sites folders into the
>>>> root of the code. They can live outside without problems.
>>>> The second issue is that you did not run python manage.py syncdb or
>>>> migrate to install the tables that come with geosites.
>>>> 2016-12-19 15:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Sorry for these multiple emails,
>>>>> I following your suggestion to create the site by hand I proceeded to
>>>>> register the new site by using the admin console as you suggested.
>>>>> On save action I had this error message:
>>>>> http://pastebin.com/SskX1QNB
>>>>> It seems geonode.contrib.geosites is not installed yet, right?
>>>>> E.
>>>>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>>>>> *Inviato:* lunedì 19 dicembre 2016 15.37
>>>>> *A:* Simone Dalmasso
>>>>> Ok,
>>>>> this is my new virtualhost prepared for the new site named 'gemex':
>>>>> <VirtualHost *:80>
>>>>> ServerName http://gemex.igg.cnr.it
>>>>> ServerAdmin webmaster at localhost
>>>>> DocumentRoot /var/www/html
>>>>> Options -Indexes +FollowSymLinks
>>>>> Alias /gemex "/dati/geonode/geonode/contrib/geosites"
>>>>> WSGIDaemonProcess gemex python-path=/dati/geonode/geon
>>>>> ode/contrib/geosites:/dati/.venvs/geonode/lib/python2.7/site-packages
>>>>> user=eugenio threads=15 processes=2
>>>>> ErrorLog /var/log/apache2/error.log
>>>>> LogLevel warn
>>>>> CustomLog /var/log/apache2/access.log combined
>>>>> WSGIProcessGroup gemex
>>>>> WSGIPassAuthorization On
>>>>> WSGIScriptAlias / /dati/geonode/geonode/contrib/
>>>>> <Directory "/dati/geonode/geonode/contrib/geosites/gemex">
>>>>> Options Indexes FollowSymLinks
>>>>> Require all granted
>>>>> IndexOptions FancyIndexing
>>>>> </Directory>
>>>>> Alias /uploaded/ /dati/geonode/geonode/contrib/
>>>>> geosites/gemex/uploaded/
>>>>> Alias /static/ /dati/geonode/geonode/contrib/
>>>>> geosites/gemex/static_root/
>>>>> ProxyPreserveHost On
>>>>> ProxyPass /geoserver http://localhost:8080/geoserver
>>>>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>> ProxyPass /geoserver2 http://localhost:8080/geoserver2
>>>>> ProxyPassReverse /geoserver2 http://localhost:8080/geoserver2
>>>>> </VirtualHost>
>>>>> My concerns are:
>>>>> - WSGIDeamon line, is that correct?
>>>>> - the first Alias, is that correct too?
>>>>> - Eventually the Directory is right?
>>>>> Moreover, I followed again this page for the http setup:
>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>> n/geonode_install/setup_configure_httpd.html
>>>>> I think now should be rready for the collecstatic command, but I don't
>>>>> know how to run it in in the new static_root inside my site gemex.
>>>>> Any hints?
>>>>> E.
>>>>> Setup & Configure HTTPD — GeoNode 2.4 documentation
>>>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html>
>>>>> docs.geonode.org
>>>>> Setup & Configure HTTPD¶ In this section we are going to setup Apache
>>>>> HTTP to serve GeoNode.
>>>>> *Inviato:* lunedì 19 dicembre 2016 15.03
>>>>> *A:* Eugenio Trumpy
>>>>> Exactly, one virtualhost for each site.
>>>>> 2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>> Ok,
>>>>>> I will proceed this way.
>>>>>> Then I have to create a new virtualhost pointing to the wsgi.py
>>>>>> within the new site dir, right?
>>>>>> In the same virtual host have I to set new aliases for uploaded dir
>>>>>> and static_root as I did for the normal installation?
>>>>>> E.
>>>>>> *Inviato:* lunedì 19 dicembre 2016 14.21
>>>>>> *A:* Eugenio Trumpy
>>>>>> I suggest you to go manually and create a site folder copying the
>>>>>> site_template, rename and add the Site object into the database.
>>>>>> geosites has not been revised for a while and geonode improved. It
>>>>>> works but the shortcut command addsite may be broken.
>>>>>> 2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>> Hi Simone,
>>>>>>> I did what you suggested, actually now I have the addsite command,
>>>>>>> but as you announced I have also this error:
>>>>>>> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
>>>>>>> then I added SITE_ROOT in local_setting.py inserting the path
>>>>>>> "geonode/contrib/geosites"
>>>>>>> afterwords I had this error:
>>>>>>> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
>>>>>>> so that I added SERVE_PATH in local_setting.py inserting the path "
>>>>>>> geonode/contrib/geosites/static"
>>>>>>> but I'm not sure I did the right thing, since now I have this error:
>>>>>>> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib
>>>>>>> /site2'
>>>>>>> Where I'm wrong?
>>>>>>> Thanks
>>>>>>> Eugenio
>>>>>>> *Inviato:* lunedì 19 dicembre 2016 11.04
>>>>>>> *A:* Eugenio Trumpy
>>>>>>> you have to add it in INSTALLED_APPS, currently it is only listed in
>>>>>>> the contrib apps.
>>>>>>> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>>> Hi Simone,
>>>>>>>> and thank you for your answer.
>>>>>>>> Sorry for my trivial question:
>>>>>>>> in my setting.py I have already geonode.contrib.geosites
>>>>>>>> in GEONODE_CONTRIB_APPS, see below:
>>>>>>>> GEONODE_CONTRIB_APPS = (
>>>>>>>> # GeoNode Contrib Apps
>>>>>>>> 'geonode.contrib.dynamic',
>>>>>>>> 'geonode.contrib.exif',
>>>>>>>> 'geonode.contrib.favorite',
>>>>>>>> 'geonode.contrib.geogig',
>>>>>>>> 'geonode.contrib.geosites',
>>>>>>>> 'geonode.contrib.nlp',
>>>>>>>> 'geonode.contrib.slack'
>>>>>>>> in INSTALLED_APPS I have:
>>>>>>>> INSTALLED_APPS = (
>>>>>>>> # Boostrap admin theme
>>>>>>>> # 'django_admin_bootstrapped.bootstrap3',
>>>>>>>> # 'django_admin_bootstrapped',
>>>>>>>> # Apps bundled with Django
>>>>>>>> 'django.contrib.auth',
>>>>>>>> 'django.contrib.contenttypes',
>>>>>>>> 'django.contrib.sessions',
>>>>>>>> 'django.contrib.sites',
>>>>>>>> 'django.contrib.admin',
>>>>>>>> 'django.contrib.sitemaps',
>>>>>>>> 'django.contrib.staticfiles',
>>>>>>>> 'django.contrib.messages',
>>>>>>>> 'django.contrib.humanize',
>>>>>>>> 'django.contrib.gis',
>>>>>>>> # Third party apps
>>>>>>>> # Utility
>>>>>>>> 'pagination',
>>>>>>>> 'taggit',
>>>>>>>> 'friendlytagloader',
>>>>>>>> 'geoexplorer',
>>>>>>>> 'leaflet',
>>>>>>>> 'django_extensions',
>>>>>>>> # 'haystack',
>>>>>>>> ....and others...
>>>>>>>> Should I insert geonode.contrib.geosites somewhere in
>>>>>>>> local_setting? or it's already ok as it? or copy geonode.contrib.geosites
>>>>>>>> in settings.py under INSTALLED_APPS?
>>>>>>>> Sorry again for this banal question...
>>>>>>>> E.
>>>>>>>> *Inviato:* lunedì 19 dicembre 2016 09.04
>>>>>>>> *A:* Eugenio Trumpy
>>>>>>>> Ciao Eugenio,
>>>>>>>> sorry for being so late in the response.
>>>>>>>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS
>>>>>>>> in order to get the command.
>>>>>>>> In case you get errors in running that command, you can always
>>>>>>>> 'make' a geosite by yourself by copying the folder 'site_template' and
>>>>>>>> changing it's name and internal parameters and then register the new Site
>>>>>>>> in the admin panel. You can follow the utils.py add_site function and
>>>>>>>> replicate the needed steps (some of them are only for production).
>>>>>>>> Take also some time to see how the pre and post settings work.
>>>>>>>> Hope this helps
>>>>>>>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>>>> Hi everyone,
>>>>>>>>> regarding the multi-tenancy setting up and in particular the
>>>>>>>>> installation of new site since the command:
>>>>>>>>> python manage.py addsite sitename sitedomain
>>>>>>>>> return me:
>>>>>>>>> Unknown command: 'addsite'
>>>>>>>>> Type 'manage.py help' for usage.
>>>>>>>>> Do you know way? Have I 'activate' in some way the multi-tenancy
>>>>>>>>> before? or it is ready to use?
>>>>>>>>> If it is ready to use, why 'addsite' is an unknown command?
>>>>>>>>> I launched the command from the main geonode directory, am I right?
>>>>>>>>> As I wrote in the previous email in my installation I have only
>>>>>>>>> manage.py file in
>>>>>>>>> /geonode directory.
>>>>>>>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>>>>>>>> 2.4.dev20151029170512.
>>>>>>>>> I installed geonode as custom installation (not by apt-get).
>>>>>>>>> Thanks
>>>>>>>>> Eugenio
>>>>>>>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>>>>>>>> *A:* geonode-users at lists.osgeo.org
>>>>>>>>> *Oggetto:* Multi-Tenancy: how to start
>>>>>>>>> Hi all,
>>>>>>>>> as pointed in the email object I want to try the
>>>>>>>>> geonode multi-tenancy capabilities.
>>>>>>>>> I started of course from the documentation [1] and [2], but a need
>>>>>>>>> some hints to start.
>>>>>>>>> I have already a running geonode instance. Do you think I should
>>>>>>>>> start from
>>>>>>>>> a clean geonode installation or I can arrange the running one?
>>>>>>>>> Is there somewhere a set of commands to setup the geosite 1,
>>>>>>>>> geosite 2, ...
>>>>>>>>> I was looking into geosites folder, as suggested in [2], but I
>>>>>>>>> don't see neither manage.py nor manage_all.py files.
>>>>>>>>> I tried python manage.py addsite geosite1 geosite1domain
>>>>>>>>> but I got Unknown command: 'addsite'
>>>>>>>>> Am I missing something?
>>>>>>>>> After that: How can I sort out the already stored layers?
>>>>>>>>> Thank you very much for hints and for the patience of this
>>>>>>>>> stupid questions,
>>>>>>>>> Eugenio
>>>>>>>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>>>>>>>> lti-tenancy.html
>>>>>>>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>>>>>>>> ontrib/geosites
>>>>>>>> Simone
>>>>>>> Simone
>>>>>> Simone
>>>>> Simone
>>>> Simone
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170105/36e6edea/attachment-0001.html>
More information about the geonode-users
