[GeoNode-users] apt-get geonode 2.5.4
Finnegan Pope-Carter f.pope-carter at magnitudesurveys.co.uk
Thu Jan 5 06:07:45 PST 2017
Hi, I’m running into an error when trying to install geonode 2.5.4 on a fresh copy of Ubuntu 16.04. I’ve added the ppa:geonode/testing repository and run apt-get update but when I try to install geonode I get the following error:
@geonode2:~$ sudo apt-get install geonode
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
geonode : Depends: geoserver-geonode but it is not installable or
                    geoserver but it is not installable
           Depends: postgresql-9.1-postgis but it is not installable or
                    postgresql-9.3-postgis-2.1 but it is not installable
           Depends: python-geonode-agon-ratings but it is not installable
           Depends: python-dialogos but it is not installable
           Depends: python-django-geoexplorer but it is not installable
           Depends: python-geonode-notification but it is not installable
           Depends: python-django-taggit-templatetags but it is not installable
           Depends: python-geonode-user-accounts but it is not installable
           Depends: python-geonode-avatar but it is not installable
           Depends: python-gsconfig but it is not installable
           Depends: python-geonode-announcements but it is not installable
           Depends: python-pinax-theme-bootstrap but it is not going to be installed
           Depends: python-tastypie but it is not installable
           Depends: python-django-modeltranslation but it is not installable
           Depends: python-gsimporter but it is not installable
           Depends: python-geonode-arcrest but it is not installable
           Recommends: python-gisdata but it is not installable
           Recommends: transifex-client but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Can anyone tell me what I’m doing wrong?
Kind regards
Finn
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170105/820ab30f/attachment.html>
More information about the geonode-users mailing list
