[GeoNode-users] installing geonode 2.5.6
Dave Kennewell
davekennewell at gmail.com
Fri Jan 6 01:32:28 PST 2017
Update - I realised there is no need to run the ansible program itself from
Xenial (I don't think)- I've recovered from my brain-fart and installed
ansible 1.9.6 (easily using pip!) on ubuntu 14.04. However, still getting
same errors as described below.
On 6 January 2017 at 11:57, Dave Kennewell <davekennewell at gmail.com> wrote:
> Hi Angelos,
> I installed ansible 1.9.4 on Xenial. It wasn't trivial, so I'll share my
> notes here for others:
> First I tried this:
> $ sudo apt-get install software-properties-common
> $ sudo apt-add-repository ppa:ansible/ansible-1.9
> $ sudo apt-get update
> $ sudo apt-get install ansible
> This installed version 2.0.0.2 (... go figure). I ran the latest
> geonode-ansible play anyway (even though it wasn't an ansible version
> 1.9.x), and got an error at
> https://github.com/GeoNode/ansible-geonode/blob/master/
> tasks/geoserver.yml#L57
> Not sure if this is to do with the latest commit (last night it seems) or
> if it's still to do with the ansible 2.0.x install... but we don't want to
> use 2.0.x anyway, so I didn't look into it too much.
> So I tried again to install 1.9.x, this time using pip.
> sudo apt-get install python-pip
> sudo pip install --upgrade pip
> sudo pip install ansible==1.9.6
> This throws an error to do with a crypt something something package (sorry
> I didn't copy the message). I'm guessing the dependencies aren't right for
> xenial. So I tried again to install 1.9.4 using deb packages (roughly based
> on https://github.com/ansible/ansible/issues/13898):
> # Make sure we are up to date
> sudo apt-get update
> # Download working ansible deb package
> wget https://launchpad.net/~ansible/+archive/ubuntu/ansible-1.9/+files/ansible_1.9.4-1ppa~trusty_all.deb -O /tmp/ansible.deb
> # Manually install deps
> sudo apt-get install -y \
> python-jinja2 \
> python-yaml \
> python-paramiko \
> python-httplib2 \
> python-crypto sshpass
> # python-support is required too, but doesn't install from apt on xenial, so use (http://askubuntu.com/questions/766169/why-no-more-python-support-in-16-04):
> wget http://launchpadlibrarian.net/109052632/python-support_1.0.15_all.deb -O /tmp/python-support_1.0.15_all.deb
> sudo dpkg -i /tmp/python-support_1.0.15_all.deb
> # Install Package sudo dpkg -i /tmp/ansible.deb # Remove downloaded
> packages sudo rm -f /tmp/ansible.deb /tmp/python-support_1.0.15_all.deb
> This worked (yay).
> I'm running the playbook by git cloning from https://github.com/
> GeoNode/ansible-geonode into a "roles/ansible-geonode" directory under my
> playbook.yml file. I'm at commit 1e6d8f9.
> playbook.yml now looks like this:
> - hosts: webserver
> remote_user: ubuntu
> gather_facts: no
> pre_tasks:
> - name: 'install python2'
> raw: apt -y update && apt install -y python-minimal
> sudo: yes
> - setup:
> vars:
> app_name: my_test_app
> github_user: GeoNode
> roles:
> - ansible-geonode
> Under this configuration, the "makemigrations" command works, but we now
> get stuck on "syncdb", error log is here:
> https://gist.github.com/davekennewell/130f10d6b45a88e2d1bfa9b8dcd065ad
> I reran the process with the commit I began with 2 days ago (ab17551)and
> received the same error message.
> I'm a bit confused as to why the playbook would run makemigrations (Django
> 1.8) and then syncdb (Django 1.6)? Should it not be makemigrations then
> migrate?
> I get the same error if I run the playbook from ansible-galaxy.
> thanks for the help!
> cheers
> Dave
> On 6 January 2017 at 04:07, Angelos Tzotsos [via OSGeo.org] <
> ml-node+s1560n5302236h31 at n6.nabble.com> wrote:
>> Hi Dave,
>> It looks like this error is specific to ansible 2.x
>> The ansible role works fine with ansible 1.9.x for now.
>> We will try to fix this issue soon.
>> Thanks,
>> Angelos
>> On 01/05/2017 01:16 PM, Dave Kennewell wrote:
>> Hi Angelos,
>> Thanks for this - I've tried the geonode-ansible installer. It seems to be
>> working well, until I get to the "makemigrations" command, when I get this
>> permissions error:
>> [image: Inline images 1]
>> If I ssh into the server, activate the venv and execute the makemigrations
>> command manually, it works fine... but the rest of the playbook won't run.
>> My playbook looks like this
>> - hosts: webserver
>> remote_user: ubuntu
>> vars:
>> roles:
>> - geonode
>> Both my ansible controlling machine & the geonode server are running
>> Xenial.
>> It's my first time using ansible, so I might be doing something not quite
>> right, or it might the the scripts?
>> Thanks
>> Dave Kennewell
>> On 3 January 2017 at 18:29, Angelos Tzotsos [via OSGeo.org] <
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5302236&i=0>> wrote:
>> Hi all,
>> I just completed updating the ansible installer for Ubuntu Xenial:https://github.com/GeoNode/ansible-geonode
>> Please test and let me know how this works out.
>> I am going to work on the ppa issues next.
>> Best,
>> Angelos
>> On 01/03/2017 10:01 AM, David Kennewell wrote:
>> Ah, thanks Simone... I had been trying on Ubuntu 14.04 and not getting
>> anywhere with the /testing repo.
>> On 16.04 I'm now getting the same packaging problems as Jeff mentioned in
>> his recent email (subject: "GeoNode 2.5.6 is out"). But at least I'm now on
>> the same page as everyone else :)
>> (and apologies for any cross-posting with this reply, I've been getting
>> confused with my email lists)
>> David Kennewell
>> Water Resources Engineer
>> Hydrata.com
>> +971 55 409 7378[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=0> <http:///user/SendEmail.jtp?type=node&node=5301842&i=0>
>> On Tue, Jan 3, 2017 at 11:08 AM, Simone Dalmasso [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=1> <http:///user/SendEmail.jtp?type=node&node=5301842&i=1>
>> wrote:
>> Hi, the fastest is to install geonode on xenial using the normal geonode
>> installation guide but just use:
>> sudo add-apt-repository ppa:geonode/testing
>> instead of
>> sudo add-apt-repository ppa:geonode/stable.
>> hope this helps
>> 2017-01-03 7:38 GMT+01:00 David Kennewell [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=2> <http:///user/SendEmail.jtp?type=node&node=5301842&i=2>:
>> Hi list,
>> I'd like to try out the new react viewer, and use django 1.8, not 1.6.
>> As of today, what's the easiest way to get this up and running on a clean
>> server?
>> regards
>> Dave
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=3> <http:///user/SendEmail.jtp?type=node&node=5301842&i=3>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=4> <http:///user/SendEmail.jtp?type=node&node=5301842&i=4>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Angelos Tzotsos, PhD
>> OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
>> geonode-devel mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5301842&i=5> <http:///user/SendEmail.jtp?type=node&node=5301842&i=5>http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> If you reply to this email, your message will be added to the discussion
>> below:http://osgeo-org.1560.x6.nabble.com/Re-GeoNode-users-installing-geonode-2-5-6-tp5301842.html
>> To unsubscribe from GeoNode devel, click here
>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> geonode-users mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5302236&i=1>http://lists.osgeo.org/mailman/listinfo/geonode-users
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5302236&i=2>
>> below:
>> http://osgeo-org.1560.x6.nabble.com/installing-geonode-2-5-
>> 6-tp5301801p5302236.html
>> To unsubscribe from GeoNode users, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185389&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM4OXwtOTI1NjEyMTk0>
>> NAML
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170106/d15a18dd/attachment-0001.html>
More information about the geonode-users
