[GeoNode-users] Multi-Tenancy: how to start
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 9 01:26:37 PST 2017
All files of the site_template folder.
Like
https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/site_template/settings.py#L39
https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/site_template/wsgi.py#L39
2017-01-09 9:39 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> you said that I should have adjust correctly the variables in the files
> that start with "$".
> This is not clear to me.
> What file do you refer? and Which variables?
> best
> Eugenio
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* giovedì 5 gennaio 2017 07.41
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: Multi-Tenancy: how to start
> The $ should not be there, is an identifier for pieces of code that would
> be changed by the addsite script. It is a normal python path.
> And yes, the SERVE_PATH should be in one of the project's settings as it
> is used to locate your static and media files "STATIC_ROOT =
> os.path.join(SERVE_PATH, 'static')"
> 2017-01-03 17:13 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi Simone,
>> I presume maybe I'm not so far from finalization of the configuration.
>> I apologize if I'm not enough smart, but I don't understand which file do
>> you mentioned, starting with "$". I suppose you intended the line 19 in the
>> wsgi.py located in the geosite folder (i.e. gemex for me), am I correct?
>> If yes I changed the line in:
>> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "$geosites.%s.settings"
>> % curdir)
>> since, as you know, I'm using a normal installation of geonode, so I have
>> the geosites project forlder within:
>> /geonode/geonode/contrib and my project folder name is the original
>> geosites.
>> Did I understand well?
>> Regarding the static_root it is my intention to leave that folder in my
>> site folder (/geonode/geonode/contrib/geosites/gemex/). In that case I
>> should run your suggested command:
>> python manage.py collectstatic --settings=geonode.contrib.geo
>> sites.gemex.settings
>> and in gemex.settings has to be inserted the variable SERVE_PATH, am I
>> correct?
>> Thanks
>> Eugenio
>> *Inviato:* martedì 3 gennaio 2017 08.35
>> *A:* Eugenio Trumpy
>> Eugenio is all more or less right.
>> The error you have is because, since you copied the site_template folder
>> manually, you also have to correctly adjust the variables in the files that
>> start with "$". In this case you have to put the correct project name in
>> the wsgi.py-
>> For the static files, they can stay anywhere, but is suggested to have
>> them in the web server folders /var/www etc,as said. To copy them there,
>> once you have set the STATIC_ROOT folder in the geosite settings yu can use
>> the normal geonode manage.py file by passing it the geosites settings
>> instead:
>> 2016-12-29 12:21 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi Simone and all,
>>> unfortunately I hadn't solved my problem multi-tenancy configuration.
>>> My new questions are:
>>> - can I set-up multi-geosites from my running normal installation?
>>> (I installed geonode following this guide [1]) or should I install a
>>> geonode from scratch?
>>> - to run multi-geosites do you suggest me to setup multi-geosite
>>> from special version of geonode as for instance [2], if yes How to start?
>>> - in my geonode normal installation manage.py and manage_all.py are
>>> missing in the /geonode/geonode/contrib/geosites/
>>> - the master site has to be within contrib/geosites/master-site,
>>> which relationship is there between the normal geonode site and the
>>> master-site? in case master-site has to inherit from normal one-site
>>> config, how?
>>> - just to be sure is this the right order of the setting files read
>>> by geonode:
>>> - /geonode/geonode/local_setting.py and /geonode/geonode/setting.py
>>> (overridden by the first)
>>> - /geonode/geonode/contrib/geosites/pre_setting.py
>>> - /geonode/geonode/contrib/geosites/local_setting.py
>>> and /geonode/geonode/contrib/geositessetting.py (overridden by
>>> the first)
>>> - /geonode/geonode/contrib/geosites/post_setting.py
>>> - in my test performed in the last days I set the: SERVE_PATH=
>>> "/dati/geonode/geonode/contrib/geosites/ in
>>> /geonode/geonode/local_setting.py is that right? in apache error log
>>> I have:
>>> [Thu Dec 29 11:46:21.129691 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] self.load_middleware()
>>> [Thu Dec 29 11:46:21.129706 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] File "/usr/local/lib/python2.7/dist
>>> -packages/django/core/handlers/base.py", line 44, in load_middleware
>>> [Thu Dec 29 11:46:21.129728 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] for middleware_path in
>>> settings.MIDDLEWARE_CLASSES:
>>> [Thu Dec 29 11:46:21.129742 2016] [:error] [pid 14216] [remote
>>> -packages/django/conf/__init__.py", line 54, in __getattr__
>>> [Thu Dec 29 11:46:21.129763 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] self._setup(name)
>>> [Thu Dec 29 11:46:21.129776 2016] [:error] [pid 14216] [remote
>>> -packages/django/conf/__init__.py", line 49, in _setup
>>> [Thu Dec 29 11:46:21.129797 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] self._wrapped = Settings(settings_module)
>>> [Thu Dec 29 11:46:21.129810 2016] [:error] [pid 14216] [remote
>>> -packages/django/conf/__init__.py", line 132, in __init__
>>> [Thu Dec 29 11:46:21.129831 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] % (self.SETTINGS_MODULE, e)
>>> [Thu Dec 29 11:46:21.129851 2016] [:error] [pid 14216] [remote
>>> 93.32.72.156:62917] ImportError: Could not import settings
>>> '$PROJECT_NAME.gemex.settings' (Is it on sys.path? Is there an import error
>>> in the settings file?): No module named $PROJECT_NAME.gemex.settings
>>> the error at last line it is seems to be related to something missing....
>>> - last but not least I still have doubt on the positioning of
>>> static_root folder for each geosites, I would maintain them within each
>>> geosite folder but I don't know how to run collectstatic to populate that
>>> folder.
>>> Thanks for any hint...
>>> Eugenio
>>> [1] http://docs.geonode.org/en/latest/tutorials/install_and_admi
>>> n/geonode_install/index.html
>>> [2]
>>> <http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/index.html>
>>> https://github.com/terranodo/geosites-project
>>> <https://github.com/terranodo/geosites-project>
>>> github.com
>>> geosites-project - A skeleton project for creating a multi-tenancy
>>> GeoNode using the GeoSites contrib app.
>>> *Inviato:* mercoledì 21 dicembre 2016 10.37
>>> *A:* Eugenio Trumpy
>>> ok:
>>> - I this that that Alias is a mistake, the way is configured is that any
>>> url /gemex will internally point to /dati but I don't think they are
>>> actually urls. You can remove it
>>> - you can assign a new name to WSGIProcessGroup
>>> - it ok to keep the dir in the root base of geonode since your site is
>>> inside
>>> - the geonode apt package creates the uploaded and static root under
>>> var/www as far as I know. It is ok to reuse the same settings. If not I
>>> suggest you to put them there as they are meant to be served by apache.
>>> - you can use the same config for the Daemon, just use the name you gave
>>> to the WSGIProcessGroup instead of geonode
>>> This is a brief explanation but you can find more on the static url and
>>> roots on the django docs and more on the wsgi config on the apache docs
>>> hope this helps.
>>> 2016-12-20 9:36 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>> Hi Simone and all,
>>>> thanks again for your inputs.
>>>> However, I think I'm at a crucial position to finalize the
>>>> configuration of the first new geosite (named gemex).
>>>> Just to clarify all the step performed and to focus the stage where I'm
>>>> now, I list here below what I did and what I miss:
>>>> 1. in setting.py I added under INSTALLED_APPS the line
>>>> 'geonode.contrib.geosites'
>>>> 2. I run python manage.py syncdb
>>>> 3. I copy site-template (i.e. the folder inside contrib/geosites/)
>>>> in the same position (i.e. contrib/geosites/) with a new name (e.g. gemex
>>>> in my case)
>>>> 4. I created a 4 level doman to be linked to the new site (i.e.
>>>> gemex.igg.cnr.it in my case)
>>>> 5. I added a new site from the admin panel available from a normal
>>>> running installation
>>>> 6. I create a new virtual host (for apache2) by copy the virtual
>>>> host I had for the normal running installation. Here what is clear to me
>>>> are the items:
>>>> - ServerName = where I put the created 4 level domain
>>>> - WSGIScriptAlias where I put the link to the wsgi.py available
>>>> within the created newsite (i.e. path to contrib/geosites/gemex/wsgi.py
>>>> - ProxyPass and ProxyPassReverse linked to the local geoserver
>>>> What is not yet clear:
>>>> from your last email I understand that the new site can be where I
>>>> prefer. I would say that for now I can leave it inside contrib/geosites, if
>>>> I can of course.
>>>> Then I have doubts to setup these lines:
>>>> - In the normal config I have Alias /geonode /dati/geonode/geonode
>>>> but I think I should change to link it to my new site, is it right?
>>>> - In WSGIProcessGroup the normal config has geonode, for my new
>>>> site do I need to change it?
>>>> - Regarding the directive Directory I had <Directory
>>>> "/dati/geonode/geonode/"> for the normal config, here should I insert the
>>>> path to my new site?
>>>> - Regarding /uploaded/ and /static/ Aliases, I understood from your
>>>> email I can put those directory where I prefer. Now another trivial
>>>> question: /uploaded/ and /static/ folder have to be different from those
>>>> created for the normal installation? if no, then it is easy both configure
>>>> the virtual host and run collectstatic. If yes, it is not clear how to run
>>>> collectstatic for the new site. That's why the command python manage.py
>>>> collectstatic works only within geonode folder and fill in the normal
>>>> static_root folder. Could you clarify this point?
>>>> - Last but not least the line WSGIDaemonProcess is not clear,
>>>> because running: service apache reload I had an error: Name
>>>> duplicates previous WSGI daemon definition (that's why apache find the
>>>> virtualhost I have for the normal installation. The normal installation
>>>> has: WSGIDaemonProcess geonode python-path=/dati/geonode/:/da
>>>> ti/.venvs/geonode/lib/python2.7/site-packages user=eugenio
>>>> threads=15 processes=2 How should sort out this line for the new site?
>>>> I offer myself to prepare an how to for dummies to be included as
>>>> documentation in git, if I will be able to configure geosites.
>>>> Thanks for any clarification
>>>> Eugenio
>>>> *Inviato:* lunedì 19 dicembre 2016 18.33
>>>> *A:* Eugenio Trumpy
>>>> I mean the whole gemex folder can be outside. For the static roots they
>>>> can be anywhere and is not recommended to have them inside but rather in
>>>> /var/www as they need to be served by the web server at some point.
>>>> 2016-12-19 16:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Ok, once I run syncdb I 'm able to register new site! first step!!!!
>>>>> Coming back to the first issue, I'm not sure to have understood well,
>>>>> do you mean the dir thumb, layers, static_root can stay ouside my newsite
>>>>> directory?
>>>>> That means I cannot run collectstatic if those dirs are inside my site
>>>>> dir?
>>>>> Actually in the docs I read I saw that the static folder is inside the
>>>>> new sites.
>>>>> This part is not so clear to me....
>>>>> E.
>>>>> *Inviato:* lunedì 19 dicembre 2016 16.22
>>>>> *A:* Eugenio Trumpy
>>>>> It is a good practice to not install the new sites folders into the
>>>>> root of the code. They can live outside without problems.
>>>>> The second issue is that you did not run python manage.py syncdb or
>>>>> migrate to install the tables that come with geosites.
>>>>> 2016-12-19 15:50 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>> Sorry for these multiple emails,
>>>>>> I following your suggestion to create the site by hand I proceeded to
>>>>>> register the new site by using the admin console as you suggested.
>>>>>> On save action I had this error message:
>>>>>> http://pastebin.com/SskX1QNB
>>>>>> It seems geonode.contrib.geosites is not installed yet, right?
>>>>>> E.
>>>>>> *Da:* Eugenio Trumpy <frippe12573 at hotmail.com>
>>>>>> *Inviato:* lunedì 19 dicembre 2016 15.37
>>>>>> *A:* Simone Dalmasso
>>>>>> Ok,
>>>>>> this is my new virtualhost prepared for the new site named 'gemex':
>>>>>> <VirtualHost *:80>
>>>>>> ServerName http://gemex.igg.cnr.it
>>>>>> ServerAdmin webmaster at localhost
>>>>>> DocumentRoot /var/www/html
>>>>>> Options -Indexes +FollowSymLinks
>>>>>> Alias /gemex "/dati/geonode/geonode/contrib/geosites"
>>>>>> WSGIDaemonProcess gemex python-path=/dati/geonode/geon
>>>>>> ode/contrib/geosites:/dati/.venvs/geonode/lib/python2.7/site-packages
>>>>>> user=eugenio threads=15 processes=2
>>>>>> ErrorLog /var/log/apache2/error.log
>>>>>> LogLevel warn
>>>>>> CustomLog /var/log/apache2/access.log combined
>>>>>> WSGIProcessGroup gemex
>>>>>> WSGIPassAuthorization On
>>>>>> WSGIScriptAlias / /dati/geonode/geonode/contrib/
>>>>>> <Directory "/dati/geonode/geonode/contrib/geosites/gemex">
>>>>>> Options Indexes FollowSymLinks
>>>>>> Require all granted
>>>>>> IndexOptions FancyIndexing
>>>>>> </Directory>
>>>>>> Alias /uploaded/ /dati/geonode/geonode/contrib/
>>>>>> geosites/gemex/uploaded/
>>>>>> Alias /static/ /dati/geonode/geonode/contrib/
>>>>>> geosites/gemex/static_root/
>>>>>> ProxyPreserveHost On
>>>>>> ProxyPass /geoserver http://localhost:8080/geoserver
>>>>>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>>> ProxyPass /geoserver2 http://localhost:8080/geoserver2
>>>>>> ProxyPassReverse /geoserver2 http://localhost:8080/geoserver2
>>>>>> </VirtualHost>
>>>>>> My concerns are:
>>>>>> - WSGIDeamon line, is that correct?
>>>>>> - the first Alias, is that correct too?
>>>>>> - Eventually the Directory is right?
>>>>>> Moreover, I followed again this page for the http setup:
>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admi
>>>>>> n/geonode_install/setup_configure_httpd.html
>>>>>> I think now should be rready for the collecstatic command, but I
>>>>>> don't know how to run it in in the new static_root inside my site gemex.
>>>>>> Any hints?
>>>>>> E.
>>>>>> Setup & Configure HTTPD — GeoNode 2.4 documentation
>>>>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html>
>>>>>> docs.geonode.org
>>>>>> Setup & Configure HTTPD¶ In this section we are going to setup Apache
>>>>>> HTTP to serve GeoNode.
>>>>>> *Inviato:* lunedì 19 dicembre 2016 15.03
>>>>>> *A:* Eugenio Trumpy
>>>>>> Exactly, one virtualhost for each site.
>>>>>> 2016-12-19 14:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>> Ok,
>>>>>>> I will proceed this way.
>>>>>>> Then I have to create a new virtualhost pointing to the wsgi.py
>>>>>>> within the new site dir, right?
>>>>>>> In the same virtual host have I to set new aliases for uploaded dir
>>>>>>> and static_root as I did for the normal installation?
>>>>>>> E.
>>>>>>> *Inviato:* lunedì 19 dicembre 2016 14.21
>>>>>>> *A:* Eugenio Trumpy
>>>>>>> I suggest you to go manually and create a site folder copying the
>>>>>>> site_template, rename and add the Site object into the database.
>>>>>>> geosites has not been revised for a while and geonode improved. It
>>>>>>> works but the shortcut command addsite may be broken.
>>>>>>> 2016-12-19 11:32 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>>> Hi Simone,
>>>>>>>> I did what you suggested, actually now I have the addsite command,
>>>>>>>> but as you announced I have also this error:
>>>>>>>> AttributeError: 'Settings' object has no attribute 'SITE_ROOT'
>>>>>>>> then I added SITE_ROOT in local_setting.py inserting the path
>>>>>>>> "geonode/contrib/geosites"
>>>>>>>> afterwords I had this error:
>>>>>>>> AttributeError: 'Settings' object has no attribute 'SERVE_PATH'
>>>>>>>> so that I added SERVE_PATH in local_setting.py inserting the path "
>>>>>>>> geonode/contrib/geosites/static"
>>>>>>>> but I'm not sure I did the right thing, since now I have this error:
>>>>>>>> OSError: [Errno 17] File exists: '/dati/geonode/geonode/contrib
>>>>>>>> /site2'
>>>>>>>> Where I'm wrong?
>>>>>>>> Thanks
>>>>>>>> Eugenio
>>>>>>>> *Inviato:* lunedì 19 dicembre 2016 11.04
>>>>>>>> *A:* Eugenio Trumpy
>>>>>>>> you have to add it in INSTALLED_APPS, currently it is only listed
>>>>>>>> in the contrib apps.
>>>>>>>> 2016-12-19 9:20 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>>>>>> Hi Simone,
>>>>>>>>> and thank you for your answer.
>>>>>>>>> Sorry for my trivial question:
>>>>>>>>> in my setting.py I have already geonode.contrib.geosites
>>>>>>>>> in GEONODE_CONTRIB_APPS, see below:
>>>>>>>>> GEONODE_CONTRIB_APPS = (
>>>>>>>>> # GeoNode Contrib Apps
>>>>>>>>> 'geonode.contrib.dynamic',
>>>>>>>>> 'geonode.contrib.exif',
>>>>>>>>> 'geonode.contrib.favorite',
>>>>>>>>> 'geonode.contrib.geogig',
>>>>>>>>> 'geonode.contrib.geosites',
>>>>>>>>> 'geonode.contrib.nlp',
>>>>>>>>> 'geonode.contrib.slack'
>>>>>>>>> in INSTALLED_APPS I have:
>>>>>>>>> INSTALLED_APPS = (
>>>>>>>>> # Boostrap admin theme
>>>>>>>>> # 'django_admin_bootstrapped.bootstrap3',
>>>>>>>>> # 'django_admin_bootstrapped',
>>>>>>>>> # Apps bundled with Django
>>>>>>>>> 'django.contrib.auth',
>>>>>>>>> 'django.contrib.contenttypes',
>>>>>>>>> 'django.contrib.sessions',
>>>>>>>>> 'django.contrib.sites',
>>>>>>>>> 'django.contrib.admin',
>>>>>>>>> 'django.contrib.sitemaps',
>>>>>>>>> 'django.contrib.staticfiles',
>>>>>>>>> 'django.contrib.messages',
>>>>>>>>> 'django.contrib.humanize',
>>>>>>>>> 'django.contrib.gis',
>>>>>>>>> # Third party apps
>>>>>>>>> # Utility
>>>>>>>>> 'pagination',
>>>>>>>>> 'taggit',
>>>>>>>>> 'friendlytagloader',
>>>>>>>>> 'geoexplorer',
>>>>>>>>> 'leaflet',
>>>>>>>>> 'django_extensions',
>>>>>>>>> # 'haystack',
>>>>>>>>> ....and others...
>>>>>>>>> Should I insert geonode.contrib.geosites somewhere in
>>>>>>>>> local_setting? or it's already ok as it? or copy geonode.contrib.geosites
>>>>>>>>> in settings.py under INSTALLED_APPS?
>>>>>>>>> Sorry again for this banal question...
>>>>>>>>> E.
>>>>>>>>> *Inviato:* lunedì 19 dicembre 2016 09.04
>>>>>>>>> *A:* Eugenio Trumpy
>>>>>>>>> Ciao Eugenio,
>>>>>>>>> sorry for being so late in the response.
>>>>>>>>> You have to add 'geonode.contrib.geosites' to your INSTALLED_APPS
>>>>>>>>> in order to get the command.
>>>>>>>>> In case you get errors in running that command, you can always
>>>>>>>>> 'make' a geosite by yourself by copying the folder 'site_template' and
>>>>>>>>> changing it's name and internal parameters and then register the new Site
>>>>>>>>> in the admin panel. You can follow the utils.py add_site function and
>>>>>>>>> replicate the needed steps (some of them are only for production).
>>>>>>>>> Take also some time to see how the pre and post settings work.
>>>>>>>>> Hope this helps
>>>>>>>>> 2016-12-19 8:55 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>
>>>>>>>>>> Hi everyone,
>>>>>>>>>> regarding the multi-tenancy setting up and in particular the
>>>>>>>>>> installation of new site since the command:
>>>>>>>>>> python manage.py addsite sitename sitedomain
>>>>>>>>>> return me:
>>>>>>>>>> Unknown command: 'addsite'
>>>>>>>>>> Type 'manage.py help' for usage.
>>>>>>>>>> Do you know way? Have I 'activate' in some way the multi-tenancy
>>>>>>>>>> before? or it is ready to use?
>>>>>>>>>> If it is ready to use, why 'addsite' is an unknown command?
>>>>>>>>>> I launched the command from the main geonode directory, am I
>>>>>>>>>> right?
>>>>>>>>>> As I wrote in the previous email in my installation I have only
>>>>>>>>>> manage.py file in
>>>>>>>>>> /geonode directory.
>>>>>>>>>> I'm testing on on ubuntu 14.04 and geonode is at version
>>>>>>>>>> 2.4.dev20151029170512.
>>>>>>>>>> I installed geonode as custom installation (not by apt-get).
>>>>>>>>>> Thanks
>>>>>>>>>> Eugenio
>>>>>>>>>> *Inviato:* venerdì 16 dicembre 2016 15.04
>>>>>>>>>> *A:* geonode-users at lists.osgeo.org
>>>>>>>>>> *Oggetto:* Multi-Tenancy: how to start
>>>>>>>>>> Hi all,
>>>>>>>>>> as pointed in the email object I want to try the
>>>>>>>>>> geonode multi-tenancy capabilities.
>>>>>>>>>> I started of course from the documentation [1] and [2], but a
>>>>>>>>>> need some hints to start.
>>>>>>>>>> I have already a running geonode instance. Do you think I should
>>>>>>>>>> start from
>>>>>>>>>> a clean geonode installation or I can arrange the running one?
>>>>>>>>>> Is there somewhere a set of commands to setup the geosite 1,
>>>>>>>>>> geosite 2, ...
>>>>>>>>>> I was looking into geosites folder, as suggested in [2], but I
>>>>>>>>>> don't see neither manage.py nor manage_all.py files.
>>>>>>>>>> I tried python manage.py addsite geosite1 geosite1domain
>>>>>>>>>> but I got Unknown command: 'addsite'
>>>>>>>>>> Am I missing something?
>>>>>>>>>> After that: How can I sort out the already stored layers?
>>>>>>>>>> Thank you very much for hints and for the patience of this
>>>>>>>>>> stupid questions,
>>>>>>>>>> Eugenio
>>>>>>>>>> [1] https://geonode.readthedocs.io/en/2.0/tutorials/admin/mu
>>>>>>>>>> lti-tenancy.html
>>>>>>>>>> [2] https://github.com/GeoNode/geonode/tree/master/geonode/c
>>>>>>>>>> ontrib/geosites
>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>>> Simone
>>>>>> Simone
>>>>> Simone
>>>> Simone
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170109/a35a6da2/attachment-0001.html>
More information about the geonode-users
