[GeoNode-users] RHEL 7
Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos)
jm.vazquez.lopez at cfnavarra.es
Wed Jan 11 01:55:01 PST 2017
Yes, this repo works.
Continuing the manual, I should modify the local_settings.py.sample file and save it as local_settings.py, but that file doesn't exist.
I can see two other: local_settings.py.geoserver.sample and local_settings.py.qgis.sample, so I modified the geoserver one and save it as local_settings.py
Is this correct?
Then, the manage.py is not in /home/geonode/geonode/genode directory, instead it is in /home/geonode/geonode, so I have copied it to /home/geonode/geonode/genode in order to execute it (and obtain the same error as above)
Is this correct?
Thanks
Jose
De: Francesco Bartoli [mailto:xbartolone at gmail.com]
Enviado el: lunes, 09 de enero de 2017 16:14
Para: Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos)
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] RHEL 7
Have you already tried with this repo http://rpm.pbone.net/index.php3?stat=3&search=libxslt-python&srodzaj=3&dist[]=94<http://rpm.pbone.net/index.php3?stat=3&search=libxslt-python&srodzaj=3&dist%5B%5D=94>?
Il giorno 09/gen/2017, alle ore 13:10, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es<mailto:jm.vazquez.lopez at cfnavarra.es>> ha scritto:
Hi, Francesco.
Sorry about Christmas long break.
First, I Can't find the proper libxslt-python package,
After do sudo yum install -y git gdal gdal-python geos python-pip python-imaging \
python-virtualenv python-devel gcc-c++ python-psycopg2 libxml2 \
libxml2-devel libxml2-python libxslt libxslt-devel libxslt-python,
I get this:
No existe disponible ningún paquete libxslt-python
The rest of packages seem to be installed.
Continuing the manual, I arrive at this point:
python manage.py migrate with this result:
Instrucción ilegal
And, I can see this message in /var/log/messages:
Jan 9 13:06:24 centjeedes12 kernel: traps: python[62459] trap invalid opcode ip:7f938dbbabee sp:7fff2b18c058 error:0 in etree.so[7f938d99c000+4b7000]
Thanks
Jose
De: "xbartolone at gmail.com<mailto:xbartolone at gmail.com>" [mailto:xbartolone at gmail.com]
Enviado el: jueves, 22 de diciembre de 2016 17:06
CC: "geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>"
Hi Josè,
What kind of issues are you facing?
Francesco
Inviato da TypeApp<http://www.typeapp.com/r> per iPhone
On 22 dic 2016 at 16:29<x-apple-data-detectors://1>, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos) <jm.vazquez.lopez at cfnavarra.es<mailto:jm.vazquez.lopez at cfnavarra.es>> wrote:
Has anyone installed geonode over RHEL 7?
I'm having trouble installing it, following the guide http://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/setup_centos.html
Thanks
José Manuel Vázquez
Lurraldeko Informazio Sistemen Atala / Sección de Sistemas de Información Territorial
Informazio Sistema Korporatiboen Zerbitzua / Servicio de Sistemas de Información Corporativos
Informatika, Telekomunikazio eta Berrikuntza Publikoaren Zuzendaritza Nagusia / Dirección General de Informática, Telecomunicaciones e Innovación Pública
Lehendakaritzako, Funtzio Publikoko, Barneko eta Justiziako Departamentua / Departamento de Presidencia, Función Pública, Interior y Justicia
Nafarroako Gobernua Gobierno de Navarra
C/ Cabárceno, 6<x-apple-data-detectors://5> - 3ª planta
31621 Sarriguren (Navarra)
e-mail: jm.vazquez.lopez at cfnavarra.es<mailto:jm.vazquez.lopez at cfnavarra.es>
teléfono: +34 848 426 169<tel:+34%20848%20426%20169>
Lantokiaren kokalekua / Localízame en
<https://administracionelectronica.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detalles=Informatika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzendaritza%20Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica>
Antes de imprimir este mensaje, asegúrate de que es necesario. Proteger el medio ambiente está también en tu mano. Mesedez, gogoan izan ingurumenaren-inpaktua e-posta hau inprimatu baino lehen. Please consider your environmental responsibility before printing this e-mail.<https://administracionelectronica.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detalles=Informatika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzendaritza%20Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica>
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users<https://administracionelectronica.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detalles=Informatika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzendaritza%20Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170111/84672731/attachment.html>
More information about the geonode-users
