[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jan 11 04:29:44 PST 2017
Sure you can, what error do you get, 404 or something else? You may need to
add the forward rule in virtualbox to port 8000.
2017-01-11 12:45 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
> I'm trying to setup the GeoNode development build following the
> instructions in https://github.com/GeoNode/geonode (using the ubuntu
> instructions - virtualevn; pip; paver). The catch is that I have a windows
> machine so I installed a Ubuntu server on a Virtualbox (just the server, no
> GUI).
> I can access the server running on the virtualbox through the IP
> 192.168.67.103
> After doing paver stat, I can get to geoserver through the IP
> 192.168.67.103:8080/geoserver
> However, I cannot get to geonode through the IP 192.168.67.103:8000
> Is it possible to run the GeoNode development build this way? With just a
> Ubuntu server install and access through an IP other than localhost?
> Cheers
> Daniel
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170111/d409ea7c/attachment.html>
More information about the geonode-users mailing list
