[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jan 11 06:03:39 PST 2017
Ah yes, don't use paver otherwise will be only in localhost. And yes, adapt
the geoserver PUBLIC_LOCATION to your needs in settings and will be fine.
2017-01-11 14:03 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
> I get an error that it's not possible to connect to the address
> http://192.168.67.103/ or http://192.168.67.103:8000/
> But if I go to geoserver page on http://192.168.67.103:8080/geoserver and
> click on the geonode Icon, I get redirected to localhost:8000 (which does
> not work).
> I tryed both `paver start` and `paver start -b 192.168.67.103:8000`
> What did work was to issue `python manage.py runserver 192.168.67.103:8000`.
> With that I can get to GeoNode at the address but the link to Geoserver
> does not work because it looks for geoserver under localhost:8080
> Will changing the geoserver address in settings.py fix this?
> My setup is a bit strange because my virtualbox connects to the internet
> via a NAT interface and connetcs to my host computer using a host-only net
> interface
> Thanks
> On Wed, Jan 11, 2017 at 10:29 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Sure you can, what error do you get, 404 or something else? You may need
>> to add the forward rule in virtualbox to port 8000.
>> 2017-01-11 12:45 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> I'm trying to setup the GeoNode development build following the
>>> instructions in https://github.com/GeoNode/geonode (using the ubuntu
>>> instructions - virtualevn; pip; paver). The catch is that I have a windows
>>> machine so I installed a Ubuntu server on a Virtualbox (just the server, no
>>> GUI).
>>> I can access the server running on the virtualbox through the IP
>>> 192.168.67.103
>>> After doing paver stat, I can get to geoserver through the IP
>>> However, I cannot get to geonode through the IP 192.168.67.103:8000
>>> Is it possible to run the GeoNode development build this way? With just
>>> a Ubuntu server install and access through an IP other than localhost?
>>> Cheers
>>> Daniel
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170111/f05d7c5d/attachment-0001.html>
More information about the geonode-users
