[GeoNode-users] RHEL 7
Francesco Bartoli
xbartolone at gmail.com
Thu Jan 12 08:27:04 PST 2017
yes absolutely and then you should also configure the connection parameters in
the settings that you have previously uncommented
Sent from [Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-730131e5-3ddc/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open source mail
client.
On gen 12 2017, at 1:17 pm, Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf.
Corporativos) <jm.vazquez.lopez at cfnavarra.es> wrote:
> This works better…
> geonode at centjeedes12:geonode$ python manage.py migrate
> Traceback (most recent call last):
> File "manage.py", line 29, in <module>
> execute_from_command_line(sys.argv)
> File "/usr/lib/python2.7/site-
packages/django/core/management/__init__.py", line 354, in
> utility.execute()
packages/django/core/management/__init__.py", line 346, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/usr/lib/python2.7/site-packages/django/core/management/base.py",
line 394, in run_from_argv
> self.execute(*args, **cmd_options)
line 445, in execute
> output = self.handle(*args, **options)
packages/django/core/management/commands/migrate.py", line 93, in handle
> executor = MigrationExecutor(connection,
self.migration_progress_callback)
> File "/usr/lib/python2.7/site-packages/django/db/migrations/executor.py",
line 19, in __init__
> self.loader = MigrationLoader(self.connection)
> File "/usr/lib/python2.7/site-packages/django/db/migrations/loader.py",
line 47, in __init__
> self.build_graph()
line 191, in build_graph
> self.applied_migrations = recorder.applied_migrations()
> File "/usr/lib/python2.7/site-packages/django/db/migrations/recorder.py",
line 59, in applied_migrations
> self.ensure_schema()
line 49, in ensure_schema
> if self.Migration._meta.db_table in
self.connection.introspection.table_names(self.connection.cursor()):
> File "/usr/lib/python2.7/site-packages/django/db/backends/base/base.py",
line 162, in cursor
> cursor = self.make_debug_cursor(self._cursor())
line 135, in _cursor
> self.ensure_connection()
line 130, in ensure_connection
> self.connect()
> File "/usr/lib/python2.7/site-packages/django/db/utils.py", line 98, in
__exit__
> six.reraise(dj_exc_type, dj_exc_value, traceback)
> self.connect()
line 119, in connect
> self.connection = self.get_new_connection(conn_params)
packages/django/db/backends/postgresql_psycopg2/base.py", line 176, in
get_new_connection
> connection = Database.connect(**conn_params)
> File "/usr/lib64/python2.7/site-packages/psycopg2/__init__.py", line 164,
in connect
> conn = _connect(dsn, connection_factory=connection_factory, async=async)
> django.db.utils.OperationalError: could not connect to server: No such file
or directory
> Is the server running locally and accepting
> connections on Unix domain socket
"/var/run/postgresql/.s.PGSQL.5432"?
> Should I have installed PostgreSQL before?
> **De:** Francesco Bartoli [mailto:xbartolone at gmail.com]
**Enviado el:** jueves, 12 de enero de 2017 12:28
**Para:** Vázquez López, José Manuel (DGITIP-Serv. Sist.Inf. Corporativos)
**CC:** geonode-users at lists.osgeo.org
**Asunto:** Re: [GeoNode-users] RHEL 7
> Try to downgrade the version to 3.6.0
/local-a219df8b-f0b0/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=am0u
dmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc
client.
On gen 12 2017, at 12:24 pm, Vázquez López, José Manuel (DGITIP-Serv.
<[jm.vazquez.lopez at cfnavarra.es](mailto:jm.vazquez.lopez at cfnavarra.es)> wrote:
> lxml==3.7.0
[[mailto:xbartolone at gmail.com](mailto:xbartolone at gmail.com)]
**Enviado el:** jueves, 12 de enero de 2017 12:20
**CC:** [geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)
> There might be issue with the lxml dependency. Let's see the current version
by running:
> $ pip freeze | grep lxml
Sent from [ Nylas N1](https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc
/local-a2f4d0e9-0fb4/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=am0u
dmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM
=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open source
mail client.
On gen 12 2017, at 12:14 pm, Vázquez López, José Manuel (DGITIP-Serv.
> The manage.py script is:
> import os
> import sys
> if __name__ == "__main__":
> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "geonode.settings")
> from django.core.management import execute_from_command_line
> I run python manage.py migrate, and I can see:
> Instrucción Ilegal
> Jan 12 12:11:22 centjeedes12 kernel: traps: python[3801] trap invalid opcode
ip:7fb25a4ebbee sp:7fff0c815e78 error:0 in etree.so[7fb25a2cd000+4b7000]
> **De:** geonode-users [[mailto:geonode-users-bounces at lists.osgeo.org](mailto
:geonode-users-bounces at lists.osgeo.org)] **En nombre de **Francesco Bartoli
**Enviado el:** jueves, 12 de enero de 2017 12:05
> Then which manage.py command are you running from there? What error are you
facing?
/local-60fab480-58a3/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM
=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2d
lby5vcmc=), the extensible, open source mail client.
On gen 12 2017, at 11:43 am, Vázquez López, José Manuel (DGITIP-Serv.
> No, I’m in the same directory:
> geonode at centjeedes12:geonode$ pwd
> /home/geonode/geonode
> geonode at centjeedes12:geonode$ ls -l
> total 132
> -rw-r--r-- 1 root root 2687 ene 11 10:07 AUTHORS
> -rw-r--r-- 1 root root 120 ene 11 10:07 CONTRIBUTING
> -rw-r--r-- 1 root root 758 ene 11 10:07 dev_config.yml
> -rw-r--r-- 1 root root 547 ene 11 10:07 docker-compose.override.yml
> -rw-r--r-- 1 root root 1127 ene 11 10:07 docker-compose.yml
> -rw-r--r-- 1 root root 199 ene 11 10:07 Dockerfile
> drwxr-xr-x 7 root root 4096 ene 11 10:07 docs
> drwxr-xr-x 22 root root 4096 ene 12 09:54 geonode
> drwxr-xr-x 2 root root 124 ene 11 10:10 GeoNode.egg-info
> -rw-r--r-- 1 root root 35147 ene 11 10:07 license.txt
> -rw-r--r-- 1 root root 1448 ene 11 10:07 Makefile
> -rwxr-xr-x 1 root root 1064 ene 11 10:07 manage.py
> -rw-r--r-- 1 root root 325 ene 11 10:07 MANIFEST.in
> drwxr-xr-x 8 root root 116 ene 11 10:07 package
> -rw-r--r-- 1 root root 22331 ene 11 10:07 pavement.py
> -rw-r--r-- 1 root root 10190 ene 11 10:07 README
> lrwxrwxrwx 1 root root 6 ene 11 10:07 README.rst -> README
> -rw-r--r-- 1 root root 1569 ene 11 10:07 requirements.txt
> drwxr-xr-x 8 root root 90 ene 11 10:07 scripts
> -rw-r--r-- 1 root root 62 ene 11 10:07 setup.cfg
> -rw-r--r-- 1 root root 4712 ene 11 10:07 setup.py
**Enviado el:** jueves, 12 de enero de 2017 11:28
> So now is or isn't the error related to not being able to find the manage.py
script? Is something else?
/local-3ac7d7af-88ee/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=am0u
=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmF
ycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), the extensible, open
source mail client.
On gen 12 2017, at 10:38 am, Vázquez López, José Manuel (DGITIP-Serv.
> I think the script can’t find somewhat…
> This is my current PATH:
> /usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/java/bin:/home/geonod
e/.local/bin:/home/geonode/bin
> If I type python, the interpreter starts correctly
> But, if I type python manage.py or python manage.py migrate or python
manage.py tururu… I obtain the error.
> Thanks
> Jose
**Enviado el:** miércoles, 11 de enero de 2017 15:36
> Yes it is but you don’t need to move any file. Please make sure to have
python and pip commands in your PATH before running:
> $ pip install -e .
> and
> $ python manage.py <something>
> Again each of them has to be executed from /home/geonode/geonode
> Francesco
> Il giorno 11/gen/2017, alle ore 10:55, Vázquez López, José Manuel (DGITIP-
<[jm.vazquez.lopez at cfnavarra.es](mailto:jm.vazquez.lopez at cfnavarra.es)> ha
scritto:
> Yes, this repo works.
> Continuing the manual, I should modify the _local_settings.py.sample_ file
and save it _as local_settings.py_, but that file doesn’t exist.
> I can see two other: _local_settings.py.geoserver.sample_ and
_local_settings.py.qgis.sample, _ so I modified the geoserver one and save it
as _local_settings.py_
> Is this correct?
> Then, _the manage.py_ is not _in /home/geonode/geonode/genode_ directory,
instead it is in _/home/geonode/geonode_, so I have copied it to
_/home/geonode/geonode/genode_ in order to execute it (and obtain the same
error as above)
> Is this correct?
> Thanks
> Jose
**Enviado el:** lunes, 09 de enero de 2017 16:14
> Have you already tried with this repo
[http://rpm.pbone.net/index.php3?stat=3&search=libxslt-
python&srodzaj=3&dist[]=94](http://rpm.pbone.net/index.php3?stat=3&search
=libxslt-python&srodzaj=3&dist%5B%5D=94&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEu
ZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3BlekBjZm5h
dmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0Bs
aXN0cy5vc2dlby5vcmc=)?
> Il giorno 09/gen/2017, alle ore 13:10, Vázquez López, José Manuel (DGITIP-
scritto:
> Hi, Francesco.
> Sorry about _Christmas long break_.
> First, I Can’t find the proper libxslt-python package,
> After do sudo yum install -y git gdal gdal-python geos python-pip python-
imaging \
> python-virtualenv python-devel gcc-c++ python-psycopg2 libxml2 \
> libxml2-devel libxml2-python libxslt libxslt-devel libxslt-python,
> I get this:
> No existe disponible ningún paquete libxslt-python
> The rest of packages seem to be installed.
> Continuing the manual, I arrive at this point:
> python manage.py migrate with this result:
> Instrucción ilegal
> And, I can see this message in /var/log/messages:
> Jan 9 13:06:24 centjeedes12 kernel: traps: python[62459] trap invalid
opcode ip:7f938dbbabee sp:7fff2b18c058 error:0 in
etree.so[7f938d99c000+4b7000]
> Thanks
> Jose
> **De:** "[xbartolone at gmail.com](mailto:xbartolone at gmail.com)"
**Enviado el:** jueves, 22 de diciembre de 2016 17:06
**CC:** "[geonode-users at lists.osgeo.org](mailto:geonode-users at lists.osgeo.org)"
> Hi Josè,
What kind of issues are you facing?
Francesco
Inviato da [ TypeApp](http://www.typeapp.com/r&r=am0udmF6cXVlei5sb3BlekBjZm5hd
mFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3Ble
kBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c
2Vyc0BsaXN0cy5vc2dlby5vcmc=) per iPhone
> On 22 dic 2016 [ at 16:29](x-apple-data-detectors://1&r=am0udmF6cXVlei5sb3Bl
ekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVl
ei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vv
bm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=), Vázquez López, José Manuel (DGITIP-
> Hi,
> Has anyone installed geonode over RHEL 7?
I'm having trouble installing it, following the guide [ http://docs.geonode.or
g/en/master/tutorials/install_and_admin/setup_on_centos/setup_centos.html](htt
p://docs.geonode.org/en/master/tutorials/install_and_admin/setup_on_centos/set
up_centos.html&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0
BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cX
Vlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=)
> Thanks
> **José Manuel Vázquez**
> Lurraldeko Informazio Sistemen Atala / Sección de Sistemas de Información
Territorial
> Informazio Sistema Korporatiboen Zerbitzua / Servicio de Sistemas de
Información Corporativos
> Informatika, Telekomunikazio eta Berrikuntza Publikoaren Zuzendaritza
Nagusia / Dirección General de Informática, Telecomunicaciones e Innovación
Pública
> Lehendakaritzako, Funtzio Publikoko, Barneko eta Justiziako Departamentua /
Departamento de Presidencia, Función Pública, Interior y Justicia
> **Nafarroako Gobernua** **Gobierno de Navarra**
> [C/ Cabárceno, 6](x-apple-data-detectors://5&r=am0udmF6cXVlei5sb3BlekBjZm5hd
2Vyc0BsaXN0cy5vc2dlby5vcmc=) \- 3ª planta
31621 Sarriguren (Navarra)
> e-mail:
teléfono: +34 848 426 169
> Lantokiaren kokalekua / Localízame en
> [ ](https://administracionelectronica.navarra.es/ApiSitnaIFrames/VisorPunto.
aspx?x=614672&y=4741153&detalles=Informatika%2C%20Telekomunikazio%20eta%20Berr
ikuntza%20Publikoaren%20Zuzendaritza%20Nagusia%20%2F%20Direcci%C3%B3n%20Genera
l%20de%20Inform%C3%A1tica%2C%20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3
%BAblica&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0
cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5s
> [Antes de imprimir este mensaje, asegúrate de que es necesario. Proteger el
medio ambiente está también en tu mano. Mesedez, gogoan izan ingurumenaren-
inpaktua e-posta hau inprimatu baino lehen. Please consider your environmental
responsibility before printing this e-mail.](https://administracionelectronica
.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detalles=Inform
atika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzendaritza%20
Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%20Telecomu
nicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica&r=am0udmF6cXVlei5sb3BlekBjZm5h
dmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cXVlei5sb3Bl
ekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11
> [_______________________________________________
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users](https://administracione
lectronica.navarra.es/ApiSitnaIFrames/VisorPunto.aspx?x=614672&y=4741153&detal
les=Informatika%2C%20Telekomunikazio%20eta%20Berrikuntza%20Publikoaren%20Zuzen
daritza%20Nagusia%20%2F%20Direcci%C3%B3n%20General%20de%20Inform%C3%A1tica%2C%
20Telecomunicaciones%20e%20Innovaci%C3%B3n%20P%C3%BAblica&r=am0udmF6cXVlei5sb3
BlekBjZm5hdmFycmEuZXM=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=am0udmF6cX
Vlei5sb3BlekBjZm5hdmFycmEuZXM=&r=am0udmF6cXVlei5sb3BlekBjZm5hdmFycmEuZXM=&r=Z2
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170112/9a7323c2/attachment-0001.html>
More information about the geonode-users
