[GeoNode-users] Running Geonode development build on another ip (!= localhost)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jan 13 01:02:47 PST 2017
It looks like a libproj installation issue. Strange thing is that is
related to spatialite. I'm not aware of which component in GeoNode is using
this, maybe the GeoGig extension?
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Jan 12, 2017 at 7:58 PM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> I changed that but apparently it did not work. However, I got tired of
> trying to fix the connection issues caused by running geonode development
> in a ubuntu server from a virtualbox windows. So I installed a full
> Ubuntu-desktop and I'm now running GeoNode from localhost. Things are
> looking almost right now. Except for this message when I try to upload a
> layer.
> "GET /api/featured/ HTTP/1.1" 200 68
> java.lang.UnsatisfiedLinkError: /tmp/spatialite-3.7.22.4-
> libspatialitejdbc.so: libproj.so.0: cannot open shared object file: No
> such file or directory
> On Thu, Jan 12, 2017 at 2:56 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> I guess the issue is related to the "importlayers" command. I would have
>> to debug it in order to understand. At a first glance it looks like the
>> command does not make use of the geoserver usernamen/password defined on
>> the setttings.
>> Anyway. In order to make a test, try to update the "rest.properties" file
>> under the GEOSERVER_DATA_DIR/security/rest.properties
>> like follows:
>> /rest/process/batchdownload/download/*;GET=IS_AUTHENTICATED_ANONYMOUSLY
>> /rest/printing/*;GET,POST=IS_AUTHENTICATED_ANONYMOUSLY
>> /**;GET=IS_AUTHENTICATED_ANONYMOUSLY
>> /**;POST,DELETE,PUT=IS_AUTHENTICATED_ANONYMOUSLY
>> NOTE: this is dangerous on a public instance. Until we improve the
>> "importlayers" management command I suggest to revert this change once the
>> import has finished.
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Jan 12, 2017 at 5:45 PM, Daniel Victoria <
>> daniel.victoria at gmail.com> wrote:
>>> same error as before (attached). I'm also attaching the geoserver oauth2
>>> screen
>>> On Thu, Jan 12, 2017 at 2:21 PM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Can you please try to run the following command?
>>>> `python manage.py imporlayers -v 3 --user=admin some_shape_file`
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Thu, Jan 12, 2017 at 5:10 PM, Daniel Victoria <
>>>>> I installed GeoNode following the development installation
>>>>> instructions for Ubuntu, found on GitHub.
>>>>> That gives me GeoNode *versão 2.5.7.dev20170111233058 and GeoServer *
>>>>> 2.9-SNAPSHOT
>>>>> I also changed the scope to 'write' in the OAuth2 geonode-oauth2
>>>>> filter, following the email you sent today to the list
>>>>> Cheers
>>>>> Daniel
>>>>> On Thu, Jan 12, 2017 at 11:59 AM, Alessio Fabiani <
>>>>>> It might depend on a geoserver configuration that needs
>>>>>> authentication to access REST APIs.
>>>>>> Which version of GeoNode / GeoServer you installed exactly?
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Thu, Jan 12, 2017 at 1:59 PM, Daniel Victoria <
>>>>>>> Well, sort off. Spoke too soon.
>>>>>>> I can load geonode. I can get from geonode to geoserver and it
>>>>>>> recognizes my user. I can upload data to GeoServer using the geoserver Data
>>>>>>> importer. I can upload documents to Geonode. But, when I try to load a
>>>>>>> shapefile using geonode I get a 403-forbiden
>>>>>>> attached is the output from the command:
>>>>>>> `python manage.py imporlayers -v 3 some_shape_file`
>>>>>>> Cheers
>>>>>>> Daniel
>>>>>>> On Thu, Jan 12, 2017 at 10:14 AM, Daniel Victoria <
>>>>>>>> Thanks all for the help. I believe I've got it working now!
>>>>>>>> Cheers
>>>>>>>> Daniel
>>>>>>>> On Wed, Jan 11, 2017 at 12:03 PM, Simone Dalmasso <
>>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>>> Ah yes, don't use paver otherwise will be only in localhost. And
>>>>>>>>> yes, adapt the geoserver PUBLIC_LOCATION to your needs in settings and will
>>>>>>>>> be fine.
>>>>>>>>> 2017-01-11 14:03 GMT+01:00 Daniel Victoria <
>>>>>>>>> daniel.victoria at gmail.com>:
>>>>>>>>>> I get an error that it's not possible to connect to the address
>>>>>>>>>> http://192.168.67.103/ or http://192.168.67.103:8000/
>>>>>>>>>> But if I go to geoserver page on http://192.168.67.103:8080/geo
>>>>>>>>>> server and click on the geonode Icon, I get redirected to
>>>>>>>>>> localhost:8000 (which does not work).
>>>>>>>>>> I tryed both `paver start` and `paver start -b 192.168.67.103:8000
>>>>>>>>>> What did work was to issue `python manage.py runserver
>>>>>>>>>> 192.168.67.103:8000`. With that I can get to GeoNode at the
>>>>>>>>>> address but the link to Geoserver does not work because it looks for
>>>>>>>>>> geoserver under localhost:8080
>>>>>>>>>> Will changing the geoserver address in settings.py fix this?
>>>>>>>>>> My setup is a bit strange because my virtualbox connects to the
>>>>>>>>>> internet via a NAT interface and connetcs to my host computer using a
>>>>>>>>>> host-only net interface
>>>>>>>>>> Thanks
>>>>>>>>>> On Wed, Jan 11, 2017 at 10:29 AM, Simone Dalmasso <
>>>>>>>>>>> Sure you can, what error do you get, 404 or something else? You
>>>>>>>>>>> may need to add the forward rule in virtualbox to port 8000.
>>>>>>>>>>> 2017-01-11 12:45 GMT+01:00 Daniel Victoria <
>>>>>>>>>>>> I'm trying to setup the GeoNode development build following the
>>>>>>>>>>>> instructions in https://github.com/GeoNode/geonode (using the
>>>>>>>>>>>> ubuntu instructions - virtualevn; pip; paver). The catch is that I have a
>>>>>>>>>>>> windows machine so I installed a Ubuntu server on a Virtualbox (just the
>>>>>>>>>>>> server, no GUI).
>>>>>>>>>>>> I can access the server running on the virtualbox through the
>>>>>>>>>>>> IP 192.168.67.103
>>>>>>>>>>>> After doing paver stat, I can get to geoserver through the IP
>>>>>>>>>>>> 192.168.67.103:8080/geoserver
>>>>>>>>>>>> However, I cannot get to geonode through the IP
>>>>>>>>>>>> 192.168.67.103:8000
>>>>>>>>>>>> Is it possible to run the GeoNode development build this way?
>>>>>>>>>>>> With just a Ubuntu server install and access through an IP other than
>>>>>>>>>>>> localhost?
>>>>>>>>>>>> Cheers
>>>>>>>>>>>> Daniel
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>> Simone
>>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170113/00a82631/attachment-0001.html>
More information about the geonode-users mailing list
