[Geoprisma-dev] Problem with zoomslider and template ordering
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Dec 7 10:26:08 EST 2009
Alexandre Dube wrote:
> Stephen,
> Could you please point your xml config file and xslt template file ?
http://imaptools.com:8080/project/myproj2/index2.php
http://imaptools.com:8080/project/myproj2/config2.xml
http://imaptools.com:8080/project/myproj2/xslt/default2.xslt
Thanks,
-Steve
> Regards,
> Alexandre
> Stephen Woodbridge wrote:
>> Alexandre,
>> Thank you that solved one huge problem and I hope will let me move
>> forward.
>> This is still a problem on r728 and trunk:
>> Try switch to OSM and the change back to WMS.
>> -Steve
More information about the Geoprisma-dev
