[Geoprisma-dev] MapFish-trunk in external
Alexandre Dube adube at mapgears.com
Mon Dec 21 13:51:52 EST 2009
=== license ===
Steve is right about the license.  I don't have not much knowledge on
the matter unfortunately and have no comments about that.
=== size of GeoPrisma ===
But still, I think we should remove all the things we don't currently
need.  The current trunk version of GeoPrisma is 772mb.  That's a lot.
What's not needed should be removed.
Before MapFish changed their repository structure, we used to have only
Mapfish-client portion included.  As soon as they changed their repos,
we included everything but it was due to this change ratter than a need
of the new features included.
I'm in favor of removing the MapFish portion we don't need : all, but
client-side.
Alexandre
Stephen Woodbridge wrote:
> Another thing to consider is product licensing. Unless I am mistaken,
> MF is licensed under one of the GPL licenses which is not compatible
> with the GP license and you should probably not mix these two together
> or it will change your license to GPL one.
> See the COPYING COPYING.LESSER files:
> http://www.mapfish.org/trac/mapfish/browser/framework/client/trunk
> -Steve
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
