[Geoprisma-dev] MapFish-trunk in external
Yves Moisan
yves.moisan at boreal-is.com
Mon Dec 21 16:03:39 EST 2009
> === license ===
> Steve is right about the license.
Not really. The Modified BSD licence we are using is compatible with
the GPL MapFish is using :
http://www.fsf.org/licensing/licenses/index_html#GPLCompatibleLicenses
> === size of GeoPrisma ===
> But still, I think we should remove all the things we don't currently
> need. The current trunk version of GeoPrisma is 772mb. That's a lot.
> What's not needed should be removed.
> Before MapFish changed their repository structure, we used to have only
> Mapfish-client portion included. As soon as they changed their repos,
> we included everything but it was due to this change ratter than a need
> of the new features included.
> I'm in favor of removing the MapFish portion we don't need : all, but
> client-side.
I'll see what we can do with excluding directories in externals.
Yves
> Alexandre
> Stephen Woodbridge wrote:
> > Another thing to consider is product licensing. Unless I am mistaken,
> > MF is licensed under one of the GPL licenses which is not compatible
> > with the GP license and you should probably not mix these two together
> > or it will change your license to GPL one.
> > See the COPYING COPYING.LESSER files:
> > http://www.mapfish.org/trac/mapfish/browser/framework/client/trunk
> > -Steve
More information about the Geoprisma-dev
