[Geoprisma-dev] QueryOnClick - Highlighting WFS.fromWMSLayer
Yves Moisan yves.moisan at boreal-is.com
Fri Nov 6 09:50:12 EST 2009
New thread = "Highlighting WFS.fromWMSLayer"
> Yves Moisan wrote:
> > Just saw something interesting on the OL list :
> > "So I have an OpenLayers map that has a WMS Layer on it, and a
> > GetFeature control that uses the WFS.fromWMSLayer Protocol in
> > conjunction with a Vector Layer to highlight a selected Feature."
> > So it seems like it is possible to highlight what is selected with a
> > queryonclick highlighted in the WMS (or does that return the
> > corresponding features ?).  That would potentially make the marker issue
> > moot.  That could also probably be used in the InitialView widget.
> > I'll put that in Trac when the JIRA history is shoved in.
> > Yves
> That could be only possible if a vector layer (of the same resource) was
> added to the map and if the QueryOnClick widget was enhanced with a
> "AutoResourceActivation" tool, like the Shortcut widget.  Do you see
> what I mean ?
> Unless there's a vector layer of the same resource, it would be
> impossible to "highlight" anything with a simple getfeatureinfo request...
Right.  Here's what's in /OpenLayers/Protocol/WFS.js :
"Function: OpenLayers.Protocol.WFS.fromWMSLayer
Convenience function to create a WFS protocol from a WMS layer. This
makes the assumption that a WFS requests can be issued at the same URL
as WMS requests and that a WFS featureType exists with the same name as
the WMS layer."
If we take the service url, maybe the proxy could issue a WFS request to
the <wms> service url (e.g. MapServer in our case) and get something
back without the need to add another resource ?  I just thought the very
name "WFS.fromWMSLayer" was a hint that one could get some features from
a WMS layer.  I know better how that works now.
Highlighting a feature after either a query for info (QueryOnClick) or
when one ends up zoomed on a feature (ShortCut, InitialView, the
deprecated QuickZoom) is really one of the most obvious things missing
in the eyes of GeoPrisma users so I figured if someone got a feature
highlighting to work on a WMS layer, that would be worth investigating.
In short, can we get a small number of features (e.g. those
corresponding to the tolerance set e.g. in the mapfile) that could be
used on a "highlight" utility layer that could be used for other things
as a "temp" layer in GeoPrisma much like for example the "Cosmetic
layer" (or whatever its name) is used in MapInfo to store transient
features/annotations, etc. ?
Yves
More information about the Geoprisma-dev mailing list
