[Geoprisma-dev] Caching on client-side, TileCache example
Alexandre Dube
adube at mapgears.com
Fri Nov 6 10:18:11 EST 2009
Devs,
I'd like to discuss an important matter : caching on the client-side
browser in GeoPrisma, most particularly "TileCache" tiles returned by
the Proxy.
=== Is it wrong ? ===
The first thing that comes to my mind is that GeoPrisma is an
"access-controled" application, so caching tiles on the client side
could be wrong. For example :
User "A" has access to some tiles (from sensitive data)
He visits his application on a public station and the browser caches
the tiles
Then he logs off (leaving the cache there)
User "B" doesn't have access but he's smart and evil
He goes directly in the cache folder and "voilà"
Or the same tile request that are cached won't reach GeoPrisma proxy
since they are cached and will return "304" response....
In brief, client-side caching really seems to be wrong in a secured
environment, but it's quite annoying to be waiting for query responses
(tiles) you should normally have while browsing your map, like zooming
in and out and in and out always makes the same requests but without any
caching it becomes much slower...
=== Caching currently in GeoPrisma ? ===
Currently, GeoPrisma doesn't cache tiles at all on browser-side. I
made some tests to verify that fact with the lastest trunk version of
TileCache that now has X-SendFile support. I tested with mod_sendfile
and it works perfectly. The first query directly sent to the tilecache
service returns an "Expires" tag that is read by the browser and used
for caching :
=== tilecache query on the service directly ===
curl -I
"http://127.0.0.1:8087/tilecache/tilecache.py?LAYERS=gmap_base&BBOX=860892.7437255,-935783.25,2667113.9905882,870437.99686275&REQUEST=GetMap"
HTTP/1.1 200 OK
Date: Fri, 06 Nov 2009 14:40:18 GMT"200" and the same request made after
returns "304", see :
Server: Apache/2.2.11 (Unix) PHP/5.2.9 mod_python/3.3.1 Python/2.6.2
Expires: Fri, 06 Nov 2009 15:40:18 GMT
Last-Modified: Fri, 06 Nov 2009 14:27:36 GMT
Content-Length: 11451
ETag: "477b4a52f4600"
Content-Type: image/jpeg
Using the same TileCache service but going through the GeoPrisma Proxy
reveals some more tags with "no-cache" added. Therefore, the Proxy
prevents caching.
curl -I
"http://127.0.0.1:8087/geoprisma/demo/proxy.php?osmservice=S_TC_DEV4G&osmtoken=TODO
Delete
this&osmresource=R_GMAP_BASE&FORMAT=image%2Fjpg&LAYERS=gmap_base&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A42304&BBOX=860892.7437255,-935783.25,2667113.9905882,870437.99686275&WIDTH=256&HEIGHT=256"
HTTP/1.1 200 OK
Date: Fri, 06 Nov 2009 14:40:16 GMT
X-Powered-By: PHP/5.2.9
Set-Cookie: PHPSESSID=f420f531163be39d51d519f6b61ea6a0; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0,
pre-check=0
Pragma: no-cache
Connection: close
Content-Type: text/html
=== Do we want caching in GeoPrisma ? ===
My first though is 'yes', since it comes with a big performance
improve while using the application. We should list the potential flaws
it can creates and find a way to fix them.
What are your thoughts on that subject ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
