[Geoprisma-dev] Trac
Alexandre Dube adube at mapgears.com
Mon Nov 9 08:58:45 EST 2009
Yves Moisan wrote:
>> Thanks a lot for the efforts.
>>   Should we have more detailed components, like OpenLayers - MapServer -
>> GeoExt - etc do ? Like :
>>   Widget
>>   Widget - QuickZoom
>>   Widget - MapFishRecenter
>>   Widget - Merge
>>   etc.
>> Alexandre
> Hi Alexandre,
> I was going to answer you I thought we had enough components for now,
> but I checked the GeoExt Trac and they have quite a few.  I'm not sure
> we need a detailed set of components at this point.  Or maybe you'd like
> to sort active tickets per component type ?  Trac provides default
> filters for version and milestone.  Do we need to filter by component ?
> Cheers,
> Yves
I get your point.  It could be interesting to do so, but not mandatory.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
