[Geoprisma-dev] Where do we build the widget doc ?
Pascal Martin
pascal.martin at boreal-is.com
Mon Nov 23 14:12:13 EST 2009
Alexandre Dube a écrit :
> Hey,
> Simple question : where can I build the widget doc ? I can see the
> following [1] on geoprisma.org, but not locally.
> Thanks,
> [1] http://geoprisma.org/dist/build/html/widgets/list/Shortcut.html
in each widget directory make file .rst
trunk\src\client\widgets\shortcut\Shortcut.rst
More information about the Geoprisma-dev
