[Geoprisma-dev] Where do we build the widget doc ?
Alexandre Dube
adube at mapgears.com
Tue Nov 24 08:37:35 EST 2009
Yves Moisan wrote:
> I wonder if a more recent version of Sphinx would help ?
> Yves
I'm able to build the doc, but the .rst files from the *samples* and
*widgets* are *not* included in the build. They *have to be manually
copied*.
Unless I'm mistaken, the only way to build the doc with an automatic
copy all .rst files from the samples and widgets is by using the *build*
button on the website, which uses this script [1]. I can't use the
button since I'm using FGS (which has no Sphinx installed). So, my
solutions are :
1. Every time I want to build the complete doc, manually copy those
missing files ( a pain in the @$$ )
2. Add Sphinx to FGS
3. Add the 'copy' fonctionnalities to the make.bat script (is that
possible / plausible ? )
[1] ./site/php/service/doc/build_gen_doc.php
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
