[Geoprisma-dev] Where do we build the widget doc ?
Alexandre Dube
adube at mapgears.com
Tue Nov 24 09:52:10 EST 2009
Yves Moisan wrote:
> http://www.maptools.org/fgs/index.phtml?page=readme.html
> "Before using the FGS environment, you need to set some
> environment variables (each time you login) :
> $ cd $FGS_HOME
> $ . setenv.sh
> (replace $FGS_HOME with your FGS path)
> OR you can do it automatically each time you log in by doing :
> echo ". $FGS_HOME/setenv.sh" >> ~/.bashrc"
> I do the former. If you do the latter, then you're toast. So either
> you disable that all shells have FGS as their default environment or
> indeed you get Sphinx installed.
I also do the former. My point is : either way, if you use FGS, when
you click the "build" button, it uses the FGS environment (which has no
Sphinx), so I guess I'll go with this solution (if it's not too
complicated).
Thanks to everyone for your time,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
