[Geoprisma-dev] Proposed change in workspaces
Alexandre Dube adube at mapgears.com
Thu Nov 26 12:09:44 EST 2009
Yves,
Yves Moisan wrote:
> I don't think it makes sense to be able to use many maps in a workspace.
Why not ?  Where would you put the "multi-map" support then ?
> but I think it's better to use a different map object to tweak map options for now.
I agree.
> Also, the mapfishlayertree need not be specified as a widget to include in a workspace.  That makes it a "special" widget.
That's a flaw IMHO, in the same way, all widgets that are not linked to
any resource should also be considered as "special" :
MeasureTool
GeoExtToolbar
Scale
ZoomSlider
MousePosition
LegendPanel
GeoExtux_GeoNamesSearchCombo
That's old discussion stuff ;)
=== conclusion ===
+0
Since you seem need the update really quickly, it would be ok to commit
these changes.  But, I think more 'conceptualization' could have been
done to include the possibility to have 'mutli-map' support some day,
and the workspace structure seemed the perfect way to accomplish this.
In the end, I'm ok with the changes.
Best regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
