[Geoprisma-dev] alloverlays question ... again
Yves Moisan
yves.moisan at boreal-is.com
Mon Apr 12 10:46:41 EDT 2010
Hi All,
I still wonder why I can easily make a GP sample for alloverlays
(http://geoprisma.org/samples/alloverlays/index.php) and can't get it
to work in our application. Here's the case : OpenStreetMap as
baselayer and a bunch of other layers as overlays. You'd think adding
<alloverlays>true</alloverlays> in the map object and <isbaselayer>false
</isbaselayer> for the OSM layer (which was previously set to true)
would turn the map to an alloverlays, but I still can't tick the OSM
layer off. I now get the checkbox typical of OL overlays for the OSM
layer, but it still behaves as if it were a radio button. Is it a
matter of layer type ? On geoprisma.org, the alloverlays example uses
WMS images. Could it be that GYMO type layers are just baselayers only ?
TIA,
Yves
More information about the Geoprisma-dev
