[Geoprisma-dev] Cleanup the samples
Alexandre Dube
adube at mapgears.com
Fri Dec 10 14:16:14 EST 2010
Got it.
Alexandre
On 10-12-10 02:00 PM, Yves Moisan wrote:
> Hi Alexandre,
> Sounds good. Please see below some specific widgets I would rather
> not clear right now.
> Thanx.
> Yves
>> Do you agree with this list :
>> === REMOVE ====
>> alloverlays
>> bdga
>> geoextux/geonamessearchcombo
>> google/default
>> helloworld
>> mapfishlayertree
> Would keep in a "deprecated" section; just so we users of the old
> widgets still have examples to rely on ...
>> merge_split
>> pdfprint/withprintproxy
> Would keep in a "deprecated" section; same reason as above; we will
> start implementing your replacement widget in 2011 for sure.
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
