[Geoprisma-dev] Updated samples on GP website missing includes
Yves Moisan
yves.moisan at boreal-is.com
Tue Dec 14 14:07:28 EST 2010
Hi Alexandre,
I can confirm the functions you wrote to get the header/footer files
resolves to a real file (echo debugging says). When I go "echo
getSampleHeader();" in index.php I see a good string. Why it is not
included in the final page is a bit beyond my PHP/JS skills. I can't
see where getSampleHeader() is called. I thought the problem might have
been due to some different way of accessing files between OS'es, but it
may be more a JS issue. The only thing I notice in FireBug is that the
style.css file is sought in the samples/zoomslider directory whereas it
is in the samples/ dir. I'll try and give it another spin later today.
Yves
More information about the Geoprisma-dev
