[Geoprisma-dev] mapfishlayertree and initialview
    Alexandre Dube
    adube at mapgears.com
    Tue Feb 16 11:59:13 EST 2010
Yves,
  The behavior you're describing doesn't apply to the Shortcut widget,
see the example [1].  The MapFish layertree already listen to the
"visibilitychanged" and "changelayer" events (see
MapFishLayerTree.xslt).  I don't know what's going on, but maybe a look
at the source of the layertree and shortcut widgets could help.
  Regards,
Alexandre
[1] http://geoprisma.org/samples/shortcut/activateresources/index.php
Yves Moisan wrote:
> Hi All,
> I have found that layers that comprise a resource with an initialview
> attached will be automatically activated upon loading the map with the
> initialview *without* the mapfishlayer tree corresponding layer being
> ticked on.  It is similar to the selfActivate option of the shortcut
> widget, only the layer isn't ticked on in the tree.
> Another issue I found is that when the resource that has an initialview
> widget attached to is part of a "compound WMS" layer, e.g.
> <layer>
>     <resourcenames>
>         <resourcename>RSMunicipalities</resourcename>
>         <resourcename>RSvegetation_tline</resourcename>
> 	<resourcename>RSstructures_mine</resourcename>
>         <resourcename>RSstructures_tline</resourcename>
> 	<resourcename>RSroads_tline</resourcename>
>         <resourcename>RSwater_river_tline</resourcename>
> 	<resourcename>RSwater_stream_tline</resourcename>
>   <!--resourcename>RSmonitoring_stations</resourcename-->
>         <resourcename>RSwater_monitoring_stations</resourcename>
>     </resourcenames>
>     <servicetype>wms</servicetype>
>     <options>
>         <layername>LYR_WMS</layername>
>         <isbaselayer>false</isbaselayer>
>         <projection>EPSG:32644</projection>
>         <format>image/png</format>
>         <transparent>true</transparent>
>         <singletile>true</singletile>
>     </options>
> </layer>
> Then all those layers will be shown on map load (without any of the
> layers in the tree ticked on).  That is understandable, since there is
> one call to MapServer, but that's not what we want on initialview.  In
> the example above, the <!--resourcename> tag is the one with the
> initialview.  I had to take it out of the compound WMS layer and shove
> it into a layer of its own, so that means any layer we want an
> initialview on cannot be used in an optimized compound WMS layer.
> Should I file a bug for that ?  And should I file a bug for the
> layertree not being ticked on or is it me ?
> Cheers,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
