[Geoprisma-dev] Roadmaps, Releases, and timelines ...
Julien-Samuel Lacroix
jlacroix at mapgears.com
Mon Jan 4 13:49:29 EST 2010
We should probably do a wiki page for the roadmap. Anyway on our side
there's some development coming for a redlining/cosmetic tool (most work
is in GeoExt), the Print tool, the new config driver, a WMS layer adder
and some more. We'll probably know more in the following weeks.
Julien
Yves Moisan wrote:
> Hi Stephen,
> First : Happy New year ! We have tentatively tied features to release
> numbers in Trac. I will do a more thorough review this week, but as you
> mention most of the things that will make it in to GeoPrisma will be
> project driven.
> For the record, here's what I need to get done soon :
> - edit point/vertices location by punching in coordinates directly in a
> textbox (probably dependent on a OL enhancement)
> - print widget
> In the latter case, some work has been committed in a patch but I feel
> more work needs to be done to bring it in line with the MapFish print
> widget or better the GeoExt print widget that should be coming soon.
> Before the holidays, I've been working on optional feature highlighting
> when people zoom to a feature (e.g. via the InitialView, recenter or
> ShortCut widgets), but I'm struggling with JS. My New Year's resolution
> is to get better at JS :-).
> I understand the need for project predictability from a third party
> programmer's point of view and we will try our best to determine a
> feature plan and stick to it. I need such a plan too :-)
> Cheers,
> Yves
>> Hi devs,
>> As I jump on GeoPrisma and start planning a new project with GeoPrisma
>> at its core, I went searching for Roadmaps, Releases, or timelines and
>> didn't find much.
>> There are also a lot of changes happening to GeoPrisma as it moves into
>> a public OpenSource project.
>> It would be very helpful to have some kind of information about
>> Roadmaps, Releases, and timelines or whatever that could be used to
>> roughly plan around. Things like when might we see the new
>> XMLMapContextConfig, or when might snapping be added to featureCreate
>> and featureUpdate widgets or when might the printWidget be released,
>> etc. I only use these as examples in general. Actually knowing when
>> these are planned for would also be helpful.
>> I know these things are often subject to change based on funded projects
>> that might get dropped into the mix that were not part of the initial
>> plan and lots of other things. These are not a problem if we as users
>> and project planners get updates when things changes so we can adjust
>> our expectations and plans accordingly.
>> It would be good to just know:
>> Next release is version ... with ballpark freeze, beta, rc1 dates of ....
>> We plan to have x, y and z enhancements and maybe others
>> We plan to tackle bugs .... and maybe others
>> Just thinking out loud about process and getting more visibility into
>> what is happening when.
>> Best regards,
>> -Steve
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev
