[Geoprisma-dev] LegendPanel layername issue
Yves Moisan
yves.moisan at boreal-is.com
Thu Jan 7 11:38:44 EST 2010
Hi List,
I've come across a small irritant about what is displayed in the legend
panel for layer name. The case is a bundled layer :
<layer>
<resourcenames>
<resourcename>RSMunicipalities</resourcename>
<resourcename>RSvegetation_tline</resourcename>
<resourcename>RSstructures_mine</resourcename>
<resourcename>RSstructures_tline</resourcename>
<resourcename>RSroads_tline</resourcename>
<resourcename>RSwater_river_tline</resourcename>
<resourcename>RSwater_stream_tline</resourcename>
<resourcename>RSmonitoring_stations</resourcename>
</resourcenames>
<servicetype>wms</servicetype>
<options>
<layername>LYR_WMS</layername>
<isbaselayer>false</isbaselayer>
<projection>EPSG:32644</projection>
<format>image/png</format>
<transparent>true</transparent>
<singletile>true</singletile>
</options>
</layer>
Now, I've set the legend for the last resource only
(RSmonitoring_stations). The only layername I can change is LYR_WMS but
I certainly can't change it to Monitoring stations because what happens
when I add the legend widget to another resource ? In fact what happens
is that I get symbols for all resources in a rather uncontrolled way and
no way to distinguish between resources. I wouldn't want to make
separate layers because of the bandwith penalty ...
Does the new config driver address this issue ? We were talking about
bundling requests to MapServer, so the legend will become an issue.
Cheers,
Yves
More information about the Geoprisma-dev
