[Geoprisma-dev] Attribute filtering
Alexandre Dube adube at mapgears.com
Mon Nov 1 08:12:22 EDT 2010
Etienne,
   I totally agree that this could be a GeoExt.ux widget.  All the
features you mentioned about it have no direct dependence on GeoPrisma.
A thread could be started on the GeoExt-DEV ML.
   In you project, do you need any access control using filtering ?  For
example, "restrict the data X to a given extent and a given attribute
having a specific value to the user Y".   If so, that could be discussed
here.
Regards,
Alexandre
On 10-10-29 03:11 PM, Etienne Dube wrote:
> Hi guys,
> We have a new requirement in one of our projects, that involves
> attribute filtering on a vector layer. What's needed is a widget that
> allows the user to filter the features to be displayed by specifying
> an attribute, an operator and a comparison value. One or more of these
> criteria could be combined using logical operators (AND/OR) to create
> more complex queries; eventually multiple filtering expressions could
> be combined by forming a tree of conditions, similar to what the OGC
> Filter Encoding standard describes. Such a feature has already been
> discussed previously (see ticket
> http://trac.osgeo.org/geoprisma/ticket/38).
> I spent some time defining the problem and exploring what tools could
> be used to solve it. A few thoughts:
> - We could offer two different modes for this widget:
>     1. A preconfigured mode, in which the choices of attributes (and
> possibly operators) to filter on, along with the logical operators
> used to combine these criteria, would be defined in the widget's
> configuration. Different preconfigured query templates could be
> defined in this way, for every layer the widget applies to. The user
> would only have to fill in the values to filter on.
>     2. An "expression builder" mode. In this case, the choice of
> attributes, operators and any logical combination (AND/OR) or criteria
> would be left to the user, and a GUI panel would be provided to build
> these expressions. This mode mostly targets GIS specialists and other
> power users who have an understanding of boolean logic, in order to
> fulfill various free-form querying needs.
> - Initially we could provide support for vector layers only.
> OpenLayers already provides the OpenLayers.Filter classes to build the
> filtering expressions, and is able to do filtering on the client side.
> However, since it's not a particularly efficient way of doing things,
> a way to pass the filter expression to the service would be desirable.
> As Yves mentioned in ticket #38, FeatureServer offers basic attribute
> filters as criteria passed in key/value pairs in a GET request, but
> this support is quite limited: it seems that only 1 criteria per
> attribute is accepted, there's no way to combine multiple criteria
> using AND/OR operators (AND is the default when specifying a filter
> for more than 1 attribute) and only the PostGIS data source is
> supported for attribute filters. Short of extending FS and its
> protocol, a solution could be to add a WFS proxy and pass a Filter
> Encoding expression in the request (as you may know, OL already has
> the logic to generate an ogc:Filter element from OpenLayers.Filter
> objects).
> - Support for filtering WMS layers (issued from vector sources) would
> be a good idea too. I believe it's possible by passing an ogc:Filter
> as part of a SLD in the GetMap request.
> - OpenGeo developed a QueryPanel widget (it's in their GXP repository)
> that offers similar functionality; see
> http://workshops.opengeo.org/geoext/more_ogc/app.html. I've not been
> able to make it work yet, and from what I see it can only apply
> filters on WFS and WMS layers. Nevertheless, this could be a good
> starting point.
> - For the moment we can settle with text boxes for entering filter
> values, but it would be interesting to offer other control types (date
> picker, selection list). Another cool feature to have would be the
> ability to populate such selection lists with domain values (e.g.
> coming from a catalog table in the DB). However I'm not aware if any
> feature service (be it FeatureServer, WFS or MapFish Server) can do
> that kind of stuff, and I think it wouldn't be extremely elegant to
> have to establish an off-the-band connection to the data source for
> retrieving those domain value lists.
> I think that the widget could be developed as a GeoExt ux first, since
> it's usefulness goes beyond the scope of GeoPrisma. I'm writing here
> to have some initial feedback, and I'm open to continue the discussion
> on the GeoExt dev mailing list if you feel it would be more relevant
> there.
> Ideas, suggestions and corrections are welcome.
> Etienne
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
