[Geoprisma-dev] LegendPanel and GetLegendGraphic requests
Etienne Dube etienne.dube at boreal-is.com
Thu Oct 14 17:12:12 EDT 2010
  Hi list,
In one of our projects, we noticed an issue with the behavior of the
LegendPanel widget. This is for a map which has many layers, but only a
few of them are initially visible. However, we noticed that when the
LegendPanel widget is added to a workspace, GetLegendGraphic requests
are issued for every WMS layer, even if these layers are invisible.
Looking at the code, I noticed that the GeoExt LegendPanel takes every
layer in the Map widget and creates LayerLegend objects, whatever the
visibility of the layer is. These LayerLegend (in occurrence WMSLayer
objects) for invisible layers are added as invisible divs in the legend
panel, with the src of the contained img element pointing to the
GetLegendGraphic URL for the layer. So in effect, these images are
loaded from the server even if they're not displayed, which is far from
optimal.
Any idea for what would be the best way to change this behavior? I can
suggest two possibilities:
- What about a GeoExt-based LayerTree? It could manage its own store for
visible layers, and the LegendPanel could attach to this store in order
to manage only LayerLegend objects for layers that are really visible.
However I don't know enough about GeoExt to say if it's easy to do.
- We could modify or subclass LegendPanel, so that it instanciates
LayerLegend objects only for visible layers. The handler for update
events on the layer store (which is triggered when a layer changes
visibility) would have to add/remove LayerLegends depending on the
visibility status of each layer.
Thanks,
Etienne
Etienne Dubé
Consultant / Développeur
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Tel. :  514.313.5951 #1131
Courriel: etienne.dube at boreal-is.com
More information about the Geoprisma-dev mailing list
