[Geoprisma-dev] maxextent on OSM
Yves Moisan
yves.moisan at boreal-is.com
Tue Sep 21 16:32:31 EDT 2010
Le 2010-09-14 15:40, Alexandre Dube a écrit :
> Hi Yves,
> To my eyes, it's an OpenLayers issue. You should open a ticket
> showing a live (very simple) openlayers demo demonstrating the problem.
> For the time being, you could set the map center in your
> template.xslt file directly. That would do the trick on load but when
> clicking on the "maxextent" button you would still be zoomed out of
> your extent. A quick fix for that could be to overwrite the control
> like this (add this in your template.xslt) :
> OpenLayers.Control.ZoomToMaxExtent.prototype.trigger = function(){
> if (this.map) {
> this.map.setCenter(new OpenLayers.LonLat(55,55), 5);
Just another remark : I notice on the GYMO example that for a given
"view level" an oMap.getZoom() gives X for GYM and X+2 for OSM. That
is, for the same viewport, OSM always has a zoom level higher than the
other GYM layers. I tried changing the map object's <numzoomlevels> but
it's always the same. Weird.
Cheers,
Yves
More information about the Geoprisma-dev
