[Geoprisma-dev] WFS Proxy
Etienne Dube
etienne.dube at boreal-is.com
Fri Mar 18 15:49:44 EDT 2011
Hey guys,
The WFS Proxy works and is ready to be committed. For the moment only
the GetFeature operation is supported, using an XML POST request type
(that's what OpenLayers uses by default).
I had to do a slight change in the API of the Proxy class, namely making
Proxy::getLayers() non-static (it's now an instance method which uses
member variables) ; WFS queries are way more complex than any other ones
in existing proxies, and I added members in the WFSProxy class to keep
track of the kind of request that is being processed and the XML body of
the POST request. WFSProxy::getLayers() uses this information (namely to
parse the XML request), hence the change in the API. I applied the
change to every subclass of Proxy too, and made sure that every call to
getLayers() is done using an object instance instead of calling a static
class method.
Note that I didn't bother to add support for WFS layers in the old Map
widget ; it's only supported in Layer widgets used along a MapPanel.
Should we do it also for the Map widget??
This change shouldn't break anything, but if you want to review the new
code before I commit it, just ask and I'll prepare a patch.
Otherwise, is it okay for you all if I commit the code? I still need to
clean up the sample (we will need a WFS service on the geoprisma.org
server for the sample to work) and implement other operations
(GetCapabilities, DescribeFeatureType and transactional operations), but
at least we'll have a first working implementation in the trunk.
Etienne
Etienne Dubé
Developer
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Canada
Tel. : 514.313.5951 #1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev
