[Geoprisma-dev] WFS Proxy
Etienne Dube
etienne.dube at boreal-is.com
Mon Mar 28 13:49:05 EDT 2011
Hi Alexandre,
On 18/03/2011 4:01 PM, Alexandre Dube wrote:
> Hi Etienne,
> On 11-03-18 03:49 PM, Etienne Dube wrote:
>> Hey guys,
>> The WFS Proxy works and is ready to be committed. For the moment only
>> the GetFeature operation is supported, using an XML POST request type
>> (that's what OpenLayers uses by default).
>> I had to do a slight change in the API of the Proxy class, namely
>> making Proxy::getLayers() non-static (it's now an instance method
>> which uses member variables) ; WFS queries are way more complex than
>> any other ones in existing proxies, and I added members in the
>> WFSProxy class to keep track of the kind of request that is being
>> processed and the XML body of the POST request. WFSProxy::getLayers()
>> uses this information (namely to parse the XML request), hence the
>> change in the API. I applied the change to every subclass of Proxy
>> too, and made sure that every call to getLayers() is done using an
>> object instance instead of calling a static class method.
> That's fine.
I also modified the new WPSProxy class to comply with this API change.
>> Note that I didn't bother to add support for WFS layers in the old
>> Map widget ; it's only supported in Layer widgets used along a
>> MapPanel. Should we do it also for the Map widget??
> I'd say no need to.
>> This change shouldn't break anything, but if you want to review the
>> new code before I commit it, just ask and I'll prepare a patch.
>> Otherwise, is it okay for you all if I commit the code?
> Run a phpcs to the files you changed then you can commit. Simply link
> the revision in your ticket you created.
> http://trac.osgeo.org/geoprisma/ticket/201
phpcs threw a bunch of errors for almost every source file in my local
copy (not only the new WFS proxy files). Are there any settings that I
have to use with phpcs so that it checks the coding style according to
what we already use?
Anyway, I made sure that the coding style in the new files is similar to
existing .php files, and went ahead with the commit.
Thanks for your feedback!
Etienne
>> I still need to clean up the sample (we will need a WFS service on
>> the geoprisma.org server for the sample to work) and implement other
>> operations (GetCapabilities, DescribeFeatureType and transactional
>> operations), but at least we'll have a first working implementation
>> in the trunk.
> Commit often, release early. That's fine. Just put notices as you
> commit in the ticket.
> Regards,
Etienne Dubé
Developer
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Canada
Tel. : 514.313.5951 #1131
Email: etienne.dube at boreal-is.com
More information about the Geoprisma-dev
