[Geoprisma-dev] Merge of the attributefilterpanel branch
Alexandre Dube
adube at mapgears.com
Tue May 10 08:06:46 EDT 2011
On 11-05-09 05:37 PM, Etienne Dube wrote:
> Hi Alexandre,
> Thanks for your (and Julien's) input. I did the merge (r1034),
> everything seems fine on my local copy. I'll make sure to configure
> the FeatureServer datasource on the geoprisma.org machine to make the
> new sample work correctly.
Or you could pick any from the existing samples, like the
dev4g.mapgears.com one.
> PGSQLMapContextConfig isn't supported by the widget yet, so your help
> would definitely be welcome. I'll let you know when I have some time
> to spend on that.
Got it.
Regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
